4th gen Oil Change
Discussion in '4th Gen. Tacomas (2024+)' started by Teuton, Jun 8, 2024.
  1. Jan 9, 2025 at 6:48 PM
    #301
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Shoulda put on a fumoto valve while you were there.
    Hadelson and Newwt like this.
  2. Jan 9, 2025 at 6:58 PM
    #302
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    Get a set of ramps and creeper. Install a Fumoto valve (and get their tube) so you don't make a mess. With a creeper, you can lower the skid plate on your chest and roll back out. Easy peasy.
    (And then quit whining.) :fingerscrossed:
    Blockhead likes this.
  3. Jan 9, 2025 at 7:07 PM
    #303
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    lol, should of stuck on a fumoto valve while you were down there. I feel you with the adding the oil, I do mine on a flat surface and add in 5qts, one side of the dip stick will show half the other side will show just under 1/4
  4. Jan 9, 2025 at 7:58 PM
    #304
    Vitamins
    Vitamins Well-Known Member
    2024 TRD OR
    You can use this:
    https://www.amazon.com/Measuring-Pitcher-Convenient-Conversion-Chart-Strong-Resistant/dp/B0B9GLH2D8
  5. Jan 9, 2025 at 8:55 PM
    #305
    patos tacoma
    patos tacoma Well-Known Member
    I’m curious,
    Anyone out in TW run into resistance from a dealer or oil change place because your truck had a Fumoto valve installed?
    Do they know what to do? or do you have to preview that they’ll find a Fumoto valve……?
  6. Jan 9, 2025 at 9:57 PM
    #306
    Sagebrush
    Gens 1, 2, 3, and 4
    Never.
  7. Jan 10, 2025 at 5:46 PM
    #307
    Vitamins
    2024 TRD OR
    If you're going to go to that trouble, I wouldn't let anyone at the dealer mess with it. I would just do the oil myself. "Free"' oil change or not.
  8. Jan 10, 2025 at 6:54 PM
    #308
    patos tacoma
    My question is more about being “out n the road”, not for being home with all my supplies…
  9. Jan 10, 2025 at 7:54 PM
    #309
    Sagebrush
    Gens 1, 2, 3, and 4
    I change my oil 90% of the time. But if it's 0ºF, I pay to have it done.
    patos tacoma likes this.
  10. Jan 11, 2025 at 10:55 PM
    #310
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Sounds like a Rivian is in your future
  11. Jan 12, 2025 at 8:31 AM
    #311
    Sagebrush
    Gens 1, 2, 3, and 4
    Good point.
    Changing oil only sucks if you don't have the proper tools.
    Vidman and Gmak621[QUOTED] like this.
  12. Jan 12, 2025 at 9:32 AM
    #312
    hemlockz
    hemlockz Well-Known Member
    24 Bronze ORP 6MT
    Hell yeah thats a sweet truck, just not in my near term budget- it costs about as much as two Tacomas, and holds its value like a gallon of milk.
    Maintenance Intervals
    • Tire Rotation and Multi-Point Inspection: every 7,500 mi (12,000 km)
    • Brake Fluid Flush: every 3 years
    • Coolant Change: every 112,500 mi (180,000 km)
    • Drive Unit Fluid Change (Model Year 2022-2024 Quad-Motor AWD vehicles only):every 112,500 mi (180,000 km)
    JoeMongo and Gmak621[QUOTED] like this.
  13. Jan 13, 2025 at 8:37 AM
    #313
    SchwarzeEwigkt
    SchwarzeEwigkt Well-Known Member
    Central NY
    ‘24 Tacoma TRD Sport 4x4, Solar Octane
    Just another reminder that an EV is a complex machine with a lot of overlap with ICE powered vehicles and no that machine is truly maintenance free. Well, except the ones designed to be thrown away regularly.
    Point is, buying that Rivian or Cybertruck or whatever doesn't mean you'll never have to maintain your car again.
  14. Jan 13, 2025 at 8:45 AM
    #314
    OpeCity
    Long Beach, CA
    Nothing is maintenance free, but BEVs have FAR fewer maintenance requirements. it’s not even comparable
    OregontoBajaCA likes this.
  15. Jan 13, 2025 at 9:36 AM
    #315
    SchwarzeEwigkt
    Central NY
    True, but if you buy an EV and think you'll never have to change fluids or regular wear parts again, you're in for a rude shock. You'll do less of it, but that's not what the EV faithful are preaching. I regularly hear them loudly proclaiming that their cars are "zero maintenance" and they "never have to take them in for anything." It's worse than a misconception; it's an outright lie.
  16. Jan 13, 2025 at 9:55 AM
    #316
    OpeCity
    Long Beach, CA
    I mean, going nearly a decade with just putting in washer fluid and rotating tires is pretty zero maintenance
  17. Jan 13, 2025 at 11:50 AM
    #317
    SchwarzeEwigkt
    Central NY
    Brake fluid still needs to be changed regularly. The brakes need regular service to keep them from freezing up due to the relative lack of use they get. Tires seem to need lots more service, particularly on Teslas. You still have to change the fluids in various parts, depending on the designs.
    It's not even close to zero maintenance. Again, definitely less, but implying it's set-it-and-forget-it on any term longer than a typical lease is disingenuous.
  18. Jan 13, 2025 at 11:56 AM
    #318
    OpeCity
    Long Beach, CA
    A very difficult thing to do every 3-4 years
  19. Jan 13, 2025 at 12:38 PM
    #319
    hemlockz
    24 Bronze ORP 6MT
    Everyone reading this post understands any vehicle is non-zero maintenance. EV was brought up in this context as an alternative to having to change motor oil in your driveway multiple times per year.
  20. Jan 13, 2025 at 8:05 PM
    #320
    patos tacoma
    Hmmm,
    What’s easier……….an oil change every 4 months. OR finding charging stations every 300 miles…….
    dneal, Goin2drt and JoeMongo like this.
