4th gen - aftermarket wheel and tire pics
Discussion in '4th Gen. Tacomas (2024+)' started by deaps, Feb 25, 2024.
  1. Mar 18, 2025 at 10:51 AM
    #301
    Reefencounter
    Reefencounter Active Member
    2024 TRD Off Road LB 4x4
    OEM TRD Pro 18x8.5 wheels / 20 mm offset and 265/70r18 GY Wranglers. No lift.
    Jacob06, Siblue, Burns and 5 others like this.
  2. Mar 18, 2025 at 3:32 PM
    #302
    swordfish
    swordfish Well-Known Member
    Jon
    CT
    ‘25 MT6 Off-Road
    Tires, bizarrely enough, are a very organic feature of vehicles. And by that I mean, there are massive differences between manufacturers and models and wheels and air pressure and lug patterns and vehicle weights and alignment and… There are so many different variables that it makes your teeth ache when you’re trying to figure it out.
    Basically the metric or LT sizes are akin to old guys explaining fish they caught. It’s a standard explanation of the size but going to the manufacturers website (or tirerack) will give you the actual height and tread width and circumference.
    Rover31 and PDKTaco like this.
  3. Mar 18, 2025 at 4:46 PM
    #303
    Reefencounter
    I used this toolset... gets you what I believe is a pretty good calculation of what combo you might be looking at. You can also zero in on the comparison by going to the tire manufacturer website to look at their detailed specs.
  4. Mar 22, 2025 at 10:31 AM
    #304
    Panda._Taco
    Panda._Taco Member
    2024 Toyota Tacoma TRD Off-Road Premium
    Stock suspension
    Wheels: 17x8.5 +35 Offset
    Tires: 285/70R17
    Streekhawk, 6starwars, Burns and 4 others like this.
  5. Mar 22, 2025 at 4:43 PM
    #305
    Taco Ji
    Taco Ji Well-Known Member
    New Jersey
    2025 TRD OR - Hybrid Bronze-Oxide, Premium PKG.
    Looks good. No rub on full locks?
  6. Mar 22, 2025 at 6:23 PM
    #306
    Panda._Taco
    Panda._Taco Member
    no rubbing.
  7. Mar 22, 2025 at 6:51 PM
    #307
    Malore
    Malore Well-Known Member
    Oregon
    '25 Celestial Silver Metallic Tacoma TRD Off-Road
    Wowwwwww. Looks so good. Thanks for reassuring me that +35 offset looks damn good. Wheels are on back order, but this gives me faith I made the right call.
  8. Mar 22, 2025 at 7:34 PM
    #308
    Panda._Taco
    Panda._Taco Member
    Oh yeah, you should be good on the +35 offset. It still has some poke to it.
  9. Mar 23, 2025 at 3:41 AM
    #309
    Taco Ji
    New Jersey
    Can you take a photo of the front and rears. I want to see how much poke you get with +35. Thank you.
  10. Mar 23, 2025 at 8:13 AM
    #310
    Panda._Taco
    Panda._Taco Member
    I hope this helps
    Malore and Taco Ji[QUOTED] like this.
  11. Mar 23, 2025 at 8:28 AM
    #311
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    That means you are a follower... you aren't a leader. I don't copy from others for the truck looks. Just I get the items based on WHAT I NEED. I got the wheels for off road uses which means I don't care if they get scratches from trees or rocks. I plan to get other set of wheels for street uses later whenever I get too old to go off road..
  12. Mar 23, 2025 at 8:41 AM
    #312
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    He was one of the first to get the new truck and post about it here. And push back against the haters of which there were quite a few in the beginning. I am grateful for the early info/feedback as any others offered in goodwill.
    heyisleep, LN13, Malore and 1 other person like this.
  13. Mar 26, 2025 at 9:29 PM
    #313
    Malore
    Oregon
    Looks absolutely perfect. Stoked! Thank you!
  14. Mar 27, 2025 at 3:14 AM
    #314
    Taco Ji
    New Jersey
    I was hoping for direct center photo so I can see the poke of the rear tires in both sides. Thanks!
    Jacob06 likes this.
  15. Mar 27, 2025 at 10:44 AM
    #315
    lundy
    lundy Well-Known Member
    Justin
    Reno, NV
    2023 Double Cab 4x4
    17x8.5 +00 285/70R17 ModCo M72 Machined
    HLSATRK, Burns, BearWithMe and 2 others like this.
  16. Mar 27, 2025 at 10:54 AM
    #316
    Taco Ji
    New Jersey
    Was this one lifted or on stock suspension?
  17. Mar 27, 2025 at 12:26 PM
    #317
    lundy
    Justin
    Reno, NV
    2023 Double Cab 4x4
    @Taco Ji customers truck but I believe it's just leveled. 285/70R17 just looks small on these 4th Gens.
  18. Mar 27, 2025 at 12:54 PM
    #318
    WHSKYFSH
    WHSKYFSH Active Member
    Sean
    2024 White Tacoma TRD OF
    Sleeping platform, 1Up
    Went with Trailhunter wheels.
    naptownjoe, max911, 6starwars and 5 others like this.
  19. Mar 28, 2025 at 9:50 PM
    #319
    cstforesthill
    cstforesthill New Member
    25 TRD OR
    Looks perfect! If you don’t mind me asking, what tires are you running? Can’t quite make it out from the pics. Thanks!
  20. Mar 28, 2025 at 9:52 PM
    #320
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Looks like Falken Wildpeaks
