4th Gen 4Runner Questions
Discussion in '4Runners' started by brutalguyracing, Jan 28, 2014.
  1. Jan 28, 2014 at 3:57 PM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    so i am picking up a 2003 limited 4Runner tomm......it has 81k on odo
    questions......will my king coils from my 09 tacoma work on the 4 runner?
    what other parts if any are interchangeable ?
    i need skids, sliders, bumpers...cv's,
    timing belt and water pump i think
    how hard is the timing belt to change
    does the water pump need to be replaced at 90k also?
    what else should be done?
    rear diff breather mod?
    im looking to go 33's and lift it?
    i also have a slight belt chirp i will have to look into.....
    let the fun begin.....
    any tips or advise is welcome......
  2. Jan 28, 2014 at 4:18 PM
    Buckles
    Buckles Well-Known Member
    Texas
    2017 TRDOR
    This site will be your best friend. I believe the coilovers should work, but you probably want to double check.
    I know some FJ suspension works on the 4Runners.
    There are a lot of things that are interchangeable. Timing belt and water pump is a pretty time consuming job, if you have the tool and know how, it shouldnt be too bad. Im pretty sure that they recommend to do both at the same time. At least you might as well since most of the same parts need to come off.
    Are you getting a 4.7 or 4.0?
    Rear breather mod is easy, and should be done if you plan on playing around any water.
    You should be able to clear 33" with a modest lift and the right wheels.
  3. Jan 28, 2014 at 4:31 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    ITS A 4.7....
    AND THATS WHAT I THOUGHT ABOUT THE TIMING BELT AND WATER PUMP
    :thumbsup:
  4. Jan 28, 2014 at 4:36 PM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    Glad you made out man!
    That V8 will be nice :cool:
  5. Jan 28, 2014 at 4:54 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    :thumbsup::D
  6. Jan 28, 2014 at 7:46 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    im running coilovers that were off a tacoma. They're completely interchangeable in that regard.
  7. Jan 28, 2014 at 7:53 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    Sweet
    What about tre's
    Cvs
    Spindles
    Wheel bearings
    Lca's
    All the same
  8. Feb 2, 2014 at 5:56 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    So for my rear lift im thinking ome 896's with ome 60004 shocks
    Any thoughts
    I carry around lots if weight and plan on tire carrier in rear
  9. Feb 2, 2014 at 6:01 AM
    Large
    Large Red
    The rear is IRS right?? Not a solid axle?
  10. Feb 2, 2014 at 6:21 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Pretty sure it's coils on a solid axle. The wife's 2004 is...
  11. Feb 2, 2014 at 8:59 AM
    Buckles
    Texas
    2017 TRDOR
    its a solid axle rear with coil springs. Some have the option of air suspension too.
  12. Feb 2, 2014 at 1:59 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    vvvv
    THIS
    THIS
    I HAVE TONS OF QUESTIONS
    i need to redo my instrument lights as some are burnt out.....
    Ok i have a 03 limited and i have a bunch if questions i could use help with
    I am a former 2nd gen fully modded tacoma owner
    But i am still learning the 4runner
    Ok for the question
    1......I will be installing some king coils 700lb spring ext travel up front
    Can i ditch the sway bar like i did on my taco
    2.....any storage ideas for tools and parts and such or are you guys just using tool bags
    3.....can i remove the side grab handle and pilar plastic without airbags going off
    Here is a pic of what i want to remove to hardwire my ultragauge and gps
    4..... Any problems using an ultragauge on a 4th gen
    5.....is there any way to open rear hatch from inside
    Id love to be able to open it from inside
    6...... Keys and key fobs
    What are you guyz paying for a new key cut
    $80 for key here.... And i would another key fob?
    What do they run and where can i get them
    7......anyone running 315-70-17's
    On a 3"
    Thanks in advance
  13. Feb 2, 2014 at 2:04 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    Also anyone here running oba setup
    If so post up your sysyem
  14. Feb 2, 2014 at 2:33 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    1. You can. There is more body roll from the 4R than my Taco...but you could do it of you wanted.
    2. There are drawer set ups and molle packs out there for the cargo area....depending on your goals for the rig.
    3. I think if you disconnect the battery and be gentle - Should be good
    4. None-Wife loved hers...Till I stole it.
    5. Don't think so...
    6. & 7. No clue.
  15. Feb 2, 2014 at 2:42 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    OK, here you go, toyota120.com is a great resource:
    See pic of storage box. I plan to revamp with a pressure switch, new compressor and a tank soon.
  16. Feb 2, 2014 at 2:44 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Yup, front suspension and steering is identical between FJ, 4R and Taco.
  17. Feb 2, 2014 at 3:05 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    thanks
    and lol
    sweet thanks i need so many ideas....
    everything is so much more expensive then my tacoma:eek:
    lca's are exactly the same too?
    rock auto has diff part numbers for them and lbj's as well.....
  18. Feb 2, 2014 at 3:48 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Pretty sure, check out Total Chaos, they list all 3 models for the same LCA. When I did my LBJs I followed a write up on TW and used the taco part numbers.
  19. Feb 2, 2014 at 4:19 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    this is what im hoping for
  20. Feb 3, 2014 at 5:43 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    So i am thinking if picking up an PIONEER avh-x4500bhs for my 2003
    It has a jbl radio in it now
    Does anyone know what i need to install it wire and cable wise
    CRUTCHFIELD WEBSITE CALLING FOR'
    1....Axxess ASWC-1
    Steering wheel control interface — connects your car's steering wheel audio controls to an aftermarket stereo
    $80
    2.....Metra 70-8117 Factory Integration Adapter
    Connect a new car stereo and bypass the factory amplifier in select 2003-07 Toyota vehicles
    $25
    3.........Metra 95-8210 In-dash Receiver Kit
    Fits select 2003-09 Toyota 4Runner models — double-DIN radios
    $FREE
    4.....Axxess AX-ADBOX1 Factory Integration Adapter
    Connect a new car stereo and retain many factory functions in select 2000-up vehicles
    $100
    5.....PAC TATO Factory Integration Adapter
    Install a new car stereo and retain your JBL amp, balance and fade controls, and Synthesis® surround systems (2003-up Toyota and Lexus vehicles)
    $38
    WHAT ELSE WOULD I NEED.....
    ALSO I PHONE 5 CABLE?
    BYPASS?
