4runner Rock warrior rims on a tacoma
Discussion in 'Wheels & Tires' started by 07whiteTRD, Jan 25, 2017.
  1. Jan 25, 2017 at 8:50 PM
    07whiteTRD
    07whiteTRD [OP] Well-Known Member
    Josh
    NY
    07 TRD Sport White
    So I've been sitting on some 4runner rims for a while now. They are the 17 rock warrior style. Ive Been thinking about tire options and just don't know what I want to do. But I have some concerns because I read these require a very specific and expensive lug nut.
    My question is are they needed. I don't want to sound cheap when it comes to safety but are there other options? I guess I don't fully understand what these specific lugs do. And if $50 gorilla lugs will work just as good as $200 toyota ptr27-89100 I would like to save that difference. But if it's the only option then I'm fine with that.
    Someone correct me if I'm wrong but I guess toyota version is extended. But wouldn't this gorilla lug work the same? 68138
    Looking for input and suggestions. Thanks.
  2. Jan 30, 2017 at 5:26 AM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    You need the Toyota lugs because the lug holes are much deeper than normal. The back end of each lug is longer to make it easier to keep the key on it. Also the keys are longer than the one gorilla supplies.
    ChadsPride likes this.
  3. Jan 30, 2017 at 5:36 AM
    ClemsonMGM
    ClemsonMGM Even Firemen Need Heroes...
    Workin the pole!
    12 Ram 2500
    Those will look like crap....
    Send them to me for disposal...
  4. Jan 30, 2017 at 8:35 AM
    07whiteTRD
    Josh
    NY
    07 TRD Sport White
    So I guess I never looked at how deep they sit in the wheel. I will check it out when I get home. So there is no other lug nut available other then the toyota ones. Is that the same lug the 4runner uses on those wheels?
  5. Jan 30, 2017 at 8:35 AM
    07whiteTRD
    Josh
    NY
    07 TRD Sport White
    What's your address? Haha
    ClemsonMGM[QUOTED] likes this.
  6. Jan 30, 2017 at 8:21 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You might find this helpful, I have lug length measurements on page 2.
    https://www.tacomaworld.com/threads...ior-beadlock-style-wheels-on-a-tacoma.381030/
    You are going to need the Toyota lug kit.
