4low-trac
Discussion in 'Technical Chat' started by Isthatahemi, Sep 12, 2009.
  1. Dec 13, 2009 at 6:13 AM
    #141
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    isthatahemi, do you think my switch will be a problem? I was planning on taking my truck in to get the transmision looked at sometime soon. Is that somewhere they'll be looking? If worse come to worse I can take it out, put some grey kydex I have for a center console holster in the hole to plug it up, and tape the wire (I cut it low to hide it better incase I had to). I already had to "mod" the piston for the glove box so it would stay in so if they ask about the hole I could just say its from me trying to make up a new way to hold it in place.
  2. Dec 13, 2009 at 10:01 AM
    #142
    Isthatahemi
    Isthatahemi [OP] Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Most of the Powertrain Control Modules are located there from what I understand. I would remove the switch, and hide the mod under 3M brand electrical tape. Mind you, this isn't a mod that would void any warranty, except maybe on your ABS pump or Brake booster.
  3. Dec 13, 2009 at 5:48 PM
    #143
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    However, the dealer is going to say you f'd up the whole truck and its totalled:rolleyes:
  4. Dec 13, 2009 at 6:07 PM
    #144
    Isthatahemi
    TRD OFF ROAD
  5. Dec 13, 2009 at 6:32 PM
    #145
    Yoytoda
    Roland
    completely stock
    im just saying hide it better because i would not feel like arguingwith them
  6. Dec 14, 2009 at 3:44 PM
    #146
    Isthatahemi
    TRD OFF ROAD
    Yup. That's what I was hinting at.....
    Side Rant - Why do some dealers go out of there way to screw guys out of warranty, others casually ask if they find a mod, and still warranty everything!
  7. Dec 14, 2009 at 6:19 PM
    #147
    Yoytoda
    Roland
    completely stock
    Because it looks good if they save the company money???
  8. Dec 14, 2009 at 8:36 PM
    #148
    kiddwvman
    kiddwvman Well-Known Member
    leon
    WV
    06 4 banger
    weathertec floor liner,tinted windows,bilstein 5100 front .85,5100'S rear,window vents,K@N air filter
    soooo why can't people with 06 tacomas do this mod ??????????????
  9. Dec 14, 2009 at 8:46 PM
    #149
    Yoytoda
    Roland
    completely stock
    Because you can activate TRAC in 4lo if you dont have TRAC in 4hi...
  10. Dec 14, 2009 at 8:55 PM
    #150
    kiddwvman
    leon
    WV
    06 4 banger
    ok thanks first tacoma :)
  11. Jan 6, 2010 at 8:01 PM
    #151
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    The more I drive my truck off road, the more it impresses me. Because I am not the only one curious about all the new drive modes, I have added the following to my signature on this forum. Baja was great last weekend... the new Tacoma excelled! TRAC and A-TRAC rule!
  12. Jan 24, 2010 at 12:39 PM
    #152
    Usfive
    Usfive Well-Known Member
    NH
    2016 Tacoma Access Cab TRD Sport
    I did the mod today and it works GREAT! :taco::taco: I was a bit concerned because my connector did not look exactly as above. My third wire down was a yellow wire. I was able to try it out in my snow filled driveway, both with trac on & off. Thanks Isthatahemi.
  13. Jan 27, 2010 at 3:57 PM
    #153
    David K
    'A-TRAC' is 'TRAC' in L4 or different???
    Isthatahemi,
    Please humor me, I am getting old, I guess!... In re-reading this thread I see you repeat saying the yellow wire mod gives one 'TRAC in L4'... and also say that A-TRAC works different or firmer on your new Tacoma.
    I was under the impression that new A-TRAC gave us what cutting the yellow wire did for the non A-TRAC Tacomas. Are they not the same? Should we with A-TRAC also cut the wire so we have 'TRAC' in L4, as well as A-TRAC?
    Can you tell me what is different or what is working different between A-TRAC and the yellow wire mod for TRAC in L4 mod?
    As I have posted elsewhere, I have now used TRAC (H4) and A-TRAC (L4) in sand, snow and hill climbs... far superior to my 2005 4WD with open differentials and rear locker only!
    Thank you!
  14. Jan 27, 2010 at 4:30 PM
    #154
    Yoytoda
    Roland
    completely stock
    Track is on 4wd offroad models only. For the rest of us with 09-10 non offroad we only have track in 4hi stock. for trac in 4lo we need to do the yellow wire mod. Isthatahemi originally had a non trd offroad tacoma but has since left us. he now owns a trd offroad so he has atrac
  15. Jan 27, 2010 at 4:41 PM
    #155
    David K
    Yes, I understood that...
    but Ishatahemi made it sound like his new A-TRAC Tacoma (like mine) operates different than his last one (with the yellow wire mod).
    So, I wanted to know what (if anything) is different, mechanically between the new A-TRAC and the old yellow wire mod (TRAC in L4).
    He said that TRAC in L4 is smoother, etc. vs. the more aggressive acting A-TRAC which was pretty close to true lockers front and rear. So, I either mis-understood or mis-read him.... or there is a difference between TRAC in L4 and A-TRAC in L4.
    Thanks for trying to help, but I think only hemi can answer.
  16. Jan 27, 2010 at 4:44 PM
    #156
    David K
  17. Jan 27, 2010 at 4:56 PM
    #157
    Yoytoda
    Roland
    completely stock
    David K
    Sorry i misunderstood. You are right on track though. A-trac is a much more aggressive version of TRAC. They both work the same way by applying brakes to the wheels with slippage. However, the sensors on the Atrac are way more sensitive and apply the brakes sooner and harder than TRAC does. Trac is actually designed for the street in 4hi so when one wheel starts slipping the system takes quite a bit of time to activate making it a smoother transition of power, whereas ATRAC is meant to be used only in 4lo. it senses slipping instantly and applies the brakes hard making it moan groan and chatter.
  18. Jan 27, 2010 at 5:02 PM
    #158
    David K
    Yah, it is noisy...
    So, TRAC in L4 and A-TRAC is more like comparing TRAC to AUTO LSD for the 2WD mode... Both are LSD, but AUTO LSD brakes harder and there is no power regulation... yes?
    A-TRAC is AUTO LSD in L4 perhaps?
    So, if we in the A-TRAC Tacomas cut the yellow wire we can have TRAC in L4 and A-TRAC, too... yes??? That would bring up the number of drive modes available... Not sure if I can make my signature any longer! LOL
  19. Jan 27, 2010 at 5:04 PM
    #159
    adktacoma
    adktacoma Well-Known Member
    danny
    upstate new york
    09 trd sport bsp
    stock (for now)
    I just wanna thank all you guys for figuring this stuff out and explaining it in a way that a simpleton like me can understand, and a special thumbs up to isthatahemi and yoytoda for bringing this mod to our attention. I really couldn't make heads nor tales of the manual. It's threads like this that make this such a great site.
    Big Brutus likes this.
  20. Jan 27, 2010 at 5:10 PM
    #160
    David K
    Tell me about it! The salesmen couldn't explain it and even the managers in the service department or mechanics could esplain it or even know what it has! The manual was almost NO help! I had to make my signature the way I did (until all new Tacoma owners understand the 9 drive modes they have and how they work)...
    I am still trying to figure stuff out, that's why I am asking Hemi to clear a few things up...
