4low to2wdwd please help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by protacodan, Mar 3, 2018.
  1. Mar 3, 2018 at 6:29 PM
    protacodan
    protacodan [OP] Well-Known Member
    GILROY Ca.
    2017 Tacoma TRD PRO
    285/75/16 KM3’s. Cali Raised rock sliders Revtek 427AP lift kit Victory 4x4 Strike bumpers Warn VR8S winch
    i am a newbie I was checking out 4low when I tried to switch back to 2wd it stayed in 4low I didn't want to drive on street in 4low placed in park turned off engine and tried again still 4low drove about 40-50 feet then big clunk went to 2wd is this normal or just me 2017 TRD Pro
  2. Mar 3, 2018 at 6:31 PM
    DylansBase
    DylansBase Well-Known Member
    Dylan
    Murfreesboro TN
    2007 DCSB Taco TRD Off-road
    Bilstein 5100 w/OME 886 All pro expo leafs w/icon 2.0 Relentless Fab plate bumper BFG KO2
    Make sure you’re in nuetral when you transition to/from 4Lo. I’m not sure about 3rd gens but 2nd gens you can go to 4Hi on the fly at low speeds. But all in all stop, put in neutral then switch to 4Lo. Put back in drive and roll until it shows 4x4 is engaged
    You gotta start somewhere! Welcome!
  3. Mar 3, 2018 at 6:37 PM
    protacodan
    GILROY Ca.
    2017 Tacoma TRD PRO
    Had it both park and nuetral when switching?
  4. Mar 3, 2018 at 6:40 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    You should go into 4HI first, (solid 4x4 light) then go to 4LO....Not straight from 2WD to 4LO.....
  5. Mar 3, 2018 at 6:41 PM
    protacodan
    GILROY Ca.
    2017 Tacoma TRD PRO
    Okay thanks
  6. Mar 3, 2018 at 7:31 PM
    Kingair84
    Kingair84 Well-Known Member
    Wisconsin
    2016 Double Cab TRD Off Road 6 speed MT
    Rad Industries skid plate, trd pro grill, rigid DOT Fogs
    Every now and then I’ll get a clunk when taking it out of 4wd. It won’t hurt anything it’s a Toyota. If you put it up on a hoist and looked at the size of the transfer case and 4wd components on these trucks you would see they are built very well. Hope that alleviates any of your concerns sometimes things just clunk.
  7. Mar 3, 2018 at 7:36 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Now try it with both oars in the water and turn that crawl control on! :)
    over60[QUOTED] likes this.
  8. Mar 3, 2018 at 7:37 PM
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    Always use neutral, not park. Takes any pressure off the deiveline. If it doesnt shift in to or out of low...place the dial back to where it was, drive a little way, put back in neutral and try again. NEVER, drive with it trying to shift and beeping. Sometimes takes a few times for everything to mesh.
  9. Mar 3, 2018 at 7:37 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    ALL 4X4 vehicles can at times be difficult to get out of 4lo. Don't try to go straight from 4lo to 2hi. You are asking the transfer case to do 2 things at once. Stop, place in neutral and shift to 4hi. If if doesn't shift out of 4lo within a couple of seconds shift back to 4lo, then go to reverse and back up 10-15 ft, then move back forward 10-15' and try again. Depending on how hard you've been using it you may have to do this dance several times to get it back to 4hi. Once in 4hi place the truck in gear and drive off. Once moving then go to 2hi.
    over60 likes this.
