4th fuel pump fail
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Turbo45, Nov 30, 2016.
  1. Nov 30, 2016 at 7:35 PM
    Turbo45
    Turbo45 [OP] Member
    British Columbia
    2010 Tacoma 6 speed
    Hi there I have a 2010 doublecab v6 six speed with about 291000k on it
    The check engine light came on the other day and it is a lean misfire code
    Everytime this code has came up it has been a fuel pump issue including the original pump this is the 4th one to fail
    This last one went for less the 30000kms
    Any ideas what is killing them?
    I made sure to always gas up before the light came on with this pump
    And still fail
    The fuel tank looks perfectly clean inside
  2. Dec 1, 2016 at 5:58 AM
    Larueminati
    Larueminati Well-Known Member
    Western MA.
    2013 DCSB TRD 0FF-ROAD
    Minor detail but do you let the pump turn off before starting the truck? You can hear it run for 5-10 seconds then turn off.
  3. Dec 1, 2016 at 7:06 AM
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    Clogged fuel lines or filter in the tank causing the pump to work too hard?
    kgarrett11 likes this.
  4. Dec 1, 2016 at 8:56 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Do you keep replacing the fuel pump with an OEM one?
    Have you swapped out the fuel filter, not the sock, ever?
    Mush Mouse likes this.
  5. Dec 1, 2016 at 9:56 AM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    What is the code? Who is replacing the pump? And as Torspd asked, if you are not using oem, then go that route. I have had many vatozone and napa pumps fail on my older tacos and 4runners, going back to oem and no issues again.
  6. Dec 1, 2016 at 10:00 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    do you let your tank run all the way down, do you always fill at the same place?
  7. Dec 1, 2016 at 10:01 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    ?? 2nd gens have a filter other than the sock??
  8. Dec 1, 2016 at 10:22 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Just out of curiosity do you have any symptoms other than a light popping on?
  9. Dec 1, 2016 at 10:24 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    You ever check fuel pressure? That would tell you if it's the pump or something else.
    Why wasn't this the first thing asked/addressed?
    Toyko Joe likes this.
  10. Dec 1, 2016 at 10:26 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yes. Sock, pump, then the filter surrounds the pump. It is fairly large. Compared to the size of the pump. Doesn't mean it won't get all clogged up, and cause undue stress on the pump though.
    This is why I am such a vocal advocate for telling people to upgrade the oem pump to one from URD. since it move the filter externally, and gives you a larger/better pump.
    Crom likes this.
  11. Dec 1, 2016 at 10:29 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Unless they changed something since 2006. Mine was a bare pump, with the sock hanging off the bottom laying flat along the bottom of the tank. I also recommend and replaced mine with a URD pump!
    Crom likes this.
  12. Dec 1, 2016 at 11:46 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Nope. It is there. It just blends in with the housing. The pump plugs directly into the filter, then the corrugated fuel feed line comes out of the filter.
    I should have a picture of it in the URD fuel pump installation manual, at home. See if I can find a picture of it which can be cross referenced from the one on Google.
    Mine is a 2006 as well.
    Crom likes this.
  13. Dec 1, 2016 at 11:50 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Here we are. The filter is in the first picture, on the right. It completely engulfs the pump.
    The fuel pump sock is in the second picture.
    Crom likes this.
  14. Dec 1, 2016 at 11:58 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    How long between pump failures? You sure it's not something else that's intermittent and you just keep clearing the codes, changing the pump, then a little while later the code comes back because the real problem wasn't fixed?
    Sandman614 likes this.
  15. Dec 1, 2016 at 12:04 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    I replaced mine with an Denso brand from Rockauto never had a problem
  16. Dec 1, 2016 at 12:09 PM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    You have a code - is there any driveability issues or does it run fine otherwise?
  17. Dec 1, 2016 at 4:23 PM
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    Heard their might be a bad wiring harness or issues.Dealer replaced mine with a new harness.Check your connections from end to end.Mine was with new frame etc...let us know what the harness,connectors look like.good luck.
  18. Dec 1, 2016 at 8:41 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    No, they don't.
  19. Dec 1, 2016 at 8:47 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Tell him..
  20. Dec 1, 2016 at 9:17 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yes chaps. They do.
