4Runner fog light switch Mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by mrp192, Mar 20, 2010.
  1. Mar 20, 2010 at 10:20 PM
    mrp192
    mrp192 [OP] REALLY!!
    Brent
    Cheney WA
    98 V6 4x4 limited
    Stereo, boobies
    So I saw this done on here but I don't remember who did it.. But Thanks for the Idea..
    So I got the switch from a 99-03 4runner.
    The plugs are the same BUT you are going to have to add 2 wires.. so when you get the switch get a pig tail..
    here are the two wire I added..
    The problem is that it doesnt fit perfect so you will have to take off the back plastic cover and trim where the screw goes..
    so all you have to do after all of this is add you power source to the switch and then from your wire to your relay and you set!
  2. Mar 21, 2010 at 6:38 AM
    SunDevilTacoma
    SunDevilTacoma Well-Known Member
    Doug
    Gilbert, AZ
    04 Wht Double Cab PreRunner
    Turn signal relocation, built in fog light conversion, 4" deck plate
    Cool. How 'bout some pics of the switch and lights after they've been installed?
  3. Mar 21, 2010 at 12:51 PM
    mrp192
    Brent
    Cheney WA
    98 V6 4x4 limited
    Stereo, boobies
    alright ill try to do it today
  4. Mar 22, 2010 at 7:32 PM
    mrp192
    Brent
    Cheney WA
    98 V6 4x4 limited
    Stereo, boobies
