4spd 2.7 Highway help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cedarpangolin, Oct 27, 2019.
  1. Oct 27, 2019 at 9:33 PM
    cedarpangolin
    cedarpangolin [OP] So country I bleed cedar sap.
    Christian
    2015 Tacoma Access Cab 4x4 2.7L
    1.5" wheel spacers, 2.5 front and 1" rear leveling kit, AFE Dry drop in filter, Thrush Glasspack Cherry Bomb exhaust, Falken Wildpeak AT3W tires Soon to be: bully aluminum side steps, plastidip emblems
    Hey guys, i need some insight and tips here. So this is whats going on:
    I just recently entered a serious relationship, and my girl lives four hours away, through a lot of mountainous interstate roads...
    2015 ACLB 2.7L 4spdAuto with 265/75/16 tires on alloys off a 2016, and a better flowthrough glasspack exhaust. Getting 21mpg on daily commute to work, having issues with mpg and gear selection at highway speeds....
    Im literally at wits end with the trip because although i can handle 18mpg going 70mph in a 4spd 4 banger, the constant shifts down to 3rd are driving me crazy because not only is it guzzling more gas when not necessary, but it for some reason wont upshift to 4th and OD again on its own most of the time. I can go over a mountain and it will take until halfway coasting down the other side to realize it can go down to OD, so i end up taking cruise off, and resuming to that it shifts at a reasonable time.
    What can i do? Can i do headers and a CAI to add maybe 10hp and will that be enough to hold 4th at least on average grades, instead of it dumping into 3rd and ramping up over 3200rpm?
    What do i do to fix the laggy upshift after breaching the crest of a mountain? Do i just keep manually stopping and resuming cruise to make it shift up?
    Finally, whats the best speed for these trucks with this drivetrain to get the best mileage and reasonable shift patters? i just spent over a hour searching old threads and all im getting is the same old "trade it in for a 4.0" and "dont use cruise" etc. Can i get some real answers from people with the same drivetrain?
    If a few performance mods and 10 or so hp boost would help hold 4th and OD instead of dumping to 3rd, that would be huge. Or if someone knows that speed this truck likes to cruise at that would be helpful for the gas conservation as well. Im putting on thousands of miles a month to see my girl, so 2mpg saved is a lot of money when im burning 50 gallons twice a week.
    One more thing: how feasible is a turbo or supercharger upgrade? im broke, and trying to save for a future with my girl, but if a turbo is an option for under 2 grand, i might consider it if it would help the powerband or cruising/mpg issues. Any thoughts and advice welcome.
    Thanks guys. This forum has made a huge difference with a lot of questions ive had! Keep being awesome.
  2. Oct 27, 2019 at 11:00 PM
    Wrench1225
    Wrench1225 Well-Known Member
    jim
    NY
    SR5 4x4 db cab sb
    Rock sliders,total skids,toytec3" lift w adjustable UCA's and O ME,leaf spring pack, w toytec 2.5 rear shocks,diff.drop andBF Goodrich A/T 275 70 R16 (spare fits nicely under bed) Ultra machined Wheels, front camera. Seat covers,Bed liner spray(can't put a scratch in it) currently pricing diff.lockers with heavy duty pumpkin gears. Lastly winch w low profile bumper
    You got a few options a) trade it in b) tell friend to move to flat lands c) what is the altitude of the mountains your going up? The 2.7 was designed to be a work horse.Not designed for cruise control on high mountainous regions. You could try bringing it to dealer and having them reprogram the ECU to accommodate your driving. It’s a shot in the dark but might be worth it.
    cedarpangolin[OP] likes this.
  3. Oct 28, 2019 at 8:02 AM
    cedarpangolin
    Christian
    Is the dealer reprogram even a possibility? I didn’t think that was even an option, especially since it has 6.5 years and 95,000 miles of drivetrain warranty left...
  4. Oct 28, 2019 at 8:04 AM
    cedarpangolin
    Christian
    How much of a difference is that really going to make with shift patterns and mpg though? If all it does it significantly reduce my off-road ability and don’t help the gear selection then it’s probably not worth it.
  5. Oct 28, 2019 at 9:02 AM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Yeah, I'm sorta'f in that situation with my 2013 reg. cab, 2.7, auto., 4X4. Except for me, the mpg. is not as important. I talked with my mechanic about changing my gearing & his first response was, lets see about reprogramming the trans. shift points. I don't understand how this may help, but I'll give him a chance. I hope you come up with something, but to me it seems anything that would help with your mph. will make the shifting problem worse. Good luck to the both of us.
