4runner wheels on a tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03toytaco, Sep 3, 2010.
  1. Sep 3, 2010 at 11:40 AM
    03toytaco
    03toytaco [OP] New Member
    03 TRD Tacoma 4x4
    CAI
    I would like to know if I put 4runner/2nd gen tacoma wheels on my 03 tacoma will it fit properly? My tacoma has 16x7(265-70-16) with a +15mm offset and a 4runner/2nd gen tacoma is 17x7.5 with a +30mm offset. 265-65-17 is the choice of tires. Thanks in advance for any help
  2. Sep 3, 2010 at 11:43 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Yep
    I have 1st gen tacoma wheels on my second gen.
  3. Sep 3, 2010 at 8:56 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    It will depend on how wide a tire you mount on those 17's. They will be tucked in about 9/16th of an inch further than your stock wheels. 285's may rub on the UCA.
