4low-trac
Discussion in 'Technical Chat' started by Isthatahemi, Sep 12, 2009.
  1. Jan 5, 2012 at 7:53 AM
    #441
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    it is by far the easiest mod i have done to my truck... you could have even done the mod right there on the trail. it takes no tools (ecept for something to cut the wire. which could be anything from nail clippers to a sharp rock) :D
  2. Jan 5, 2012 at 10:59 AM
    #442
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    I briefly thought about doing it right then and there. The problem though was that it'd been a few months since I read this thread so couldn't be sure about exactly which wire I should be dicking with. Last thing I needed at that point would have been cutting something I shouldn't! I think that would've gone something like this-
    Now which one was it...:confused:
    Uh-Oh...:eek:
    $*(^(*$)^#*&^#$&*#$^!!#@#$&*@!!!!:mad:
    Oh man, it's gonna be a long walk back to the highway...:(
  3. Jan 27, 2012 at 11:21 PM
    #443
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    sub'd...........want to read later!!
  4. Feb 18, 2012 at 12:27 PM
    #444
    mjm540ii
    mjm540ii Ding Dang Dee
    Oxford, PA
    2010 TRD Sport AC V6
    Fog light mod, interior LED's, illuminated switch, B110 5100's in the rear, Satoshi Grill, Hella 500's, 4X Innovations sliders, rear diff breather mod, painted rocker panels, bhlm, yellow wire mod, CB, Wheeler's 2"aal, Allpro diff skid, ubolt flip, LR UCA's, 885X's w/ 13mm spacer on 5100's, Spydertrax spacers, Relentless IFS/ mid/ T case skids, 255/85/16 KM2s, block heater, DTRL mod, T2 eyelids, Wheelers Superbumps, Extended SS brake lines, ATO shackle flip kit,1" 4Crawler BL, Elite fr plate bumper, Flyzeye LEDs, Drilled and slotted rotors, 20" LED bar
    Just did this today! Now I can tell my girlfriend that I was working on my drivetrain electronic traction control system alllll day...;)
  5. Feb 21, 2012 at 7:55 AM
    #445
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    I have the same truck as you. Just wanted to how this has worked out for you? Have you been out wheeling to try it out? Is it the same wire as on other years?
  6. Feb 21, 2012 at 8:41 AM
    #446
    Utard
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    So...whats up with all the down hill? A 2wd truck could do that.
  7. Feb 21, 2012 at 9:26 AM
    #447
    Utard
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    So I found the photo on page three. I went out to my truck and there is some differences on the colors. The photo here shows only 2 yellows in spots 1 and 2. On my 2012 the first three are yellow. Anyone cut the second one on a 2012 yet. Is it still the right one?
  8. Mar 4, 2012 at 4:12 PM
    #448
    Bobbb
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Okay, so here I am two months later staring down the barrel of a trip into the desert tomorrow and still hadn't gotten off my ass and done this mod. I finally did it today and I removed the terminal from the plug as btkicker referenced. Tried it with a pick and a too-large jeweler's screwdriver with no luck, so had to eventually dig through the bottom of my toolbox to find my tiniest driver. Only real pain about it was that, once the clip released, the terminal got stuck partway out. Wouldn't come out or go back in. Just kept dicking with it and dicking with it until it finally gave. Taped up the end so it couldn't find it's way to shorting something else and shoved it behind the module. Problem solved!
  9. Mar 5, 2012 at 7:51 AM
    #449
    Utard
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Anyone done this on a 2012 sport yet?
  10. Mar 5, 2012 at 12:01 PM
    #450
    BDT
    BDT New Member
    Edmonton, Alberta
    2012 DBL Cab Sport
    X2.. Just traded in my '08 for a 12 and kind of worried I'm getting a less capable truck. Would be great to know if this works as well and the same way for the new model. Mod looks easy, but never took out the glove box before.
    First post, and great thread. Thanks to all those that have tried it first. I do lots of ice fishing and like the grip of all 4 when I can. I run narrower winter tires with spyder spacers and chain all 4 up. Hopefully the new truck works as well.
  11. Mar 5, 2012 at 4:16 PM
    #451
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Unless you traded an '08 Off Road for a '12 Sport, if a Sport or other model for a Sport or other model, you lost nothing...
    If you wanted the most capable truck, then your 2012 should have been a 4WD Off Road TRD.
    Off Road TRDs have the extra traction systems from the factory (Rear Locker and A-TRAC)... Sport TRDs have no more traction systems than base or SR-5 Tacomas... but, they do have that scoop on the hood and color matched trim that means so much to some! Thank Goodness for the mod to help them have some more traction in low range.. TRAC in 4WD & AUTO LSD in 2WD do work!!
  12. Mar 5, 2012 at 4:20 PM
    #452
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  13. Mar 5, 2012 at 4:24 PM
    #453
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    lol
  14. Mar 5, 2012 at 4:33 PM
    #454
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
  15. Mar 5, 2012 at 4:54 PM
    #455
    BDT
    BDT New Member
    Edmonton, Alberta
    2012 DBL Cab Sport
    Thanks for the reply David. I traded (pick up the 2012 tomorrow), a sport for sport. I was worried the brake actuated LSD would not compare to the mechanical I got used to in the '08. I was all set to cut the wires on a brand new truck until I saw a post saying it may have changed for '12. Just checking if the one post was correct - that there are now 3 wires. I'll give it a try and report back. I have not test driven the new trac system in any snow but have a good understanding of how the system works from checking your previous threads. Thanks!
  16. Mar 5, 2012 at 4:57 PM
    #456
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    LAWL
  17. Mar 5, 2012 at 7:24 PM
    #457
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    :shootmyselfineheadsmiley:
  18. Mar 6, 2012 at 8:09 AM
    #458
    Utard
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    I hope someone chimes in that has done this on a 2012. I don't have the balls to just start cutting wires.
    From the photo's I have looked at on here of people doing this on older models the wires look a little different on the 2012.
  19. Mar 10, 2012 at 12:29 PM
    #459
    crooks420
    crooks420 Well-Known Member
    Jesse
    San Gabriel
    05 AC Prerunner SR5, 12 DC LB 4x4, 70 FJ40
    So has anyone actually done this on the 2012 models yet?
    I just got a 2012 DC LB 4X4 SR5, and I am looking to do this mod. I am hoping someone can offer up the info here.
    Jesse
  20. Mar 15, 2012 at 7:35 PM
    #460
    crooks420
    Jesse
    San Gabriel
    Ok, so I did this today, and it seems to work. I pulled the connector out of the plug (2nd yellow wire from top), and covered it so it wont short on anything.
    I put the truck in 4H... all good ( I heard a click coming from behind the glove box). Put it in 4L the right way (I heard an actuator engage down under the truck) and the 4LO light blinks on the dash, no buzzer. Putting the truck in 4L the wrong way (any gear other than Neutral), and both a blinking 4LO light and buzzer sound.
    So I think I did this right. Seems to be like the earlier models in that the 4LO dash light blinks.
    I will splice in a switch later on when I add my off-road/ fog lights, for when I take it to the dealer, it will function as the factory intended.
    So yes, 2012 4x4's, it is still the 2nd wire down on the top plug.... yellow wire with a thin black tracer.
    Jesse
    2012 DC LB 4X4 SR5
