4low-trac
Discussion in 'Technical Chat' started by Isthatahemi, Sep 12, 2009.
  1. Sep 30, 2011 at 2:21 PM
    #381
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    Exactly, which sucks. I will say that TRAC on this truck is amazing, I'm extremely impressed at how well it works, especially having just come from the same exact truck without those options. I just want the ability to disengage it. Can you turn VSC OFF with your switch in 2WD, or only 4WD?
    Also one more question, which may have already been discussed but I don't recall...Does TRAC control the front diff in 4WD as well as the rear diff? Obviously it's controlling the rear diff in 2H, but is it still only the rear diff even in 4WD, or the front diff as well? Sorry if this has been answered...
  2. Sep 30, 2011 at 2:32 PM
    #382
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    In 2wd, I can turn VSC and TRACtion control off by pressing the vsc switch for 3+ seconds (while the truck is parked).
    In 4wd, VSC is off automatically. As soon as you switch to 4wd, it goes off.
    TRACtion control is all 4 wheels when in 4WD.
  3. Sep 30, 2011 at 2:36 PM
    #383
    GP3
    California
    4X4 TRD Off Road
  4. Sep 30, 2011 at 2:57 PM
    #384
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Well I'll be darn... I just tried it and your absolutly right. I''ll have to add this one to the list of other discrepancies in the owners manual. Thanks!! :)
  5. Sep 30, 2011 at 3:58 PM
    #385
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    Awesome, thanks for the link and clarification! I'd like to perform this mod with the addition of an OEM VSC switch.
    I had actually found this link before, but wasn't sure if it was the option I am looking for, as my primary goal is to be able to disable VSC and TRAC.
    Disabling ABS worried me a little, as I don't know why you would want it disabled. I know a lot of people make comments about how ABS almost killed them, but I have never had an issue with it so I don't know what it is that causes people to hate it.
  6. Sep 30, 2011 at 5:19 PM
    #386
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Wow my head is spinning! I will need to re-read your guy's replies again... but until I get some rest and come back... Let me say that TRAC and A-TRAC are MILES APART in what they do.
    TRAC is a limited slip traction control it does work on the front and rear on 4WD trucks. However, (at least since 2009) it only works in H4, not in L4 (unless you do the 4 low trac/ yellow wire mod). L4 is open differential only... unless you have A-TRAC, and push the A-TRAC button.
    A-TRAC is far greater than limited slip, it is about the same as front and rear lockers in the traction it provides, but without the negatives (loss of steering control, added expense, etc.). A-TRAC needs a hydraulic brake booster in order to hold the spinning tire as firmly as it does to the rotation of the opposite traction tire... It doesn't just slow down the spin, it halts it. The A-TRAC makes some pretty bazaar noises in the front end when it is working... a grunting-clunking sound, if-you-will. This is normal.
    Now, those of us with the hydraulic brake booster (Off Road 4WDs) probably have a stronger TRAC. When I see videos of Sport Tacos using TRAC, I see a lot more spinning before it goes to work then my truck experiences...?
  7. Sep 30, 2011 at 6:21 PM
    #387
    GP3
    California
    4X4 TRD Off Road
    Yes, please do re-read the posts.
    Summary:
    • TRAC is available on pre-2009 trucks.
    • 2006-2007 4X4 OR trucks have the infamous hydraulic brake booster.
    • 2006-2007 4X4 OR have TRAC in 4L
    • 2006-2007 4X4 OR's TRAC is way more aggressive than Yoytoda's videos.
    Because of the above, I went as far as calling 2006-2007 4X4 OR trucks equipped with TRAC, ATRAC. I'd love to know why I am wrong, besides the fact I dont have a button to turn ATRAC on. Instead, I have a button to turn it off. :).
  8. Sep 30, 2011 at 6:57 PM
    #388
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    not to be a douche but this thread is for doing the yellow wire mod for non trd offroad 09+ tacomas...
    i want to stay on topic so others can benefit from this mod and not have to weed through the "clutter"
    Marc70 likes this.
  9. Sep 30, 2011 at 6:58 PM
    #389
    GP3
    California
    4X4 TRD Off Road
    No problem.
    Just trying to help out the pre 09'ers.
  10. Sep 30, 2011 at 7:00 PM
    #390
    Yoytoda
    Roland
    completely stock
    meant it in the least douchey way possible... :eek:
    our little trucks dont have the goodies of the trd offroad but the yellow wire mod helps a ton...
  11. Sep 30, 2011 at 7:07 PM
    #391
    GP3
    California
    4X4 TRD Off Road
    I understand completely. I guess I turned the topic towards my truck, but I meant to help pre 09'ers. They might have TRAC, so the yellow wire mod likely applies.
  12. Oct 8, 2011 at 3:39 PM
    #392
    disk_55FL
    disk_55FL Well-Known Member
    disk
    Buckeye
    '17 TRD Sport MT
    2010 SR5 4X4
    So I have Trac and Auto LSD.
    I jacked up both right side tires and tried to move the truck in both 4 Lo and 4 Hi.......Nada. It wouldn't budge.
    What am I missing.....I intended to do the YWM and this was going to be a before and after test.....but it should have moved in 4 Hi ....correct ?
  13. Oct 8, 2011 at 5:36 PM
    #393
    Yoytoda
    Roland
    completely stock
    was the traction control icon on your dash flashing at all? its not instant either
  14. Oct 8, 2011 at 5:51 PM
    #394
    disk_55FL
    disk
    Buckeye
    '17 TRD Sport MT
    No .....nothing flashing in 4 hi or 4 Lo.
    Any ideas ?
  15. Oct 8, 2011 at 6:01 PM
    #395
    Yoytoda
    Roland
    completely stock
    no idea. when the system works i get flashing lights...
  16. Oct 8, 2011 at 6:09 PM
    #396
    disk_55FL
    disk
    Buckeye
    '17 TRD Sport MT
    I can sit there running in first gear....I can hear the wheels turning....but the TRAC doesn't try to stop the jacked up / spinning wheels.
    Others have described how they can hear the brakes modulating.
    No sense in doing the YWM if the TRAC is not working in 4 Hi.
  17. Oct 8, 2011 at 6:11 PM
    #397
    Yoytoda
    Roland
    completely stock
    it works better in 4 lo but thats still surprising you dont get anything...
  18. Oct 8, 2011 at 6:15 PM
    #398
    disk_55FL
    disk
    Buckeye
    '17 TRD Sport MT
    As much as I hate to....I'll call the dealer on Monday. I'm wondering if they will recognize this " test " as a legitimate way to verify that TRAC is working ?
    :confused:
    I appreciate your input....I was ( am ) looking forward to having TRAC in 4 Lo ......I have a long lane that drifts bad in the winter and I'm going to need all the help I can get !
  19. Oct 8, 2011 at 6:17 PM
    #399
    Yoytoda
    Roland
    completely stock
    yea right... you will wind up on the dealer shop stupid customer wall of shame...
    take it out and test it on the trail... find someplace really off camber to get a wheel or two in the air
  20. Oct 8, 2011 at 7:38 PM
    #400
    BH15001
    BH15001 Well-Known Member
    SW PA
    09 Tacoma DC LB SR5
    Tried the same thing with floor jacks, found out it did not work in just drive until you started to give it a little gas. Be careful not to drive off the jacks.
