4low-trac
Discussion in 'Technical Chat' started by Isthatahemi, Sep 12, 2009.
  1. Oct 8, 2011 at 7:42 PM
    #401
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    i forgot to ask if your auto or manual. you have to give it some gas. you cant just let your foot off the clutch/brake
    you actually have to "try" to move.
  2. Oct 8, 2011 at 9:52 PM
    #402
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    If you aren't an Off Road, there is a longer delay for the limited slip to engage. The Off Road 4WDs (2009+) have a hydraulic brake booster to power the A-TRAC. This must also be why our TRAC in H4 and AUTO LSD in H2 work almost instantly and not the long lag such as I have seen in the videos of the non-Off Roads, with the Yellow Wire Mod...??
    How long and at what RPM did you gas it while on jack stands?
  3. Oct 8, 2011 at 9:59 PM
    #403
    Yoytoda
    Roland
    completely stock
    to reiterate
    it actually wont kick in unless you hit the gas as well. maybe to prevent stalling? idk but not only is it delayed you actually have to try
  4. Oct 9, 2011 at 5:44 AM
    #404
    disk_55FL
    disk_55FL Well-Known Member
    disk
    Buckeye
    '17 TRD Sport MT
    Thanks guys ....you've nailed it. I didn't give it any throttle, for I feared it would LAUNCH off the jacks !
    But I tried it again in 4 Lo .....went up to 3K and nothing.....but in 4 Lo it tried to go at about 2K so that's a very good thing.
    Actually I was pleasantly surprised that it didn't get violent and jump off !
    But I could definitely tell it was working.
    YWM is next.....I'm sure it will succeed :cool: !!!
    Thanks again.....Love my TACO !
  5. Oct 9, 2011 at 6:44 AM
    #405
    disk_55FL
    disk
    Buckeye
    '17 TRD Sport MT
    Worked as advertised......the easiest, quickest and best performance Mod I've done so far.
    Initially I thought I needed to pull the plug connector to be able cut the wire and heat shrink it .....not, plenty of room to do the job.
    Thanks all for your guidance and patience !
  6. Oct 9, 2011 at 8:20 AM
    #406
    Yoytoda
    Roland
    completely stock
    did you mean it didnt work in 4lo but did in 4hi?
    because this is before the mod?
    Marc70 likes this.
  7. Oct 9, 2011 at 8:37 AM
    #407
    disk_55FL
    disk
    Buckeye
    '17 TRD Sport MT
    Yes....I wanted to pre test the Mod to confirm it did work. I had the truck jacked up but I didn't know you needed to gas it to get it to work.
    So pre Mod it worked as intended in 4 Hi...but not in 4 Lo ( as designed by Toyota )
    Then I performed the Mod.....and it worked in 4 Lo and 4 Hi.
  8. Oct 9, 2011 at 8:46 AM
    #408
    David K
    Great news... I was wondering as well, because you typed: But I tried it again in 4 Lo .....went up to 3K and nothing.....but in 4 Lo it tried to go at about 2K so that's a very good thing."
    The second '4 Lo' was really '4 Hi' then... How long until or at what RPM did the limited slip engage?
  9. Oct 9, 2011 at 8:56 AM
    #409
    disk_55FL
    disk
    Buckeye
    '17 TRD Sport MT
    I stand corrected....
    It is a manual tranny.
    I just went out and tested it again.
    It's idling at around 1200 - 1300 ( cold ) and the Trac engages at 1500~.
    So I put it in gear and let out on the clutch and just touch to gas and it tries to move.
  10. Oct 9, 2011 at 10:08 AM
    #410
    David K
    That is great!
    Makes you wonder about those here who say the TRAC/ AUTO LSD is no good and they prefer a mechanical limited slip... without even giving the new technology a chance!
  11. Oct 9, 2011 at 10:29 AM
    #411
    disk_55FL
    disk
    Buckeye
    '17 TRD Sport MT
    Tech is cool.....and it makes my Truck more capable .....and cheaper than a locker.
    Thanks again......let it snow !
  12. Oct 13, 2011 at 2:17 PM
    #412
    jonny
    jonny Betty White Edition Heep ZJ
    Hoping Roland or DavidK can chime in real quick. (asking for an 09 4x4 sport owner)
    Would it be beneficial for someone with a 2009 sport 4x4 to do the yellow wire mod? Will it help slower crawl traction in 4low?
    SOunds like such a noob question...but I am at work and can't scroll through 20+ pages :p
    TIA
  13. Oct 13, 2011 at 2:18 PM
    #413
    Yoytoda
    Roland
    completely stock
    short answer. yes.
    the ywm will add traction in 4lo
  14. Oct 13, 2011 at 2:22 PM
    #414
    jonny
    thanks Roland!
    I will let him know and hopefully we can test this out soon :spy:
  15. Oct 13, 2011 at 2:23 PM
    #415
    jonny
  16. Oct 13, 2011 at 2:23 PM
    #416
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
    Yes it will help traction. Whatever 09 4x4 Sport owner who hasn't done this is a noob.
    I'm a noob and will be getting this done. Thanks Jonny!
  17. Oct 13, 2011 at 2:25 PM
    #417
    jonny
    :p
    We should knock this out while we are doign your 5100's.
    :thumbsup: thanks Hemi & Yoy
  18. Oct 13, 2011 at 2:27 PM
    #418
    PerfectTekniq
    Pepe Silvia
    Claremont, CA
    They arrived at 2:02pm today. :yay:
  19. Oct 13, 2011 at 5:40 PM
    #419
    David K
    Yes... as per the Sport guys! A spinning tire is a waste of energy... a traction tire is pure bliss!
  20. Oct 13, 2011 at 9:02 PM
    #420
    PerfectTekniq
    Pepe Silvia
    Claremont, CA
    ATRAC FTMFW!
