4Runner wheel bearing vs. Tacoma question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by im4u2nvss, Dec 6, 2016.
  1. Dec 6, 2016 at 10:56 AM
    im4u2nvss
    im4u2nvss [OP] Well-Known Member
    Jesse
    2012 DC
    Does anyone know the difference between the two bearing/hubs(specifically 2003 up 4Runners and 2005 up Tacomas). It seams that Tacomas really eat the front wheel bearings, but the 4Runners hold up better(example, my 2004 4Runner had 200k+ miles on stock front wheel bearings). Also, the members on TacomaWorld that sell pre-made hubs show that they will interchange. Is there a difference between the two(4Runner sourced from Japan possibly)? Is it a fluke that my 4Runner bearings have held up this long? Any input would be awesome!
    BamaToy1997 likes this.
  2. Dec 6, 2016 at 12:51 PM
    TacomaTrav
    TacomaTrav Well-Known Member
    Travis
    07' Tacoma SR5, 4.0L 6spd, ELocker
    NONE
  3. Dec 6, 2016 at 5:32 PM
    08tacobear
    08tacobear Well-Known Member
    08 taco DCSB pre runner V-6 SR5
    12v accessory plug right rear bed bin,1gallon air compressor setup in left rear bed bin, 3-window bed topper.
    Sub'd
    Would like to know also...
  4. Dec 6, 2016 at 5:51 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Subd, also interested in this
  5. Dec 6, 2016 at 6:27 PM
    Taco'09
    Taco'09 Well-Known Member
    If you are having issues with the front wheel bearings Toy has quietly upgraded them with a new part and for lack of anything better I have been calling them the HD bearings. You may want to try them as the rollers are different in size, and IIRC there is an additional roller in each half. There is also an new mfg.
    balljoint likes this.
  6. Dec 7, 2016 at 9:35 AM
    im4u2nvss
    Jesse
    2012 DC
    Interesting. Does anyone know the brand used between the 4runner and Tacoma? This may validate a trip to toyota for a comparison of the two "new" OEM units. Maybe the new HD bearings are the same as the 4Runners originals? I for sure want to figure this out.
  7. Dec 7, 2016 at 10:16 AM
    im4u2nvss
    Jesse
    2012 DC
  8. Dec 7, 2016 at 10:18 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    richardbui23 likes this.
  9. Dec 7, 2016 at 10:21 AM
    im4u2nvss
    Jesse
    2012 DC
  10. Dec 7, 2016 at 10:38 AM
    BamaToy1997
    Bill
    Navarre, FL
    I have never known a difference at all between the Tacoma and 4Runner bearings. The part numbers with Toyota are the same.
    Adding info, the part numbers are different, for some reason as Toyota replacement is showing KOYO for the 4 Runner, and NSK for the Tacoma. I only use KOYO on all of my assemblies and they are a universal fit.
    richardbui23 and DustStorm4x4 like this.
  11. Dec 7, 2016 at 10:47 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I know it's cheaper to replace just the bearings but so much simpler to just replace the whole hub assembly.
  12. Dec 7, 2016 at 10:51 AM
    BamaToy1997
    Bill
    Navarre, FL
    Perhaps a little more detail would be better? lol.
    Toyota has had their bearings come from Koyo since the beginning of Tacoma and the equivalent model 4Runner. Even the older design that was pressed into the spindle itself were manufactured for Toyota by Koyo. The newer design fits the following trucks:
    2005-2015 Tacoma (4X4)
    2003-2015 4Runner (4X4)
    2007-2014 FJ Cruiser (4X4)
    2003-2009 Lexus GX470 (4X4)
    2010-2015 Lexus GX460 (4x4)
    The 2WD units fit the following trucks:
    2003-2015 Tacoma Prerunner
    2003-2015 4Runner (4X2)
    2007-2014 FJ Cruiser (4X2)
    2003-2009 Lexus GX470 (4X2)
    2010-2015 Lexus GX 460 (4X2)
    However I have noticed a discrepancy with the 2003 Tacoma Prerunner, in that SOME of them evidently did use the older designed spindles with the bearing pressed directly into the spindle, so those models have to be visually checked to be sure.
