4low-trac
Discussion in 'Technical Chat' started by Isthatahemi, Sep 12, 2009.
  1. Feb 9, 2011 at 8:37 AM
    #241
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Essex county NY
    23 trd OR DCSB 4x4 silver
    a cross on my rearview Circle mirror Scotch guard seats
    bump for 2011 regular cab
  2. Feb 9, 2011 at 4:31 PM
    #242
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    try it...
    i cut the wrong wire the first time and my truck wouldnt start. I spliced it, cut the other wire, and my truck runs fine...
    It wont hurt if you try...
  3. Feb 19, 2011 at 3:14 PM
    #243
    BUB_IROC_Z
    BUB_IROC_Z Well-Known Member
    Anthony
    North Eastern Ohio
    2010 4x4 4.0 Taco
    3 inch OME, Rear diff breather mod, Aeroforce Interceptor Gauge and custom gauge pod, Yellow Wire Mod, Avid Off-road bar, Bud built Skid Plates,
    Just completed this mod and it works great! The only problem I Had was when I was messing with putting in a switch I set off the ABS and traction lights. I turned the truck off and back on and they were gone though. All and all a great mod. Tried and tested.
  4. Feb 27, 2011 at 10:42 AM
    #244
    06TRDZombieHunter
    06TRDZombieHunter Well-Known Member
    Robert
    Hillsboro, OR
    06 TRD Sport DCLB
    K&N Intake System Port and Polish of TB x2 E3 Diamondfire Sparkplugs 2.5" Leveling kit 32" BFG A/Ts Zombie Response decals Custom painted grill, trim under headlights, scoop, intake and manifold. No more mud flaps, Temp gauge inside intake box, BHLM, extra D-rings in front of bed, No more plastic storage box behind rear seats. More to come.
    So I have an 06 TRD Sport and it does great off road, 4Hi or 4Loco, I dont think it has Trac or ATrac... There are no lights on the dash when I lose traction and it doesnt matter if 2H 4H or 4Loco. So if I dont have the Trac system in 4H will this mod do anything in Lo? I looked at the systems that come standard on the FJ Cruisers on Toyotas website, they have some sweet videos there describing not only traction aides, but suspension and transmissions and stuff too. I just dont know if my truck is too old to even have these systems onboard. As I understand the ATrac on the OffRoad packages is a switch next to the fog lights so its only on when you want it?
    Thanks for the pics though, Im gonna take a look later today.
    Rob
  5. Feb 27, 2011 at 11:36 AM
    #245
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    This was for trucks w/ TRAC, so if you dont have it, this will do nothing for you.
  6. Feb 27, 2011 at 7:08 PM
    #246
    Yoytoda
    Roland
    completely stock
    09+ non ATRAC TRD offroad trucks. So all 4wd tacomas 09 and newer with TRAC
  7. Feb 28, 2011 at 3:25 AM
    #247
    The_Hodge
    SC
    there are 05-08 trucks w/ VSC/TRAC, but they are few and far between. it was an option that didnt get used too much.
  8. Feb 28, 2011 at 9:09 AM
    #248
    Yoytoda
    Roland
    completely stock
    there were 05-08 w VSC none of them went the step further and had TRAC. Early VSC would limit throttle to prevent wheel slippage and limit throttle if the yaw was too great, but none of them would transfer power via braking system when one wheel or the other looses traction. Ive seen a few older Reg cabs with VSC and they def didnt have TRAC
    From all the info i have gathered. I could be wrong...
  9. Feb 28, 2011 at 9:16 AM
    #249
    The_Hodge
    SC
    you could very well be right and i'm overstepping VSC into TRAC.
  10. Mar 1, 2011 at 8:41 AM
    #250
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    So this is good for the '11 models built before december of '10? Just want some clarity. I don't mind doin this mod but I don't like bitchin somethin up accidently while trying to accomplish somethin else.
  11. Mar 1, 2011 at 10:06 AM
    #251
    Yoytoda
    Roland
    completely stock
    i think its ok for all 2011s it wont mess anything up. i cut the wrong wire and my truck wouldnt start, spliced it, no problem. pre 09 dont even have yellow wires there so thats a good indicator. look for the yellow wires...
  12. Mar 1, 2011 at 5:55 PM
    #252
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    for more confidence, go to toyotaowners.com - pay 15 bucks and get access to fsms and service manuals and -especially- exact schematics with wire colors for your exact truck.
    Yeah, I know you can find some schematics on TTORA, but they're for a 2006, and the wiring harness changes from year to year.
  13. Apr 10, 2011 at 7:22 AM
    #253
    Gunny
    Gunny Active Member
    Randy
    Jacksonville, FL
    09 4X4 TRD Sport
    TRD Induction Sys, TRD pipes. Side bars, roof rack
  14. Apr 15, 2011 at 12:40 PM
    #254
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    Before I cut the wire on my 2010 reg cab 4x4, I want to make sure I'm doing it correctly. Here's a pic I just took. Do I cut the yellow wire that is second from the top here (where I'm pointing)?
    I'm going wheeling tomorrow and wont have a bunch of time to fix things if this messes everything up. Here are the steps I'm going to do: 1. Disconnect the battery 2. Unplug that clip with all the wires going into it 3. Cut the yellow wire second down from the top 4. Connect clip back in 5. Connect battery
    Is this correct? What if I dont unplug the white clip with all the wires going into it before I cut the yellow wire?
    Thanks guys!
  15. Apr 15, 2011 at 2:42 PM
    #255
    Yoytoda
    Roland
    completely stock
    yep thats the one!!! the second down with the thinner black stripe...
  16. Apr 15, 2011 at 3:25 PM
    #256
    especk
    Erik
    Redding, CA
    You rock! Thanks Roland
  17. May 10, 2011 at 12:41 PM
    #257
    iJDub
    iJDub Well-Known Member
    Would a 05-08 TRD Offroad with rear locker be better than an 09+ TRD Sport with TRAC and wire mod?
  18. May 10, 2011 at 12:54 PM
    #258
    The_Hodge
    SC
    better for?
  19. May 10, 2011 at 1:31 PM
    #259
    JimmyBuckets
    JimmyBuckets Well-Known Member
    Access Cab 6 speed V-6 sr-5
    If I hold the traction control button down to turn off traction control...would this in effect make the truck function in 4 LO with out TRAC if I have the Yellow Wire Mod? I have done the wire mod, and have not had a chance to test it out yet, but wanted to know if turning off traction control would in effect be like turning off TRAC.
  20. May 10, 2011 at 2:00 PM
    #260
    JimmyBuckets
    Thanks I actually came back to edit my post since I found the answer in this thread. So I apologize for asking an already covered question. I hardly ever go "off roading" but this mod just seems to make the truck safer if I were to ever be in a bad situation. It would seem Toyota doesn't give us this feature to add more value to the TRD Off Road package? I went for the SR5 package over a TRD Sport since I could see no real benefits to the TRD Sport other than some eye candy. Not that the Sport doesn't look great...but the package doesn't add any capability to the truck like the Off Road package. Now I really feel I have the best of both worlds! Thanks guys.
