4speed auto not shifting into 4th when cold
Discussion in '4 Cylinder' started by DJR81, Sep 25, 2022.
  1. Sep 25, 2022 at 4:02 AM
    DJR81
    DJR81 [OP] Well-Known Member
    2013 5 lug 4 speed auto
    For a short period while truck is cold it seems to wanna hold 3rd gear ( at 40+ mph) when normally it would change to 4th. It only does this like the first 5 minutes of driving. Does anyone else’s 4 speed do this? Truck has 60k miles 2013 ( no hitch on when I purchased- owned by older gentleman). Hope it’s not early trans issue. Planning to do a drain and fill soon.
  2. Sep 25, 2022 at 6:10 AM
    Stelcom66
    Stelcom66 Well-Known Member
    2007 2.7L 5MT 4WD
    Most automatic transmission vehicles I've had would hold off locking directly, bypassing the torque convertor on the highway when it was cold. Meaning, the torque converter was still adding a higher (numerically) ratio, and a couple hundred rpm. After a few miles, the transmission would 'lock up' and rpms would go down a bit.
    Is it that, or is it really staying in 3rd gear? Not sure what the Toyota 4 speeds automatics characteristics are.
  3. Sep 25, 2022 at 11:53 AM
    DJR81
    leaving my neighborhood getting up to 40 or so (would normally be in 4th with light throttle) it holds 3rd for a while. May be normal I’ll see how it does after a drain and fill
  4. Sep 25, 2022 at 11:56 AM
    Bishop84
    Bishop84 Well-Known Member
    Normal, its just trying to warm up quicker.
    Fluid change is still a good idea.
    You're more likely to have delays going into drive or reverse with fluid issues, or 1-2 shifts. 4th is rarely a concern.
  5. Sep 25, 2022 at 12:19 PM
    Stelcom66
    2007 2.7L 5MT 4WD
    Is this truck new to you? I remember the first 4 speed automatic I had did that and I thought something may be wrong. Like Bishop84 said, normal. Some 4 speed automatics are aggressive to downshift with any slight incline or attempt to accelerate. I'd think this automatic wouldn't tend to do that, as the 4 cylinder has a decent amount of torque for a 4.
  6. Sep 25, 2022 at 12:20 PM
    DJR81
    Thanks that was my thought just warming up. Just an odd feeling on and off throttle when it would normally be in 4th and the truck revs out some since it’s still in 3rd going around 43 mph. Truck rarely gets above 2k rpm how I drive. No way this trans is having early issues though. this truck has been babied as far as I can tell
  7. Sep 25, 2022 at 12:21 PM
    DJR81
    I’ve had it over a year. Once it’s warmed up it shifts to 4th early
  8. Sep 25, 2022 at 12:27 PM
    Stelcom66
    2007 2.7L 5MT 4WD
    Sounds like it's fine then. I'm new to Toyotas, but do a lot of research. The transmissions on these trucks seem to have a good reputation.
  9. Sep 25, 2022 at 12:32 PM
    DJR81
    It’s doing it on flat ground but by the time I get down the road to the stoplight it’s back shifting normally. If it was doing it from 1st to 2nd I’d be more concerned. I had a maxima that did that and trans was going out
  10. Sep 25, 2022 at 2:16 PM
    arkie taco
    arkie taco Well-Known Member
    russ
    1988 4x4 pickup, 2013 tacoma 2.7 auto
    Tacoma wheels, lc header, cold intake
    My 2013 4cyl automatic does it sometimes in colder weather, 85,000 miles on it.
    DJR81[OP] likes this.
  11. Sep 27, 2022 at 4:50 AM
    Stelcom66
    2007 2.7L 5MT 4WD
    Seems normal with the 4 speed automatics. Don't know if the 6 speeds have the same tendency. I've heard unless you're on a level highway for a while, they tend to stay in 5th, at least with the 4 cylinder.
