4th gen door or door panel rattle
Discussion in '4th Gen. Tacomas (2024+)' started by laocie, Apr 27, 2025.
  1. Apr 27, 2025 at 6:28 PM
    laocie
    laocie [OP] Member
    2025 4x4 SR5 Tacoma, TRD 2 inch suspension and TRD exhaust
    The other fourth gen owners have an issues with the door or the door jam rattling? It seems like I have to slam the door shut for it to not happen. If it does start happening, sometimes I can actually open it and then slam it shut and it goes away for a little while.
  2. Apr 27, 2025 at 7:05 PM
    Yoda's TRD
    Yoda's TRD Well-Known Member
    David
    Haslett, MI
    2025 TRD Sport Hybrid
    I’ve noticed some times that the seat belt buckle on the passenger side (when I don’t have a passenger) will rub and make a rattling noise- could that be it?
  3. Apr 27, 2025 at 7:13 PM
    laocie
    laocie [OP] Member
    I wish. Because I also have issues with the seat belts too. It’s the door or door panel. Mostly on the driver side. It like it isn’t latched all the way and vibrates.
    Yoda's TRD[QUOTED] likes this.
  4. Apr 27, 2025 at 9:06 PM
    laocie
    laocie [OP] Member
  5. Apr 28, 2025 at 2:35 AM
    Taco Ji
    Taco Ji Well-Known Member
    New Jersey
    2025 TRD OR - Hybrid Bronze-Oxide, Premium PKG.
    I don’t know about the door panel rattles as mine is solid for now but you guys can apply Velcro felt on the panel where the seatbelt hangs to stop it from hitting it.
    Yoda's TRD likes this.
  6. Apr 28, 2025 at 9:19 AM
    TacomaBuyerBC
    TacomaBuyerBC Member
    I have what sounds like a ping pong ball dropping in my driver side B pillar right under the seat belt assembly. It happens more consistently over rougher roads but I have not been able to narrow it down.
    The dealership said they have heard it before and had reports of it but no resolution steps yet. It is definitely something inside the seat belt assembly within the b pillar.
  7. Apr 28, 2025 at 9:24 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    that guy talks alot about nothing...
    yetisb likes this.
  8. Apr 28, 2025 at 10:36 AM
    laocie
    laocie [OP] Member
    Kind of wondered if it was the b pillar.
  9. Apr 30, 2025 at 9:28 PM
    LWM2024SilvOR
    LWM2024SilvOR Member
    My passenger door had a rattle that would come and go. Sometimes bumps in the road would initiate it or make it go away. I slid the piece of trim with "TRD" on it off and there is a screw underneath which was loose. Took about 6 turns to tighten down that solved the problem! Maybe this could be your issue too?
