4Runner Seat Swap / Belt Receptacle
Discussion in '1st Gen. Tacomas (1995-2004)' started by FWAdam, Jan 6, 2017.
  1. Jan 6, 2017 at 6:29 PM
    FWAdam
    FWAdam [OP] Well-Known Member
    Indiana
    2001 Regular Cab Prerunner
    DIY Frame replacement New rear leaf springs (General Spring, stock height) Wheeler's greasable shackles Bilstein 5100 / 5125 Roll-on bedliner Poly bushings all around Leer topper Michelin Defender LTX M/S tires New drum brakes, rotors and pads, and Nickel-Copper brake lines Window tint Wheels painted black Interstate battery New spark plugs Chrome bumpers painted Bucket seats and console (soon) Emblems plasti-dipped (soon) 4x4 conversion (2017)
    Howdy folks. I recently picked up a set of bucket seats from a 2000 4Runner for my 2001 Tacoma. Before install, I tried clicking the existing seat belts into the receptacles built into the 4Runner buckets and they did not click. Anyone else run across this issue? I figured I can either use the receptacles from my bench seat and feed them through, or maybe Tacoma bucket seats receptacles could be bolted onto the same place on the 4Runner seats if I can find a set?
  2. Jan 6, 2017 at 10:18 PM
    jacobrippey
    jacobrippey It’s always Taco Tuesday Instagram #rippstik
    Jacob
    Surprise, Arizona. USA
    2004 Tacoma DC 4wd
    Find me on Instagram: @rippstik
    I had this issue. Tacoma bucket seat belts bolt right on. The bench ones won't.
  3. Jan 7, 2017 at 8:59 AM
    FWAdam
    Indiana
    Thanks man. I will seek out some replacements!
  4. Jan 7, 2017 at 9:50 AM
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    Also, not all taco seat belts are the same. Found that out.
  5. Jan 7, 2017 at 10:07 AM
    FWAdam
    Indiana
    Hmmmm ... tell me this: Will any 2001-2004 seat belt receptacle be interchangeable? As in, if I find an 01-04 receptacle from a Tacoma bucket seat, should it be compatible with the seat belt from any other 01-04 Tacoma, including one that had a bench?
  6. Jan 7, 2017 at 10:38 AM
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    Best thing to do is to actually test fit it.
  7. Jan 7, 2017 at 11:00 AM
    FWAdam
    Indiana
    I'd love to do that, but without having any nearby, I'm probably gonna have to take a semi-educated leap of faith on something . . .
  8. Jan 7, 2017 at 12:21 PM
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    I have a 95.5. Had buckets. Put in a bench seat. Had to get new belts. Then I tried out some 98 buckets. Those belts wouldnt work. The 04 seats did. Then I got rsx seats with 4Runner receivers. Those didn't work.
  9. Jan 7, 2017 at 1:02 PM
    07regtacoman
    07regtacoman Well-Known Member
    Davis Ca
    07 Silver REG Cab
    Painted arm rests, 2011 front grille,Readylift for 5lug.
    If they are too wide you can grind them down to fit.
  10. Jan 7, 2017 at 1:18 PM
    chaosrob
    chaosrob Well-Known Member
    I just used the belts from the 4runner
  11. Jan 7, 2017 at 6:44 PM
    FWAdam
    Indiana
    Yeah...I've gotta get either new belts or new buckles...
