.:-- 4th Annual KY/TN March 2016 Land Between the Lakes Meet--:.
Discussion in 'South East' started by allmotorrex, Dec 14, 2015.
  1. Mar 4, 2016 at 6:39 AM
    #1301
    rhion82
    rhion82 El Duderino
    Mitchell
    TN/GA
    16 Taco
    Here is you weekly update for the weather at LBL.
    Thu
    3/17/2016
    58° 33° 0.49 in 0 in [​IMG]Chance for rain; colder 60° 36°
    Fri
    3/18/2016
    54° 36° 0 in 0 in [​IMG]Partly sunny 60° 37°
    Sat
    3/19/2016
    57° 31° 0 in 0 in [​IMG]Mostly cloudy 60° 37°
    Sun
    3/20/2016
    60° 42° 0.26 in 0 in [​IMG]Sunshine 61° 37°
  2. Mar 4, 2016 at 6:40 AM
    #1302
    Breezy
    Breezy vaping in my subaru
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    I hope that forecast holds up!
    Bluegrass Taco and 11TRDTX like this.
  3. Mar 4, 2016 at 7:47 AM
    #1303
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
    Even if it is sunny while we're there, it's supposed to rain 3-5 inches the week leading up to LBL so there will be plenty of mud to go around.
  4. Mar 4, 2016 at 7:55 AM
    #1304
    allmotorrex
    allmotorrex [OP] Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Me too. Wow
    Bluegrass Taco likes this.
  5. Mar 4, 2016 at 9:17 AM
    #1305
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    Eww no.
    If that's the case I could see them closing due to it being too wet.
  6. Mar 4, 2016 at 9:21 AM
    #1306
    TacoBurrito07
    Jake
    Arizona
    They didn't close it last year with 6 inches of snow so hopefully not!
  7. Mar 4, 2016 at 9:26 AM
    #1307
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    I read something a few days ago on another site where a lot of the fire roads @ Red River Gorge were being closed until further notice due to wet conditions.
  8. Mar 4, 2016 at 10:37 AM
    #1308
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
  9. Mar 5, 2016 at 8:50 AM
    #1309
    rhion82
    rhion82 El Duderino
    Mitchell
    TN/GA
    16 Taco
    Finally installed my Dakar rears Thursday and after work today I plan on swapping cv axles and rear shocks.
    beertimecontinuum likes this.
  10. Mar 5, 2016 at 11:17 AM
    #1310
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    (Used) spare tire search was a bust. I went to 4 tire shops.... no one had anything. I guess I'll just go ahead and debead one this trip so i can get it over with.
  11. Mar 5, 2016 at 12:57 PM
    #1311
    lowinhz
    lowinhz Well-Known Member
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Billies@ 2.5, 2inch blocks, front hitch, xrc 8k winch on portable mount, 10 sub behind seat, Memphis amp, pioneer touch radio, cobra cb, 235/85/r16 duratracs with black rims, high lift jack, tint, remote start alarm, hella 500 lights, 59" curve led bar, snorkel, expo trailer with rat, car seat
    My last trip to royal blue I blew a bead and had to get it cleaned out.
  12. Mar 6, 2016 at 10:34 AM
    #1312
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    Just took my spare out from under the bed (never taken it down before :anonymous:) thinking about leaving it home since it's not full size now, or should I put it back up before the trip and have it anyway?
  13. Mar 6, 2016 at 10:53 AM
    #1313
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    Have it anyways! Can always put it in the front if one debeads for the trip home. To keep wheeling bead the full size tire back on the wheel and then when you get home debead it and clean it out and balance it and then it's good as new
    11TRDTX[QUOTED] likes this.
  14. Mar 6, 2016 at 10:59 AM
    #1314
    cy.hill
    cy.hill Well-Known Member
    Cy
    Nashville, TN
    2010 Barcelona Red Tacoma Access Cab
    Just got the CB installed. Hopefully it works... I have a lot of static, I have to have the squelch 3/4 of the way up to get rid of the static.
    TacoBurrito07 and 11TRDTX like this.
  15. Mar 6, 2016 at 11:14 AM
    #1315
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    How well is your system grounded?
  16. Mar 6, 2016 at 11:28 AM
    #1316
    cy.hill
    Cy
    Nashville, TN
    I have BAMF tailgate mount. I know the bed isn't the best for ground. And as far as power and ground for the radio I ran them both directly to the battery.
  17. Mar 6, 2016 at 11:29 AM
    #1317
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    Is either the mount or the antenna grounded?
  18. Mar 6, 2016 at 1:49 PM
    #1318
    cy.hill
    Cy
    Nashville, TN
    This is where I have it mounted and I checked with an ohm meter and it has a good ground where the metal is mounted.
  19. Mar 6, 2016 at 1:51 PM
    #1319
    TacoBurrito07
    Jake
    Arizona
    Interesting. I have mine mounted there as well. Similar mount but from a different company. I ended up running a ground wire from one of the bolts to the frame. My swr was above 3 (sometimes it said infinity) beforehand but now it is down in the proper range.
    cy.hill[QUOTED] likes this.
  20. Mar 6, 2016 at 1:55 PM
    #1320
    cy.hill
    Cy
    Nashville, TN
    I'm going to run a ground wire to the frame. Thanks for the advice.