  6. Oct 28, 2019 at 9:06 AM
    Wrench1225
    jim
    NY
    SR5 4x4 db cab sb
    Best you can do is ask them. I don’t see how any ECU air/fuel trim (aka volumetric efficiency) is going to significantly effect your off road capabilities. You have a second gen engine, therefore it was design to give you better torque at low RPM’s. Trimming your volumetric efficiency will make you run a little richer and it could help you out with cruise on the mountains. I mean you could change the thermostat to a cooler temp and probably get the same results without reprogramming anything. I have the 4.0 no problem with any mountain or hill in cruise control. Then again I don’t know the altitude of the mountains your driving on. Believe it or not that significantly effects volumetric efficiency.But to really see where the problem lies you would have to monitor the vehicles inputs an take a snap shot of these measurements while the symptoms are occurring.
    I’m just throwing ideas out there based on the repairs I’ve encountered on the 2.7 engine.
    I wish you luck and kindly keep me posted.I’m pretty sure one day someone else will pull into my garage with the same problem.
  7. Oct 28, 2019 at 9:09 AM
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    believe it or not, higher RPM in lower gear isn't necessarily burning more fuel. Although it makes more noise, the engine isn't working as hard to do the same amount of work.
    That being said, the 2.7 was never meant to win any races, it's engineered for torque and reliability, and it'll excel at both of those. A re-gear is most likely going to be your best next step.
  8. Oct 28, 2019 at 9:10 AM
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Don't bother with the thermostat, modern EFI engines don't care. You may actually force the engine to stay in open loop which causes it to run richer, making your fuel economy issues worse.
  9. Oct 28, 2019 at 9:15 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  10. Oct 28, 2019 at 9:16 AM
    BassAckwards
    I also agree with downsizing the tires to the 245/75/16s.
    That would be effectively regearing the truck just slightly, and the reduced mass will also give you a little performance back.
    BillsSR5 and LoveableWerewolf like this.
  11. Oct 28, 2019 at 9:21 AM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    Can't really do anything but it's supercharger. Cruise control is stupid in my truck will downshift for everything when if pedaled gently will pull great. Again, a workhorse, not a sprinter. Sorry for just confirming
  12. Oct 28, 2019 at 9:32 AM
    Wrench1225
    jim
    NY
    SR5 4x4 db cab sb
    Your probably right “WILL”. However, these vehicles are over geared as it is. Usually in my experience when cruise fails to shift, its a reprogramming of shift solenoids and cleaning them out or replacing them due to dirty tranny fluid.
    Not saying this is Cedar’s issue but not totally ruling it out either @95k for mileage. All I can do without seeing the vehicle is through things out there that I’ve come across and hope that the least costly works.
    LoveableWerewolf likes this.
  13. Oct 28, 2019 at 9:34 AM
    LoveableWerewolf
    Nashville
    Good point, I forgot how much better my shifting was after I did a good drain and fill
  14. Oct 28, 2019 at 11:56 AM
    cedarpangolin
    Christian
    Maybe I wasn’t clear - I have 95k remaining on my 100,000 mile warranty. I bought the truck this summer with 4,989 miles on it, four years old lol. It’s up to 8,650 miles now. It’s possible a tranny fluid drain and refill could be useful but I find it very unlikely there’s a fluid issue or a solenoid problem with such low mileage on the truck.
  15. Oct 28, 2019 at 11:59 AM
    cedarpangolin
    Christian
  16. Oct 28, 2019 at 12:05 PM
    BassAckwards
  17. Oct 28, 2019 at 12:06 PM
    BassAckwards
    This i am not sure of, sorry..
  18. Oct 28, 2019 at 12:08 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    1. Downshifting doesn't "use more gas than necessary". RPMs don't determine fuel usage.
    2. Is this not normal operation? No engine is going to traverse mountains without downshifting. Furthermore, does cruise control not intentionally hold lower gears on downgrades to keep speed under control?
    If you don't like the decisions made by autopilot turn off autopilot.
  19. Oct 28, 2019 at 12:08 PM
    nisno
    nisno Well-Known Member
    Trade it for a V6. I always thought that the modern Tacomas are just too big/heavy for a 4 cylinder, especially up hills. A manual trans helps a bit though. You are gonna spend money on NA power mods and they aren't gonna make that big of a difference. A supercharger gets you power but that ain't gonna help too much with fuel mileage.
    det107 likes this.
  20. Oct 28, 2019 at 12:10 PM
    Wrench1225
    jim
    NY
    SR5 4x4 db cab sb
    Sorry about that .I can’t reside myself to the fact that I need reading glasses. Now if this vehicle is still under warranty bring it to the Stealership and bitch ! Let them figure out what’s wrong with their puppy.
    det107 likes this.
