4th Annual TacomaWorld Rush Off Road Meat Sweats 2020
Discussion in 'Kentucky' started by dirty deeds, Jun 1, 2020.
  1. Aug 20, 2020 at 12:57 PM
    #1561
    JohnnyRed
    JohnnyRed Well-Known Member
    Northern Kentucky
    2008 DCLB TRD Sport
    If it's not too late....I would recommend trimming your fender liner as little as possible. Heat & mold it away from rub spots. What you've done looks like minimal trimming compared to some.
    Fender liners are one of the few defenses from water getting in the intake.
    beertimecontinuum likes this.
  2. Aug 20, 2020 at 12:58 PM
    #1562
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Tuned, geared, armored, BP51s...
    Yeah it's pretty bad. I'm folding back both pinch welds too, the bottom horizontal one and the vertical one. It's a bitch to swing a sledge in here. I thi k I've made some good progress
    I'm a little worried about this huge hole and getting water up there
  3. Aug 20, 2020 at 1:04 PM
    #1563
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    I may have gotten too head over heals with the Dremel lol. Might be looking at a new liner and a second go around!
  4. Aug 20, 2020 at 1:45 PM
    #1564
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    Just fill the holes with spray foam. Ez pz
  5. Aug 20, 2020 at 1:50 PM
    #1565
    dirty deeds
    dirty deeds [OP] Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Pulled my liners completely. I might try to fit them back in, maybe not. Their only benefit at this point on my truck, it stopping water/debris coming into the door hinge area.
    This is very highly likely my answer/solution!
  6. Aug 20, 2020 at 2:01 PM
    #1566
    JohnnyRed
    Northern Kentucky
    2008 DCLB TRD Sport
    That's not too bad. I've seen much worse. Probably will get some water coming in the pinch weld. Your intake should be fine. If you cut more I'd begin to cringe if I saw you enter a mud hole at WOT.
  7. Aug 20, 2020 at 2:05 PM
    #1567
    JohnnyRed
    Northern Kentucky
    2008 DCLB TRD Sport
    Just make sure you fill the hole behind this little black knob thing. That's the important one.
  8. Aug 20, 2020 at 2:17 PM
    #1568
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Is there some sort of super thick black smear coating I can line the wheel well with? Something that can fill in some of the 1/2" hole?
    I frequently do deep water and sometimes deep mud
  9. Aug 20, 2020 at 2:26 PM
    #1569
    JohnnyRed
    Northern Kentucky
    2008 DCLB TRD Sport
    Which holes are you talking about?
    The red is the area below you may have an issue with. Also the pinch weld commonly separates, or cracks from the body on the back side. You can spread 3M seam sealer all over it and that will fix the issue. The green circle is nothing to be concerned about, that's only an attachment point for your fender liner.
    Here's a link to a good seam sealer https://www.amazon.com/dp/B000Y89JC8/
    beertimecontinuum and b3itz like this.
  10. Aug 20, 2020 at 2:33 PM
    #1570
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    I'm more talking about that foam block in my door. I should either replace my wheel well plastic bit to cover that, or I was thinking I could use some super thick coating to seal it up.
    Either way, I already have a fucked up fender and door I need to replace lol
  11. Aug 20, 2020 at 2:59 PM
    #1571
    dirty deeds
    Nick
    Eastern KY
    Huh?
    4 cylinder, so intake inside the fender is different. I do have holes in the bottom of the air box, drainage for water, undecided to seal them up.
  12. Aug 20, 2020 at 3:01 PM
    #1572
    JohnnyRed
    Northern Kentucky
    2008 DCLB TRD Sport
    Oh. That must be a 3rd gen thing. Looks like it's maybe just for sound deadening. I think it would be fine but I don't know.
  13. Aug 20, 2020 at 3:01 PM
    #1573
    JohnnyRed
    Northern Kentucky
    2008 DCLB TRD Sport
    That's the intake hole for the v6. You 4 bangers must be wired
  14. Aug 20, 2020 at 3:07 PM
    #1574
    dirty deeds
    Nick
    Eastern KY
    Had to get a rubber 4" to 3" adapter for the snorkel to air box junction. Inside the fender I'll lose about 3lbs of plastic, you'll see what I mean...
  15. Aug 20, 2020 at 3:09 PM
    #1575
    JohnnyRed
    Northern Kentucky
    2008 DCLB TRD Sport
    I'm not sure I want to see your 3"-4" rubber...
  16. Aug 20, 2020 at 3:14 PM
    #1576
    dirty deeds
    Nick
    Eastern KY
    Girthy :thumbsup:
  17. Aug 20, 2020 at 3:16 PM
    #1577
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Lol
    My intake is passenger side and there is no intake vent in the wheel well on the 3rd gens
  18. Aug 20, 2020 at 4:49 PM
    #1578
    dirty deeds
    Nick
    Eastern KY
    Correct, looks exactly like what @JohnnyRed posted in there. 2nd gen v6 are same.
    Idk what the 3rd 4 banger has. Mine has a horn pointed upward, but between it and the air box, is some big ass plastic cavity. Something like a collector/velocity/turbulence thing. I'm sure it's emissions related, don't need that noise!
  19. Aug 20, 2020 at 5:41 PM
    #1579
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    2019 TRD OR DCLB (Sold), Honda Civic TRD PRO
    What the hell is going on in here?!
  20. Aug 20, 2020 at 5:44 PM
    #1580
    JohnnyRed
    Northern Kentucky
    2008 DCLB TRD Sport
    Just talking about modding trucks. You should try it and stop driving that stock heap.
