4th gen Oil Change
Discussion in '4th Gen. Tacomas (2024+)' started by Teuton, Jun 8, 2024.
  1. Jul 3, 2024 at 9:37 AM
    #141
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Are you gonna run the Toyota genuine oil?
  2. Jul 3, 2024 at 9:56 AM
    #142
    Teuton
    Teuton [OP] Well-Known Member
    2011 Reg Cab 4x4, 2021 TRD sport, 2024 TRD Sport
    no I just use Mobil 1. I’m pretty sure my dealer also uses Mobil 1
    Gfenza89[QUOTED] likes this.
  3. Jul 3, 2024 at 10:27 AM
    #143
    Mudc4t
    Mudc4t Active Member
    Frank
    2024 TRD Sport 4WD
    None
    I did yesterday at 1,200 miles. Will do another at 5000 to get back on schedule and stay on 5000 for the life of it.
  4. Jul 3, 2024 at 10:30 AM
    #144
    Gfenza89
    What brand oil are you running?
  5. Jul 3, 2024 at 10:33 AM
    #145
    Mudc4t
    Frank
    2024 TRD Sport 4WD
    None
    Toyota 0W-20. Aka, M1 w/slightly different additives is my understanding.
  6. Jul 3, 2024 at 10:44 AM
    #146
    Gfenza89
    I think I might run the Toyota oil too. Was thinking of running amsoil signature series as I understand it’s really good for turbo engines but at the same time the engine was torture tested to death by Toyota with their genuine oil
  7. Jul 3, 2024 at 10:56 AM
    #147
    Mudc4t
    Frank
    2024 TRD Sport 4WD
    None
    My uneducated opinion is I don’t think you can go wrong either. More than anything pick one and stick with it so you aren’t jacking up the additive mixture. And the most important factor is the interval. My question is more should we be doing 3,000 mile oil changes with a turbo. The thing about manufacturer recommended intervals is my understanding is they get credit for longer oil change intervals for less oil waste disposal, as well as the ability to tout a lower cost of ownership. So kind of a conflict of interest although I do feel Toyota takes reliability seriously. It just gives me pause any time there is a kick back recommending something not beneficial to customer. I am going to stick to 5,000, but debating even going to 3000.
    1Strailhunter likes this.
  8. Jul 3, 2024 at 11:33 AM
    #148
    Gfenza89
    All good points ! I think I’m gonna stick to 3k mile oil changes
  9. Jul 3, 2024 at 5:06 PM
    #149
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    yes, I’ll did/will be doing 500, ~2k, 5k then every 5k after
  10. Jul 4, 2024 at 4:58 PM
    #150
    Rocko
    Rocko Well-Known Member
    Washington
    2024 TRD Auto
    To really start the fireworks off here, I plan on permanently switching to M1 5W30 EP and stick to 5k. I am due to change it in about 1 k miles, but I may do it sooner as I have the next few days off.
  11. Jul 4, 2024 at 5:29 PM
    #151
    lvmusicman
    lvmusicman Well-Known Member
    Dealer told me the warranty is voided if you use oil that is not stated in owners manual
  12. Jul 4, 2024 at 6:30 PM
    #152
    Digitalwiz5
    Digitalwiz5 Well-Known Member
    What does the owners manual say? What the dealer says is worthless, they barely know anything about their own veichles.
  13. Jul 4, 2024 at 6:49 PM
    #153
    lvmusicman
    It says 0W-20 only except in emergency you can use 5W-20 but must convert back to 0W-20 at next oil change
  14. Jul 4, 2024 at 6:50 PM
    #154
    Digitalwiz5
    I declare an emergency.It not like they defined what constitutes an emergency so it seems you can always run it if your “emergency” doesn’t end.
    Rocko likes this.
  15. Jul 4, 2024 at 7:03 PM
    #155
    Rocko
    Washington
    2024 TRD Auto
    My truck will likely never see the dealer anyways unless (or when) there is a recall of some sort. I'll take the .0069 chance my motor blows up and they blame the oil.
    JoeMongo likes this.
  16. Jul 4, 2024 at 7:05 PM
    #156
    lvmusicman
    Who would be that stupid and no you can only use it till your next oil service interval under warranty,Why would anyone want to take the risk of voiding the warranty.
  17. Jul 4, 2024 at 7:10 PM
    #157
    Digitalwiz5
    Some are concerned about the 0 in 0w-20 being waaaay to thin. There’s reason to believe it’s that way for EPA gas mileage and not really appropriate as a long term protective oil.
    dJunior and Rocko like this.
  18. Jul 4, 2024 at 7:33 PM
    #158
    lvmusicman
    Most new cars use this oil.Even semi trucks will start using it in 2027,Toyota has a 0W-8 that they will start using in a few years.
  19. Jul 4, 2024 at 7:38 PM
    #159
    Newwt
    Tampa, FL
    I use 5w30, right now using Penn UP I have. Once that runs out I’ll be using Rotella 5w30
  20. Jul 10, 2024 at 3:39 AM
    #160
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    It’s impossible that 30 weight could cause damage in any engine speed for a 20 weight. The difference is like 1.2 cSt at 100C.
    By comparison, the difference between cold 0w20 and warm 0w20 is like 40+ cSt.
    I’d absolutely run a 30 weight while in warranty. I’d just get my scheduled 10k oil changes, switch it out for 0w/5w30 HPL, and not tell them. They’ll never know. Meantime I get better protection from fuel dilution, a more robust oil, better HTHS and film strength, and better deposit control.
    ToyodaSun and GONE FISHIN' like this.
