4low-trac
Discussion in 'Technical Chat' started by Isthatahemi, Sep 12, 2009.
  1. Oct 28, 2010 at 10:22 AM
    #221
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    Of course not.. How could I...
    I've searched, but you see the titles people use "help!?" and "another one" instead of "can't get brake disk off 2010" or "hood alignment help"
    But I've read all the one's with decent titles and linked from other threads with decent titles.
    Marc70 likes this.
  2. Nov 22, 2010 at 7:05 PM
    #222
    Tamich
    Tamich New Member
    Tacoma
    Just got my Taco TRD Sport Double Cab and was wondering if anyone confirmed for 2011 non-atrac models?
  3. Dec 16, 2010 at 9:56 PM
    #223
    pollock21
    pollock21 Well-Known Member
    Brian
    Cornelius, NC
    '11 Tacoma DC, TRD Sport 4x4
    Bump for 2011 confirmation!
  4. Dec 16, 2010 at 11:39 PM
    #224
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    try it and if it works, report back. if not just splice the wire back together
  5. Dec 17, 2010 at 12:28 AM
    #225
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    It is that easy! Don't delay, clip your yellow wire today!
    Tridet167 likes this.
  6. Dec 17, 2010 at 5:06 AM
    #226
    rwilso03
    rwilso03 Well-Known Member
    Russ
    Dayton
    2010 DC SB 4.0L 6spd Barcalona Red
    TRD Exhaust, Engine Ticking Fix, Fog Lights Anytime, Locking Center Storage, 4LO Trac Mod, Rear Spring TSB
    ^^ I think that rhymes...
  7. Dec 31, 2010 at 11:35 AM
    #227
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Confirmed for 2011 (build date before dec 2010)
  8. Jan 4, 2011 at 3:01 PM
    #228
    jaredpa28
    jaredpa28 Well-Known Member
    jared
    longmont, colorado
    2010 TRD Sport 4 Door Longbed
    1.Weathertec front and rear 2.Front windows tinted to match. (23%)? 3. Rear TSB 4. TOYTEC coil overs up front and Bilstein 5100's front and rear. 5. Sway bar relocate 6.Front diff drop kit 7. Skid plate drop kit 8.Light Racing UCA's 9. 265/70/17 Cooper Discoverer STT 10. backup camera mod. 11. wildernest 12. "yellow wire" mod
    did mine today. would really like to thank "isthatahemi" and "yoytoda" for all the work and info. great job you guys!!!
    A SIDE NOTE: i didnt even bother to unplug from the harness. i just located the wire, cut it, and slapped some electric tape on.
    i also did not disconnect the battery. the reason for this is i had the dealer go into the ecu and disable the passanger side seatbelt alarm. i have dog that rides with me and i get sick of the damn alarm going off.
  9. Jan 4, 2011 at 3:06 PM
    #229
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Folks - just a headsup. There are some instrument panel wiring changes on Tacos with mfg date beginning Dec 2010. So if you're planning on doing this mod on a truck build on or after that date - you should reconfirm the wiring.
  10. Jan 5, 2011 at 10:55 AM
    #230
    Yoytoda
    Roland
    completely stock
    fyi
    to disable seat alarm.
    1. turn key on with driver belt not connected.
    2. press and hold odo/trip button for 12 long seconds.
    3. while holding the button down connect the driver belt.
    4. b-on will show up. press odo/trip button until b-off comes up.
    5. Seatbelt alarm now off.
  11. Jan 6, 2011 at 9:48 AM
    #231
    jaredpa28
    jared
    longmont, colorado
    Hmmm. nice to know. thanks
  12. Feb 6, 2011 at 2:37 PM
    #232
    BP348
    BP348 Well-Known Member
    San Diego, CA
    2004 DC 4x4
    will this work on my 2011 reg cab?
  13. Feb 6, 2011 at 3:12 PM
    #233
    Yoytoda
    Roland
    completely stock
    It should. Try it. If it doesn't work you could always splice them back together. Compare the pictures. I'm 99% sure it'll work fine
  14. Feb 7, 2011 at 6:39 AM
    #234
    Nick54
    Nick54 Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    5. Seatbelt alarm now off.[/QUOTE]
    What's just as good as choking the seat belt chirp is choking the chirp that happens every time you move the transmission from drive to reverse and back again. What the &^%* was Toyota thinking with that one. Do I need to be warned that I'm back in drive after I reversed???
  15. Feb 7, 2011 at 6:45 AM
    #235
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    Did this mod on my 09. Was able to easily puill the wire out from the plug using a saftey pin. No permanent cuts in wire to be spliced at a later date. Can easily just slide it back in. Seems to work fine. Have not had an opportunity to REALLY field test it.
  16. Feb 7, 2011 at 6:45 AM
    #236
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i dont have any reverse/drive warning on my 09 and didnt have one on my 07...sounds odd
  17. Feb 7, 2011 at 8:03 AM
    #237
    David K
    X2... and I have had 3 Tacos ('01, '05, '10) none with any noise/ sound changing gears...
  18. Feb 8, 2011 at 1:52 PM
    #238
    Tacomanic
    Tacomanic Member
    This is a truly awesome mod and many thanks to this forum and all those who eased my skepticism with their thoughtful posts.
    I am totally convinced that there is no way I could have made it into my place in the Sierra without the mod earlier this winter. Even with this mod it was rough. I put Blizzacks on my 2010 and even then with 14 inches of snow on a very steep grade of unplowed road and ice at the bottom of the snow it was gnarly. My biggest trouble was the rear end bouncing up and down trying to get traction, even with sand bags. No way of making it crawling as the 4 banger would just flat come to a stop. Little by little though I "plowed" my way up. Thanks again.
    I actually had a mechanic friend help me with this following the threads here so it got done right and took less than 20 minutes.
  19. Feb 8, 2011 at 2:44 PM
    #239
    Yoytoda
    Roland
    completely stock
    the only thing i can think is in the standard, the reverse is very close to reverse so itll beep to let you know so you dont accidently put it in reverse.
  20. Feb 8, 2011 at 2:46 PM
    #240
    Yoytoda
    Roland
    completely stock
    the rear end bouncing is due to axle wrap. custom leaf packs or add a leaf will help alot with that.