    As for quality, Koyo does make the best assemblies. The problem, and the cause of failure is under several categories. the most common cause of failure is insufficient lubrication. The lubricant used really was not the best for this application, which generates a lot more heat than the factory bearing grease can handle. This results in premature failure for 2 reasons. One: Not enough grease results in lack of lubrication protection, resulting in early failure, and two: the low quality used would result in failure usually before the 60k mile mark. The next most common cause of failure is the inner seal at the CV axle allowing contaminants into the bearing chamber. Contaminants can include water, which when exposed to the high heat has been known to cause flash steam inside the bearing rollers. As you know steam is a VERY good cleaner, and will prevent the bearing grease form lubricating the bearing, causing quick failure.
    That information is not accurate. The FACTORY OEM bearing for the 4Runner, Tacoma, FJ Cruiser, and Lexus is Koyo. NSK, National, and other brands do make aftermarket bearings that are called "OEM" but only in the sense that the bearings are built to factory specifications and require no modification to install them.
    I would like to see the information supporting this. I have been dealing with the manufacturing plant for Koyo for many years, and there has been no changes to the manufacturing process for these specific bearings.
  13. Dec 7, 2016 at 10:55 AM
    BamaToy1997
    Bill
    Navarre, FL
    The whole thing with cheaper to replace just the bearing is subjective. Is the original hub still usable? If not, then it could add up fast. Typically a new Koyo bearing is about $90-100 including shipping. Add to that the cost of a new outer seal, o-ring, and possibly damaged hub, as well as press work at a shop (Unless you own your own press of course!) and the cost could easily match the replacement of the entire assembly. Some people do have a press, and they like the idea of doing it themselves. It's always awesome to fix your own stuff!
  14. Dec 7, 2016 at 10:57 AM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I always opt for easy rather than cheap. I do the same with CV boots. I usually just replace the whole thing rather than taking it apart.
    BamaToy1997[QUOTED] likes this.
  15. Dec 7, 2016 at 10:58 AM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    My first front wheel bearing that needed to be changed was the drivers' side, at approx. 290,000 miles. I'd say it lasted a pretty long time.
    Nickel and BamaToy1997 like this.
  16. Dec 7, 2016 at 11:03 AM
    BamaToy1997
    Bill
    Navarre, FL
    There are a LOT of people who do get a large number of miles on the factory bearing. My comments are mostly directed towards those that DO fail.
  17. Dec 7, 2016 at 11:16 AM
    BassAckwards
    Ive had three of my bearings fail prior to the 175k mark, with one at 208k and counting. Seems like theyre hit and miss as far as quality is concerned
  18. Dec 7, 2016 at 3:08 PM
    im4u2nvss
    Jesse
    2012 DC
    According to parts.tituswilltoyota.com there are different part numbers.
    3
    43570-04011 Bearing
    Front Wheel Bearing
    TACOMA
    $171.91 $121.33
    3
    43570-60011 Wheel Bearing
    Front Wheel Bearing
    4RUNNER(also same part number for FJ cruiser)
    $188.17 $132.81
    Also, looking at the ebay links where you can see the pics of items, both are toyota part numbers and box's and show pics of the replacement bearing(and show KOYO 4Runner NSK Tacoma). Now, I do not know if from the factory toyota installed KOYO on all and only sells NSK as a replacement for Tacoma? But, toyota does list a separate part number for both, and the 4Runner bearing costs more money. I can imagine Toyota would put the exact same part in both boxs(different part numbers), and sell one of them for a lower cost? Worst case, I will see when I pull my old hubs out and look. Just trying to do some research in advance.
  19. Dec 7, 2016 at 5:59 PM
    KRich
    KRich Well-Known Member
    BC, Canada
    07 Black DCSB TRD Sport 4x4
    Just had to replace the passenger side front bearing after having the driver side front done last year. I have 122,000 KM on the truck. I have had a lift and 285s with spidertrax wheel spacers on the stock rims for about the last 5 years. My truck barely sees the dirt and I'm feeling kind of burnt at the cost of doing these (not mechanically inclined enough to do it myself). I had a 93 4runner that I put through way more hell without these issues. Am I looking at having to do them both again any time soon? Don't think I can handle that especially when I'm going to have to shell out for new tires again in the next year or two. I don't want to be wincing when I go off road worrying about the bearings getting worn out.
  20. Dec 7, 2016 at 6:03 PM
    im4u2nvss
    Jesse
    2012 DC
    I believe most would agree that Toyota build quality is not what it once was. But, compared to the other newer options out there, I believe they are still the best choice. Forums like this one will save a person some serious cash. May need to brush up on your wrenching skills.
