4th gen Oil Change
Discussion in '4th Gen. Tacomas (2024+)' started by Teuton, Jun 8, 2024.
  1. Sep 9, 2024 at 11:40 AM
    #201
    infantry317
    infantry317 Well-Known Member
    Minnesota
    2019 Tacoma TRD OR
    None yet
    Lol, those would work great off road.
    PDKTaco, hemlockz and snickers like this.
  2. Sep 9, 2024 at 9:35 PM
    #202
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Yup…. Super easy to gnarl the threads on them. They actually looked a bit deformed after removing them the first time.
  3. Sep 13, 2024 at 4:28 PM
    #203
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
  4. Sep 13, 2024 at 4:35 PM
    #204
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    You can’t fire me if I’m just being a bum living in my mom’s basement.
    forextacoma[QUOTED] likes this.
  5. Sep 17, 2024 at 9:37 AM
    #205
    miqie
    miqie Well-Known Member
    I like to use Purolator One oil filters, (PL11411) so obviously won't be going to the dealer for them. Does anyone know the part number for the oil plug crush washer so I could order online?
  6. Sep 17, 2024 at 10:01 AM
    #206
    hemlockz
    hemlockz Well-Known Member
    24 Bronze ORP 6MT
    MJB4450 and miqie[QUOTED] like this.
  7. Sep 17, 2024 at 2:58 PM
    #207
    miqie
  8. Sep 17, 2024 at 4:05 PM
    #208
    Xbowguy
    Xbowguy Well-Known Member
    Jeff
    Pa
    2023 Tacoma 4x4 SR5 double Cab Barcelona Red
    Vidman likes this.
  9. Sep 17, 2024 at 8:42 PM
    #209
    hemlockz
    24 Bronze ORP 6MT
    Yeah I didn’t even know about them until hearing about them on this site. I’ve been doing oil changes on several cars never had a crush washer before. But this is also the newest car using lightest oil I’ve ever owned, so I plan and using them going forward.
  10. Sep 20, 2024 at 10:00 PM
    #210
    miqie
  11. Sep 20, 2024 at 11:42 PM
    #211
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
    TLDR Folks: Therefore, our conclusion is pretty simple: if you can find a Wix or K&N filter for the same cost as an OEM Toyota filter, you should think about buying it. Otherwise, based on the pricing we found, the Toyota OEM filter seems like the smart choice.
    Stevie17 and Johnny919 like this.
  12. Sep 28, 2024 at 5:48 PM
    #212
    adrew
    adrew Well-Known Member
    '21 SR 2.7L 4x4 Old Man Truck
    Leer 100XR
    FYI my dealer sells 10-packs of the crush washers for $1.47 and the oil filters are like $5.50. Most likely yours will have them in stock and it's much cheaper than eBay/Amazon
  13. Sep 29, 2024 at 10:37 AM
    #213
    E4x4
    E4x4 Active Member
    2015 TRDOR 6MT
    Putting less oil than what’s put in at the factory for a turbo charged engine?
    Johnny919 likes this.
  14. Sep 29, 2024 at 6:13 PM
    #214
    Vitamins
    Vitamins Well-Known Member
    2024 TRD OR
    I did a bit of digging on these. I thought the same thing and so I prematurely went and purchased 10 new ones from the dealer believing that they were screwed up somehow. No, the way they look is exactly how they're supposed to look. They are in intended to look the way they do because they are self tapping.
  15. Sep 29, 2024 at 10:09 PM
    #215
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Sure. But they still deform very easily, self tapping or not.
  16. Sep 30, 2024 at 7:15 AM
    #216
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    What size are they? I think I'll replace mine with non-self tappers.
  17. Oct 2, 2024 at 11:08 PM
    #217
    kastilyo
    kastilyo Well-Known Member
    San Ramon
    2024 Double Cab White TRD Off Road
    I just changed my oil at 750 miles, for break In, you can not pre-filled out tacos, installed sideways, as soon as you fill it and put it in place all the oils comes out, we should all stop dreaming of pre-filling our oil filters, just wet the seal. My 2 cents
  18. Oct 2, 2024 at 11:44 PM
    #218
    bdkjones
    bdkjones Well-Known Member
    Bryan
    2024 TRD Off-Road
    Just stopped by to pour one out for the 2nd gen Tacoma. Open hood, oil filter was right there on top. 10 seconds to swap it.
    Now there's 8 bolts and two skid plates. Engineers ought to be forced to *work* on the cars they design.
  19. Oct 3, 2024 at 12:01 AM
    #219
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Go do an Audi 3.0T v6. The filter is on top (inside the vee along with the center mount turbo) but you have to remove the whole intake assembly and suspension tower cross brace to get to it.
  20. Oct 3, 2024 at 7:42 AM
    #220
    Sagebrush
    Gens 1, 2, 3, and 4
    I've been removing skid plates to change the oil on my Tacomas since 2016. I assume the engineers moved the filter next to the oil pan because of an issue with filters that drain when the engine is turned off.
