4runner E brake screech
Discussion in 'Toyota Trucks & SUVs' started by kmok, Mar 19, 2009.
  1. Mar 19, 2009 at 3:55 PM
    kmok
    kmok [OP] Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    My brother has a 97 4runner V6 4wd and we let his truck set for a week with the e brake up a while back and now his truck screeches whenever hes driving around. Is there any way to fix this and we havent used the E brake since it had the problems...I came accross the problem on the freeway with some violent shaking while driving that was fun lol. Is it a simple job to fix the e brake?
  2. Mar 19, 2009 at 4:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Maybe one of the brake shoes is out of adjustment. You can try to repetedly engauge and disengauge the E brake about 10 times, and see if that fixes it, or, you may have to take the rear brake apart, and manually adjust it.
  3. Mar 19, 2009 at 4:57 PM
    kmok
    Kyle
    Columbus, Ohio
    We havent used the e brake for a couple of months since it first locked up and left it down so is it a bad idea to reengage?
  4. Mar 19, 2009 at 5:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The drum brakes are typically adjusted by the aplication of the E brake.
  5. Mar 19, 2009 at 5:18 PM
    kmok
    Kyle
    Columbus, Ohio
    Ok I'll go try it right now...I have nothing better to do
  6. Mar 19, 2009 at 5:25 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    if it does work, spray some lube on all the moving parts. Sounds like something got a little rust built up on it
  7. Mar 19, 2009 at 5:48 PM
    kmok
    Kyle
    Columbus, Ohio
    It didn't work so I think theres a bigger problem
  8. Mar 19, 2009 at 5:49 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    take the drum off and have someone work the ebrake..see if anything moves. May just be the cable is hanging up inside
  9. Mar 19, 2009 at 5:51 PM
    kmok
    Kyle
    Columbus, Ohio
    Ok i'll probably get to that another day its too dark outside to do anything now
  10. Mar 19, 2009 at 5:52 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    how many miles on the runner? may need a clean and adjust in the rear
  11. Mar 19, 2009 at 5:54 PM
    kmok
    Kyle
    Columbus, Ohio
    around 170k
