4th Gen Tacoma (2024+)
Discussion in '4th Gen. Tacomas (2024+)' started by shakerhood, Aug 26, 2021.
  1. Jan 21, 2024 at 4:49 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    That's what he does.
  2. Jan 21, 2024 at 4:51 PM
    Plasmech
    Plasmech Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    Maybe if you do an aftermarket tune, and an overly ambitious one at that. Otherwise, I'm not worried about turbo longevity.
    BC Hunter and stevesnj like this.
  3. Jan 21, 2024 at 5:20 PM
    Gasmonkey
    Gasmonkey Well-Known Member
    20 dbcb offroad
    You should start a car company, sounds like you have this figured out.
  4. Jan 21, 2024 at 5:30 PM
    It's a TRD Thang
    It's a TRD Thang Well-Known Member
    Canada
    2021 Army Green Off Road
    3 inch Leveling kit with 265 75 r16 Ko2's
    I'd go to the guy across the street instead
  5. Jan 21, 2024 at 7:09 PM
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    Of course there is. Forced induction is harder on engines. Always has been, always will be.
  6. Jan 21, 2024 at 7:11 PM
    It's a TRD Thang
    Canada
    If I get 300k out of an engine I'm good , your making it sound like they will all blow up at 80 thousand. Again stop the fear mongering
    DRAWN and Hogleg918 like this.
  7. Jan 21, 2024 at 7:11 PM
    Turd Ferguson
    Taxachusetts
    Can you fund it? @SwollenGoat and I will do the design work. We’ll call it Goat Turd Motors.
  8. Jan 21, 2024 at 7:14 PM
    Turd Ferguson
    Taxachusetts
    Now you’re just making things up. I never said such thing.
    Goats first gen motor went 435K miles. Do you have any turbo engine examples with similar mileage? Do you honestly think a 4th gen motor will last that long?
    SwollenGoat likes this.
  9. Jan 21, 2024 at 7:15 PM
    It's a TRD Thang
    Canada
    Do you have an example saying they won't last that long? You're the one bringing up . I bet you there are turbo engines put there that last that long with proper maintenance
  10. Jan 21, 2024 at 7:19 PM
    Turd Ferguson
    Taxachusetts
    How about WRX engines. :D
    holland1 and SwollenGoat like this.
  11. Jan 21, 2024 at 7:40 PM
    SwollenGoat
    SwollenGoat Onwards and Upwards!
    ‘21 ACLB, ‘99 XCLB, ‘92 RC, ‘85 4R
    Lol!
  12. Jan 21, 2024 at 8:34 PM
    mikekoot
    mikekoot Well-Known Member
    MIKE
    Castlegar BC
    14 ssm dclb sr5/18 tundra
    What they should have done is put in an old straight 6 with cast iron block from the 60s complete with vacuum tubes and carburetor. 3 on the tree would also be a good idea. Its proven reliable.
    BC Hunter and Lt. Dangle like this.
  13. Jan 21, 2024 at 9:41 PM
    DRAWN
    DRAWN Well-Known Member
    2016 QUICKSAND AC SR5 4X4
    Sliders, 6112's, full skids.
    Stop fear mongering. I’ve seen plenty of 2jz’s with that mileage. Also plenty of examples of old turbo Saabs and Volvo’s getting to extremely high mileage, on turbo tech from the 80s and 90’s, running Dino oil. We’ve seen supercharged 3.4s and 4.0s reach ridiculously high mileage, and those engines were never designed with force induction in mind. The 2.4l was designed from the ground up to handle forced induction and had to meet the SAME durability standards that the previous engines did. If manufactures could accomplish that mileage in the 90’s, then it’s not some absurd feat in 2023 with modern synthetic oil, better tolerances, higher thermal efficiency and electronically controlled engine management.
    Regardless that kind of mileage is irrelevant to most owners because the cost of maintaining the rest of the truck above 300k is usually prohibitive. Ask goat how much work he had to do on the truck. If you have the resources, skills, knowledge and tools to keep a NA gas truck working above 350k then a simple turbo replacement above 250k isn’t daunting. If you actually use your truck as a 4x4, then there’s a long list of preventative items that need to be addressed by 200k, and they won’t be cheap if you want OEM components.
    BC Hunter and OpeCity like this.
  14. Jan 21, 2024 at 9:44 PM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Yup. Well said. Theres a user in the 1G forum with like 800k on a blown 3.4 but turd is terrified of FI on a motor designed exactly for the job :rofl:
  15. Jan 22, 2024 at 4:58 AM
    Turd Ferguson
    Taxachusetts
    I’m not terrified you moron. I’m saying a forced injection motor has a shorter lifespan than NA. Fact. There’s no need to argue. We can revisit this in 10 years and I’ll say “told you so”.
  16. Jan 22, 2024 at 5:10 AM
    stevesnj
    Oh he's gonna call you some type of name for saying that. lol
  17. Jan 22, 2024 at 5:47 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I can't see forced induction adding longevity to an engine.
  18. Jan 22, 2024 at 5:50 AM
    mikekoot
    MIKE
    Castlegar BC
    Just wait ten years before buying a 4th gen taco. Problem solved.
  19. Jan 22, 2024 at 5:55 AM
    Snakepilot
    Snakepilot Well-Known Member
    Tucson, AZ
    2025 Tacoma TRD Pro
    Probably a non-issue for most people. 15-20K/yr (way above 13k average) is only 135-180K. Just don't buy used, it will be someone else's problem.
  20. Jan 22, 2024 at 6:12 AM
    It's a TRD Thang
    Canada
    I see Turd ignored your post because you provided examples
    Gasmonkey, stevesnj and Hogleg918 like this.
