4th fuel pump fail
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Turbo45, Nov 30, 2016.
  1. Dec 2, 2016 at 8:36 AM
    #41
    Twalt87
    Twalt87 Well-Known Member
    Travis
    Vancouver island Bc
    I have a dodge one here about to go in the trash can i can show you, its virtually the same thing. Paper filter inside a sealed white canister. If you want i can break that one open and get pics
  2. Dec 14, 2016 at 9:41 AM
    #42
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Going to share this. There are still so many people on this forum and others which believe that there is either no fuel filter or that it should never be changed. I am about to do an intank fuel filter change on my mother's car. So I looked up a video of how to.
    2009 Hyundai Sonata w/108k miles on the filter, in the video. This is how filthy it looked. Her's with 130k, if never before changed, should look the same.
    All that is relevant because the same applies to the OEM Tacoma fuel filters. Which will also stress a pump.
    KTM753 and XPOTRPR like this.
