4R TRD Pro Wheels Discontinued?
Discussion in 'Wheels & Tires' started by toyotahenry, Dec 25, 2020.
  1. Dec 25, 2020 at 9:00 PM
    toyotahenry
    toyotahenry [OP] N/A
    Houston, Texas
    2021 TRD OFF ROAD 4X4 ARMY GREEN
    I ran across this video from 88Rotors which do awesome work and was wondering if anyone could elaborate on this subject?
    thank you
  2. Dec 26, 2020 at 9:48 AM
    toyotahenry
    Houston, Texas
  3. Dec 26, 2020 at 9:54 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Thats not a link to the video.
  4. Dec 26, 2020 at 9:56 AM
    toyotahenry
    Houston, Texas
  5. Dec 26, 2020 at 9:58 AM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    this is the link to the video. ^
