4th gen Oil Change
Discussion in '4th Gen. Tacomas (2024+)' started by Teuton, Jun 8, 2024.
  1. Jun 15, 2024 at 2:14 PM
    #81
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Oil violently splashing out while draining is the christening of 3rd gen Tacoma owners too. I now use an 8qt bucket which seems to contain the burning holy water pretty well.
    usmc2msu and Gmak621 like this.
  2. Jun 15, 2024 at 2:21 PM
    #82
    BrokenMachine
    BrokenMachine Member
    Mikey
    '24 Bronze Oxide TRD Sport Premium
    Misfits and NIN stickers on rear glass.
    Yeah, might see if I can get a Home Depot bucket under there next time
  3. Jun 15, 2024 at 3:44 PM
    #83
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
  4. Jun 15, 2024 at 4:16 PM
    #84
    BrokenMachine
    Mikey
    yeah, opening the filler cap was probably a bad idea. Used to doing motorcycle oil changes haha. And yeah, the fumoto drain valve is probably going on my truck at 5,000 miles.
    Sagebrush[QUOTED] likes this.
  5. Jun 16, 2024 at 12:00 PM
    #85
    Johnny919
    Johnny919 Well-Known Member
    Long Island, NY
    2006 Honda Pilot EXL 4WD
    Thanks for the video! Is there a reason you poured oil into the filter? I've never heard of that. I have heard of just using a little bit of oil to rub on the seal of the filter.
  6. Jun 16, 2024 at 12:08 PM
    #86
    Sagebrush
    Gens 1, 2, 3, and 4
    The philosophy is out there. Dunno the answer, but it's not really realistic for a horizontal filter. Perhaps just fill it halfway? I don't know.
    Johnny919[QUOTED] likes this.
  7. Jun 16, 2024 at 2:05 PM
    #87
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    reduces the time needed for the system to build oil pressure thereby reducing wear
    I tried it on my oil change and was pretty surprised how little oil came out when putting on the filter since it’s horizontal
  8. Jun 16, 2024 at 2:09 PM
    #88
    Sagebrush
    Gens 1, 2, 3, and 4
  9. Jun 16, 2024 at 2:18 PM
    #89
    Newwt
    Tampa, FL
    Can anyone confirm if the oil filter part has been upgraded to YZZF2? that seems to come up a lot when searching for 90915-YZZN1
  10. Jun 16, 2024 at 2:37 PM
    #90
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    N1 replaces F2 after 20yrs, newer version of the older filter
    Newwt[QUOTED] likes this.
  11. Jun 16, 2024 at 5:53 PM
    #91
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    Can’t help but chuckle a bit seeing the 3rd Gen owners jealous of the 4th Gen spin-on filter
    Nice to see they went back to a spin-on filter though. Should help keep things a bit cleaner than the cartridge system on the 2GR
  12. Jun 16, 2024 at 7:19 PM
    #92
    BrokenMachine
    Mikey
    Reduces oil starvation when you start the engine for the first time after the oil change. And it’s also surprising how much oil the filter media inside of the housing can soak up. I had to pour oil into the filter about 4 times before it actually stayed full. The first few pours just got absorbed by the media.
    captrussia253 likes this.
  13. Jun 16, 2024 at 7:22 PM
    #93
    BrokenMachine
    Mikey
    I’m used to working with 10w40 motorcycle oil. Way more viscous. I’ve filled filters to the top with 10w40 and installed horizontally…not a drop spilled. Just gotta spin fast. That 0w20 really got me hahah. Oil shower.
  14. Jun 16, 2024 at 7:27 PM
    #94
    TacomaAddict23
    TacomaAddict23 There's no cure for dumb
    2023 Lunar Rock DCSB
    Ditch Lights 4wp Sliders Bed side molle panels Taco garage DMM mount More to come
    Im very jealous of that nice spin on oil filter
  15. Jun 16, 2024 at 7:39 PM
    #95
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    FWIW, technically you can use 0w-40 in your Tacoma with no worries.
  16. Jun 16, 2024 at 7:42 PM
    #96
    Sagebrush
    Gens 1, 2, 3, and 4
    Where did you read that?
  17. Jun 16, 2024 at 9:02 PM
    #97
    2019 TRD Off Road
    The difference between cold 0w20 and warm 0w20 is roughly 10x the difference between warm 0w20 and warm 0w40. Temperature affects far greater a viscosity difference than the difference between 20 and 40 grade.
    Engines must always be able to run on a higher viscosity, else they would never be able to run in the cold.
  18. Jun 16, 2024 at 9:07 PM
    #98
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Im jealous of that tbh
    Hafaday[QUOTED] likes this.
  19. Jun 16, 2024 at 9:24 PM
    #99
    lavrishevo
    lavrishevo Well-Known Member
    2023 Trail Edition
    Not sure if you guys know this but the OEM filter is only rated at 50% efficiency at 20 µm. That’s pretty poor quality. A good aftermarket filter will be rated at 99%.
  20. Jun 16, 2024 at 10:09 PM
    #100
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Receipts would be nice.
    Or don’t wait until 10k to change it.
    BrokenMachine likes this.
