4th Annual TacomaWorld Rush Off Road Meat Sweats 2020
Discussion in 'Kentucky' started by dirty deeds, Jun 1, 2020.
  1. Aug 10, 2020 at 8:53 AM
    #1301
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    It'll do ya good
  2. Aug 10, 2020 at 9:46 AM
    #1302
    wink4x4
    wink4x4 Well-Known Member
    Kentucky
    2017 DCSB TRD Offroad
    Not hating, just wish it was beefier. Mine has definitely taken some hits, and it shows.
    beertimecontinuum likes this.
  3. Aug 10, 2020 at 9:46 AM
    #1303
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Tuned, geared, armored, BP51s...
    Alright, i got shit installed this weekend.... BP51's all around, brakes, rotors, brake lines, sway bar bushings and linkages, clutch, pressure plate and flywheel. WHEW!
    As long as nothing falls apart, expect to see me out there!
  4. Aug 10, 2020 at 9:51 AM
    #1304
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    Probably want to leave the sway bar at home. New suspension will be stiff enough you won't need it anymore anyway.
  5. Aug 10, 2020 at 9:53 AM
    #1305
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    That's the second time i've heard that actually....
    I'm going to keep it on for the next couple weeks at least. maybe the weekend i come down, i can ditch it and give it a whirl.
    Usually it's me, the gf, and 2 dogs in the truck loaded down and i'm not sure i want the risk. :notsure:
  6. Aug 10, 2020 at 9:55 AM
    #1306
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    What weight springs do you have? I'm being entirely unsarcastic about the shocks. Even with the weight of a steel bumper/winch on my front end, I could take corners pretty aggressively on 700# springs without significant body roll.
  7. Aug 10, 2020 at 10:00 AM
    #1307
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    I believe they're like 700lbs for the coilovers and about the same for the rear. I have a steel bumper, winch, and dual batteries up front. In a couple weeks i'll also have full 3/16" steel skids.
    I'll baby into it and find out :)
  8. Aug 10, 2020 at 10:02 AM
    #1308
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    Yeah give it a whack and see if you like it. You get better articulation offroad but if you hate driving it on road it will ultimately lead you to sell the truck for a Raptor. Pros and Cons.
  9. Aug 10, 2020 at 10:03 AM
    #1309
    dirty deeds
    dirty deeds [OP] Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Shoot me a PM with your name and arrival/departure days please.
    Sounds like you put in some serious work! Hope you had help or made someone else do it lol!
    This. All swaybars, after real suspension mods do nothing but inhibit your truck's ability.
  10. Aug 10, 2020 at 10:06 AM
    #1310
    dirty deeds
    Nick
    Eastern KY
    You should've just geared the Taco, if it wasn't for needing more interior space.
    You did keep your radio setup(s) and anything else that was easily removed, right? We should've swapped those baller ADS with one of 3 sets of suspensions I have in the garage. Among many other things.
  11. Aug 10, 2020 at 10:15 AM
    #1311
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    Well I pulled CB beforehand and gave Matt his radio back. Still on team handheld HAM. Probably order a permanent HAM for Blue
  12. Aug 10, 2020 at 10:19 AM
    #1312
    Summers_Kytaco_19
    Summers_Kytaco_19 “I did that in 2wd” rdpoe
    Steven
    Independence, KY
    19 trd OR tacoma
    I told him that on FB earlier :rofl:
  13. Aug 10, 2020 at 10:54 AM
    #1313
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Will do - let me get a few things in line first.
    Haha i had some help, but it took about 24-26 hours total
  14. Aug 10, 2020 at 11:10 AM
    #1314
    fleckosaurus
    fleckosaurus Certified Toyota Enthusiast
    Brian
    Versailles, KY
    2024 Tundra
    Finally ordered a CB antenna, bracket, and cable so I can install the radio that @mwc273 sent me several ages ago. :wave:
  15. Aug 10, 2020 at 11:19 AM
    #1315
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    2019 TRD OR DCLB (Sold), Honda Civic TRD PRO
    Samezies. No sway for over a year and no second guesses
  16. Aug 10, 2020 at 12:43 PM
    #1316
    dirty deeds
    Nick
    Eastern KY
    I'm happy with handy HAM. The somewhat overpowered units (for handhelds) we have are quite adequate for most things we do. My boosted CB is equally as amazing, squashes stock units!
  17. Aug 10, 2020 at 12:45 PM
    #1317
    dirty deeds
    Nick
    Eastern KY
    No problem. I'd just like to get a somewhat complete list to them at least a week before.
    I fully expect ~5 people to back out in the next couple weeks. Happens every time, at every meet across TW.
  18. Aug 10, 2020 at 12:47 PM
    #1318
    dirty deeds
    Nick
    Eastern KY
    Be sure whatever you mount the antenna's bracket to has a solid ground. Or run an independent ground cable from it. My bracket has its own ground because it's painted which is mounted to another painted/coated surface.
    Also, run the radio as direct to battery as possible. This cuts down on interference.
    Someone probably needs to bring a SWR meter if the radio doesn't have a built-in.
  19. Aug 10, 2020 at 12:51 PM
    #1319
    Summers_Kytaco_19
    Steven
    Independence, KY
    19 trd OR tacoma
    THIS! Definitely want the antenna very well grounded. I’m wired straight to battery and still get to much interference. Guess that’s the price I pay for running a big radio
  20. Aug 10, 2020 at 1:31 PM
    #1320
    dirty deeds
    Nick
    Eastern KY
    Any coils in the cable to/from antenna? Running parallel to active power cables on the frame for more than, say, 10'?
    I'm running this: https://www.ebay.com/itm/NEW-CB-RAD...NNA-BLACK-18FT-COAX-MOUNT-SPRING/172533562117 but with a different mount bracket. 18' of coax was just enough to go from the driver tail light/bed corner and into the center console in front of my shifter. No coils.
