4th Gen OR stuck in 4H
Discussion in '4th Gen. Tacomas (2024+)' started by TacoFish808, Mar 23, 2025.
  1. Mar 23, 2025 at 1:41 PM
    TacoFish808
    TacoFish808 [OP] Member
    Caleb
    2024 Underground OR Tacoma
    17” Method wheels
    Yesterday I went to the Dirtbike track and it was muddy getting out. Had to put the truck in 4H. I shifted to neutral then moved the knob to 4H, I waited until the 4H indicator light stopped flashing on the dash. I was able to get out of the mud and get out of the mountains. Before I hit the pavement I stopped shifted to neutral and switched the knob to 2H. 4H started flashing on the dash and nothing happened. Normal. I have had this happen in other trucks. I rolled fwd and back many times to try to get it to disengage. No Luck. I then tried to do it on loose gravel and no luck. I read on this forum to try to lift one of the front wheels with the jack. Tried that and still no luck. I have a warranty on the truck. Called Toyota and they can’t get me in for 2 weeks. If anyone has any other ideas? Might just be a bad actuator is what I am thinking. I use 4x4 regularly and it has worked with no problems for 9k miles. The only mod I have done is put method wheels and mud tires on it.
    UPDATE.
    Faulty actuator motor. Toyota has replaced it. Truck is back to working normally. Thank you to anyone who posted something HELPFUL
    PUMPKINKING likes this.
  2. Mar 23, 2025 at 1:54 PM
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
    What happens if you leave it in drive and then switch between 4h and 2h?
    AvalonTaco and Jakerou like this.
  3. Mar 23, 2025 at 2:17 PM
    Taco Ji
    Taco Ji Well-Known Member
    New Jersey
    2025 TRD OR - Hybrid Bronze-Oxide, Premium PKG.
    Not an expert but I’ve read to switch from 2H to 4H you keep the speed limit under 65 mph and can switch while in drive mode and no need to switch to neutral gears.
  4. Mar 23, 2025 at 2:28 PM
    roalddahl
    roalddahl Well-Known Member
    2025 DCLB OR Terra (pending), 2011 Access cab OR Silver
    You should be in gear to go 2H to 2L or vice versa. In neutral for 2L to 4L.
    Perhaps you already tried, but once I had a similar problem in my 2nd gen, I went into 2L, drove a little, then progressively back to 2H with a little driving and small turns in between steps. It worked.
    Jakerou likes this.
  5. Mar 23, 2025 at 11:58 PM
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    That’s how you shift to 4L.
    When you shift to 4H do it while moving forward in drive.
  6. Mar 24, 2025 at 5:41 AM
    Taco2GR86
    Taco2GR86 Well-Known Member
    2021 TRD Pro 6MT [sold]; 2024 TRD OR 6MT
    If only there were some kind of instructions for this type of thing, to help owners. An owner’s manual, if you will.
    TurboDA6, baron55, Vitamins and 7 others like this.
  7. Mar 24, 2025 at 6:23 AM
    JB_TN
    JB
    Tennessee
    It's amazing the amount of postings I have seen on facebook with people trying out 4WD in the mall parking lot doing circles on dry pavement....wondering what the hell all the noise and shaking is about.
  8. Mar 24, 2025 at 6:24 AM
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    25 years ago it was just a thick book located in the glove box or a sticker. 25 years earlier, you might’ve locked your own hubs. But today, it’s a 2 sec browse on your personal Toyota app, a YouTube video either by Toyota or other credible resources, quick query here, or when all else fails, just google.
    For those who may have traded in their AWD wagons, sedans, or SUV’s on a Tacoma, it pays to do a little homework before you go half-cocked off road and potentially end up reporting problems here.
    TurboDA6, baron55 and bbartol like this.
  9. Mar 29, 2025 at 3:34 PM
    TacoFish808
    Caleb
    17” Method wheels
    Nothing happens. It just flashes 4hi
  10. Mar 29, 2025 at 3:35 PM
    TacoFish808
    Caleb
    17” Method wheels
    Tried this also no luck
  11. Mar 29, 2025 at 3:37 PM
    TacoFish808
    Caleb
    17” Method wheels
    I’ve owned many 4wds and I know what I am doing. This is something mechanically wrong with the truck. It’s been at Toyota for a week. They have no clue what is wrong and have been trying to fix it. Thanks tho buddy
    CrispyTacoLover likes this.
  12. Mar 29, 2025 at 3:39 PM
    TacoFish808
    Caleb
    17” Method wheels
    Miss my 97 4Runner. No computer crap like today.
  13. Mar 29, 2025 at 3:42 PM
    TacoFish808
    Caleb
    17” Method wheels
    Toyota has had the truck for a week now and they are stumped. They have been in contact with their headquarters trying to find a solution. They have reset and recalibrated everything. It’s still stuck in 4hi. They said they have never seen this happen before. ‘all the donkeys saying to check the manual just f*** off. Thanks.
  14. Mar 29, 2025 at 4:03 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    I blame the buying public for all this stuff they put in all these vehicles. All potential buyers want a truck
    That gets 35 miles to the gallon , goes 0 -60 in in 3 seconds , has 900 foot pounds of torque, is lifted and goes around corners like a rally car . I think back to my 01 Tacoma ….. what a nice simple little truck . Auto hubs yes but you went into 4WD with a nice shifter, you know what , that truck wasn’t fast at all but what a great simple motor to work on . These companies going way overboard in my opinion
    Curveball30 and Gfenza89 like this.
  15. Mar 29, 2025 at 4:36 PM
    TacoFish808
    Caleb
    17” Method wheels
    Tried this a few times and no luck
  16. Mar 29, 2025 at 4:39 PM
    TacoFish808
    Caleb
    17” Method wheels
    Agreed! I miss my 97 4Runner. I had to make the downsize from a 2nd gen raptor so nothing will ever compare to the raptor. I got the 24 Tacoma for financial reasons. I in no way expect it to preform like a raptor and have not treated it so.
  17. Mar 29, 2025 at 6:51 PM
    roalddahl
    Bummer man, sorry you're stuck without an answer and without a truck.
  18. Mar 29, 2025 at 8:20 PM
    TacoFish808
    Caleb
    17” Method wheels
    Appreciate it man it sucks! I need my truck for work sometimes so it’s inconvenient. I’m shocked that even Toyota is stumped. They have been on it with providing updates. Nut every update is not good news.
  19. Mar 30, 2025 at 5:27 AM
    AvalonTaco
    AvalonTaco Falken Sales Rep.
    Joe
    Cabin in the woods
    2019 Super White DCSB OR
    Working on a lien delete for my title…..
    I’d put a placard on the visor.
  20. Mar 30, 2025 at 5:43 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Gmak621 and Toyko Joe like this.
