4runner Will Not Turn Off
Discussion in '4Runners' started by taco52, Oct 13, 2016.
  1. Oct 13, 2016 at 7:31 PM
    taco52
    taco52 [OP] Well-Known Member
    01 SR5 v6 5speed 4x4
    Hello all,
    I just sold my first gen tacoma to pick up a 2002 4runner from my best friend. Today is the first day I have had it and when I got home from getting my license plates the truck wouldnt turn off. I had to pull my battery to get it to shut off.
    I have replaced the
    -Starter relay
    -Ignition switch
    The truck runs fine and drives great but will not shut off, no check engine codes. All the wiring behind dash looks to be in good shape. All fuses checked out.
    Im lost on what could have happened. Truck has 145k and is in excellent condition. Not sure what would cause such a problem.
    Any advice??
  2. Oct 13, 2016 at 7:40 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    man im curious about your predicament..
  3. Oct 13, 2016 at 7:40 PM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Ask your best friend?
    Benzdriver81 likes this.
  4. Oct 13, 2016 at 7:41 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    "Dieseling."
    DavidMietzner likes this.
  5. Oct 13, 2016 at 7:42 PM
    T4RFTMFW
  6. Oct 13, 2016 at 7:48 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Pull the ignition relay to see if that shuts it down. If it does, plug the relay back in, and see if it clicks when you do. If no click, replace relay. Not terribly common, but relays can stick on once the contacts burn a bit.
  7. Oct 17, 2016 at 7:15 AM
    taco52
    I tested the ignition relay. I ended up taking the throttle body off and attempting to replace the TPS sensor, but you have to purchase an entire throttle body to get a new sensor unless you source one from china in a bulk order or find one used. After I put the truck back together, everything worked as it should. I think its a stretch but the TPS sensor may be going bad and causing this. Its been two days with no problems since. Still uncertain of what the exact cause of this is
  8. Oct 18, 2016 at 7:34 AM
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    I had that problem in a 97 Land Cruiser. I replaced the starter and it stopped doing that thing. I thought it was the ignition key tumbler, or the wiring, or all sorts of things. I chose to replace the starter and it never did it again. It didn't make a whole lot of sense to me at the end.
    Hopefully you get it sorted out.
