4th gen Oil Change
Discussion in '4th Gen. Tacomas (2024+)' started by Teuton, Jun 8, 2024.
  1. Jun 11, 2024 at 8:09 AM
    #61
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
  2. Jun 11, 2024 at 7:53 PM
    #62
    PalmettoGunny
    PalmettoGunny Member
    SC
    2001 PreRunner SR5 SandPearlBlk Original Owner
    Stock
    If you can afford to buy a 40-50k truck shouldn't you be able to afford an oil change ever 6 months or 3-5k miles just to be on safe side?
    :spending::devil:
    PUMPKINKING, RUBRN3K, Vidman and 4 others like this.
  3. Jun 11, 2024 at 8:03 PM
    #63
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Absolutely. But nobody here should be taking advice from the person with an Aprilia Tuareg 660 and no Toyota in the first place
  4. Jun 11, 2024 at 8:26 PM
    #64
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    It’s not my fault that Toyota doesn’t build trucks for men. /s
    I also do my oil changes every 10k miles or more and my truck cost more than $40-50k.
  5. Jun 11, 2024 at 8:48 PM
    #65
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    If you remove the chin strap you won’t need “Ramps of Death” for the oil change!
    If not, get you some Race Ramps instead, much safer
  6. Jun 12, 2024 at 3:32 AM
    #66
    JustAnotherSquid
    JustAnotherSquid Just here for the resale value
    Charlotte, NC
    2024 White TRD Sport 4x4 6MT
    I'm thinking about it! Still mulling over the potential loss of efficiency and increased noise vs the ocular pain of keeping it on.
    Thanks for the recommendation of Race Ramps!
    Gmak621[QUOTED] likes this.
  7. Jun 12, 2024 at 6:11 AM
    #67
    PalmettoGunny
    SC
    Stock
    Real men buy trucks that require engine and trans rebuilds every 80-100k miles:thumbsup:
    Gamma11 and tacoman45 like this.
  8. Jun 12, 2024 at 7:29 AM
    #68
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    I (obviously) don't have the chin strap on my third-gen TRD or Tacoma, and I still need ramps to change the oil comfortably.
  9. Jun 12, 2024 at 7:53 AM
    #69
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    'murica.
    Gamma11 likes this.
  10. Jun 12, 2024 at 8:59 AM
    #70
    chrispchicken9
    chrispchicken9 Well-Known Member
    '04 3.4 tacoma, '16 4.0 4runner
    ok
  11. Jun 12, 2024 at 2:19 PM
    #71
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    With the truck raised up in front on the ramps will the oil drain completely?
  12. Jun 12, 2024 at 3:16 PM
    #72
    JustAnotherSquid
    Charlotte, NC
    Note that the truck is sitting approximately level because my driveway is sloped. But do you ask because you actually care? :D
  13. Jun 12, 2024 at 3:33 PM
    #73
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    My garage is flat - so yes, I care.
  14. Jun 13, 2024 at 12:35 PM
    #74
    scottclarkinco
    scottclarkinco Well-Known Member
    Scott
    Denver, Colorado
    2014 MGM TRD Off Road
    A lot. Check out my build page.
    What is gonna happen for those who have a full complement of steel skid plates underneath? That oil filter looks to be in a lame spot. My 2nd gen with the filter up top is the most convenient I've ever had. This looks not so great.
  15. Jun 13, 2024 at 2:03 PM
    #75
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    my guess is they'll get a phillips/torx and remove the little cut out or a 14mm socket and drop it down like you do with 3rd gen skids...
  16. Jun 13, 2024 at 9:36 PM
    #76
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    What’s gonna happen? God forbid you have to drop some skids once or twice a year for routine maintenance
    Newwt likes this.
  17. Jun 15, 2024 at 6:13 AM
    #77
    BrokenMachine
    BrokenMachine Member
    Mikey
    '24 Bronze Oxide TRD Sport Premium
    Misfits and NIN stickers on rear glass.
    Had some time to kill yesterday, so I decided to make a DIY oil change video for the ‘24 Tacoma. It’s an amateur/low budget offering from me. I’m not really a big YouTuber/influencer type. I also made sure to leave my flat brim hat in the house haha. Hope this is helpful to someone out there wanting to do an oil change on the new Tacoma.
    https://youtu.be/M9Sd6-3O8Ug?si=McyEk77uknAA7NTd
  18. Jun 15, 2024 at 7:18 AM
    #78
    Sagebrush
    Gens 1, 2, 3, and 4
    Thanks for doing this.
    BrokenMachine[QUOTED] likes this.
  19. Jun 15, 2024 at 7:51 AM
    #79
    Toy-Truck
    Toy-Truck Well-Known Member
    Thanks for the video.
  20. Jun 15, 2024 at 1:33 PM
    #80
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    I care. Somebody has to
