4th Gen MT Third Gear Snag
Discussion in '4th Gen. Tacomas (2024+)' started by tms90, May 11, 2024.
  1. May 11, 2024 at 6:52 AM
    tms90
    tms90 [OP] Member
    2024 SR MT
    Noticing third gear on my 24 MT SR is a bit “catchy”, almost like there is a snag or groove between the channels of 1st and 3rd the shifter gets hung in. I’ve sort of gotten used to being more precise shifting to third but sometimes I hit the snag and it doesn’t shift into third right away. I let my buddy take it for a spin and we were stuck in heavy traffic because he couldn’t figure out how to move it to third because of this snag spot, and thought it was weird.
    It’s kind of similar to when I first bought it, I was pulling the shift too far left to go into second and missing the 2nd gear channel basically putting the shifter somewhere between first and reverse and cannot shift to second from that point. That one isn’t an issue for me now since I’ve gotten used to it.
    In another unrelated forum I was reading this can be a symptom of a bad synchro.
    wondering for the other 4th gen MT owners have. you’ve noticed the same? Assuming it doesn’t get worse, I’ll ask Toyota about it on my first service.
    HondaGM likes this.
  2. May 11, 2024 at 6:55 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    It’s best to get it documented by the dealer..so if later on down the road something does happen you have a complaint
    SH10151 likes this.
  3. May 11, 2024 at 7:10 AM
    tms90
    tms90 [OP] Member
    2024 SR MT
    Dumb question but is this somthing I need to take it into them for or should I just send an email or use the service app?
    HondaGM[QUOTED] likes this.
  4. May 11, 2024 at 7:19 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Are u fully engaging the clutch ? Sometimes when the clutch is new it needs to be fully engaged to properly shift over time it should loosen up a bit . If it continues on have dealer diagnose it .
  5. May 11, 2024 at 8:52 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    I would mention it on your first oil change…that way it will be documented
  6. May 11, 2024 at 9:39 AM
    Tehkoema
    Tehkoema Well-Known Member
    Ottawa, ON
    2024 TRD Sport 6MT
    Just drove my new 6MT this morning and practiced a lot. I do not notice a snag so much but I was taught to let the shifter normalize itself and then push it past the gate for 3rd and 4th.
    Sometimes going down to 2nd I find myself getting lost and needing to reattempt but I'm also new to stick.
    The characteristics I am noticing right now that I want to get a second opinion on is a louder driveline thunk going from 1st to 2nd. My shifting is still novice so I had my dad give it a try and he wasn't bothered at all so not sure if this is just me coming from auto.
  7. May 11, 2024 at 9:46 AM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    I would not wait until 10k miles.
    shakerhood likes this.
  8. May 11, 2024 at 10:51 AM
    tms90
    tms90 [OP] Member
    2024 SR MT
    I also have a clunk from first to second, not sure if it’s normal or not, been 8+ years since my last stick, but I think my last may have had it too.
    Tehkoema[QUOTED] likes this.
  9. May 11, 2024 at 8:40 PM
    GBR
    GBR Well-Known Member
    19 TRD OR
    3rd gear syncros on mine (2019) were a bit picky when new. More miles, like 15,000, and a fluid change mostly cured it. It doesn't sound like this is what you're talking about though.
    When shifting from 2nd to 3rd try letting the shift lever do most of the work. As in you're just popping it out of 2nd into neutral and up to 3rd, but in a continuous fluid motion.
    MOC221_ and Tehkoema like this.
  10. May 11, 2024 at 11:20 PM
    linuxpickup
    linuxpickup Well-Known Member
    2024 OR MT
    I've noticed 1st to 2nd is clunkier. Not obnoxiously so but I definitely feel it more than all the remaining upshifts.
    Tehkoema likes this.
  11. May 12, 2024 at 3:02 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    It needs to break in a little bit. My 3rd gen was the same way (very similar transmissions) and it took a while for 3rd to click in right.
    MOC221_ and tms90[OP] like this.
  12. May 12, 2024 at 7:20 AM
    tms90
    tms90 [OP] Member
    2024 SR MT
    Good advice thanks I'll give it some time and mention it at the 10,000 mile change. I am able to work it because i'm driving it everyday so have learned the temperament. But I also need my wife to be able to drive the truck on occasion, and since she doesn't drive stick regularly this will be a big put-off. Will keep an eye on it, also only at ~1000 miles. Thanks!
  13. May 13, 2024 at 9:22 AM
    ericin1984
    ericin1984 Well-Known Member
    2023 TRD OR Auto
    That is a sure sign of a bad synchro.
    SH10151 likes this.
  14. May 13, 2024 at 9:23 AM
    Northerntaco69
    Northerntaco69 Well-Known Member
    2023 TRD Offroad 6MT dcsb
    Trd pro grill, blackout overlays, black tailgate inserts
    My 23 does it too going to 3rd. Takes a bit to get used to it. Now I don't notice it anymore
  15. May 13, 2024 at 9:27 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    Or TO bearing.
  16. May 13, 2024 at 11:43 AM
    ericin1984
    2023 TRD OR Auto
    I don't know about the throwout bearing. Why would it only affect 3rd and not every gear?
  17. May 13, 2024 at 11:51 AM
    oneikr
    oneikr Well-Known Member
    2024 GMC Sierra 1500 Denali
    I used to have to double clutch when temps were really cold. Got used to it until it became natural.
  18. May 13, 2024 at 11:58 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    Many 2nd gens with the 6spd have this problem getting into third gear.
    Using redline gear oil is the fix. Use this oil, before it's too late.
    Are 3rd/4th gens using the same ol' 6spd?
    2001 4x4 and Brucey like this.
  19. May 13, 2024 at 5:17 PM
    Brucey
    Brucey Well-Known Member
    Bruce
    2018 DC LB SPORT 4X4
    Ovtuned
    I also did this to my 07 civic si. Stock fluid sucks in the winter and make the gears feel hard to engage. Redline and amsoil fix the issue. Or maybe my car just came with low fluid from the factory.
    FishaRnekEd[QUOTED] and 2001 4x4 like this.
  20. May 14, 2024 at 4:22 AM
    2001 4x4
    2001 4x4 Well-Known Member
    2008 TRD Offroad 6MT
    I have also found that switching out the stock trans fluid to Amsoil or Redline made all the difference. Shifts like butter now! Also, my second gen has the same thing with 3rd gear. For whatever reason the gate opens late in the 3rd gear syncro. If you pause for a second going into 3rd, giving that gate time to open it will fall into 3rd easily and smoothly. 3rd gear doesn't like to be rushed. If I rush 3rd it will grind.
    FishaRnekEd likes this.
