4runner - Replacing AC controls and ECT Illumination Bulbs **PICTURES**
Discussion in '4Runner Builds' started by ramonortiz55, Jan 1, 2017.
  1. Jan 1, 2017 at 9:11 PM
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    The illumination bulbs were out on my AC controls, ECT, rear window button, rear defroster, and power point.
    This is a write up on the step by step process I took to replace the bulbs.
    My research was done here: ***************************************************************************
    After reading thru those threads, I determined I needed the following part numbers. These are for a 2001 4runner, the bulbs for other 4runner generations might be different.
    2001 4runner limited climate control light bulbs:
    Part Number #81850-35050 - 2 Total
    Part Number #81850-35040 - 2 Total
    Hazard control light bulb:
    Part Number #84999-10860 - 1 Total
    ECT and Defroster light bulb:
    Part Number #90010-01041 - 1 Total
    Rear window roll down:
    Part Number #90010-01042 - 1 Total
    Cigarette lighter:
    Part Number #84999-10250 - 1 Total
    Ordered all my bulbs from Camelback Toyota:
    Removing the center console cup holder, this is done by tugging it off:
    Then removing the shifter surround:
    Next, the radio surround is removed, gently pry it away from the dash:
    Pull it out slowly to reveal the plugs by the ac vents:
    Unplug the power point plugs:
    Once the power point plug connector has been removed, locate the bulb - it is the gray end of the power point:
    Twist to remove:
    Next, I removed the hazard switch:
    This is done by releasing the side tabs:
    Next, I removed this portion:
    This is done by releasing tabs at the ends AND at the top center:
    Next I removed the AC controls faceplate, tabs are on top. This is very flimsy, so careful:
    I then removed the screws that hold in the AC control unit, disconnected the rear plugs and pulled it out:
    At this moment, I went ahead and installed the power point bulb:
    Time for some surgery. Hazard switch:
    Twist and pull out the bulb, replace with new one:
    Now the strip, this has two bulbs. One for defroster and ECT, another bulb for the rear window switch:
    A needle nose pliers will allow the removal of one of the bulbs.
    To remove the other, the backing must be removed, a small flat head screwdriver helps here. I then removed the other bulb and replaced it.
    Next step of the surgery was to open the front of the AC control unit. I removed two screws. FOUR tabs need to be released on the top and bottom. Forks or toothpicks help keeping tabs open while I worked on other tabs.
    Carefully opened the AC control unit..
    Bulbs removed and replaced:
    I then assembled the AC control unit together.
    Reinstalled everything back together.
    Finally have all my illumination working properly!
