4th Gen Tacoma (2024+)
Discussion in '4th Gen. Tacomas (2024+)' started by shakerhood, Aug 26, 2021.
  1. Apr 9, 2024 at 11:21 AM
    tyugy
    tyugy Well-Known Member
    I'm struggling to see the separation between the LC and new 4Runner. I figured they would limit the powertrain to non-hybrid to help distinguish them, but they do appear pretty close to each other. I guess Toyota will make the 4Runner a cheaper body-on-frame SUV compared to the LC with lower quality materials?? They're generally close in size, can have the same engine, appear to have similar towing numbers according to the Forbes article. Weird move by Toyota IMHO.
  2. Apr 9, 2024 at 11:30 AM
    Hogleg918
    Hogleg918 Well-Known Member
    Oklahoma
    Ranger Raptor, sorry TW
    I have no idea, it’s just the first thing I thought of when I saw it.
  3. Apr 9, 2024 at 12:17 PM
    awdj
    awdj Well-Known Member
    20' Tacoma TRD PRO
    Lol, they killed the 4Runner. From a reddit post:
    Both the new 4Runner and new Land Cruiser share an identical 112.2" wheelbase. The extra 4.7" in length of the new 4Runner went to both front and rear overhangs. Meaning, there should be a slightly longer cargo area, but also slightly more hood and front bumper.
    The longer overhangs mean the approach and departure angles are slightly degraded for the new 4Runner at 32 and 24 degrees respectively, compared to 33 and 26 degrees for the four-wheel-drive fifth-gen.
    This clarifies my decision on what vehicle I'm purchasing. 4Runner is no longer an option.
    TacoBuffet and holland1 like this.
  4. Apr 9, 2024 at 12:20 PM
    Plasmech
    Plasmech Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    What is the underlying purpose of the "leaks" that always happen before these events? To get people talking so that more will be tuned in tonight?
    ...and before anyone even tries, there is zero chance these are leaks. They're "leaks".
    usmc2msu likes this.
  5. Apr 9, 2024 at 12:44 PM
    jaxyaks
    jaxyaks Well-Known Member
    2020 Silver Tacoma TRD Off Road
    If you go to Toyota USA's social media pages and share the leaked photos on the comment section, I bet they delete them real quick....I don't think they meant for the pics to get out until later today.
  6. Apr 9, 2024 at 1:23 PM
    Snakepilot
    Snakepilot Well-Known Member
    Tucson, AZ
    2025 Tacoma TRD Pro
    The front doesn't look like it is much longer/lower than the previous gen. I wonder if those numbers are for the Limited with the air dam? In the rear it looks shorter than the previous gen but the spare tire hangs down lower. A rear spare tire carrier would solve that.
    DRAWN likes this.
  7. Apr 9, 2024 at 1:39 PM
    TacoMTga
    TacoMTga Well-Known Member
    Brian
    Inreally hope Toyota messes up for 2025 and offers some of those 4Runner colors on the Tacoma
  8. Apr 9, 2024 at 1:48 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    4th gen Tacoma looks way better in person that it does in pictures.
    If the 4Runner doesn’t, they just sold a lot of Pilots for Honda.
    Kolter45 likes this.
  9. Apr 9, 2024 at 2:10 PM
    jaxyaks
    The wheel base is longer you'll have to probably lift it to get to the angles you have currently stock. Your SOL on the turning radius though.
  10. Apr 9, 2024 at 2:35 PM
    Pyral
    Pyral Well-Known Member
    None
    All the Toyota BOF offerings have gotten less capable over the last 20 years. Look at the stats for a normal 4wd 1st gen Sequoia, then look at them for a current TRD Sequoia. The 1st gen Sequoia wipes the floor with it, over an inch more of ground clearance, better angles. I blame it on cost cutting and the CAFE loophole, every generation gets bigger to make emissions easier, but at the cost of capability. They try and hide it with technology, but the bones are worse.
    The question is how cheap would the 4runner have to be for you to buy it instead of a Land Cruiser? Let's assume it is made in Mexico, and that Toyota does all the crap they did on the Tacoma like stop including metal skid plates on base 4wd.
    I think the highest trim should top out around 49k (Land Cruiser starts at 55k). Pricing a TOTL 4runner any closer to a base LC is dangerous since the base LC has everything the TOTL 4runner has. And at that point people will choose to upgrade to an LC since it looks better and is higher quality being made in Japan. Of course, that might be the idea.
    Toyota would rather have an SUV lineup with the same amount of fine adjustment as a color wheel than make a Wrangler competitor or anything resembling first gen 4runner.
    holland1 likes this.
  11. Apr 9, 2024 at 2:55 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    There is going to be price overlap. The 4Runner Trailhunter will definitely be in Land Cruiser territory, possibly into the Lexus GX 550 lower end territory.
    shakerhood[OP] likes this.
  12. Apr 9, 2024 at 2:57 PM
    DRAWN
    DRAWN Well-Known Member
    2016 QUICKSAND AC SR5 4X4
    Sliders, 6112's, full skids.
    I’m running a high clearance bumper so I understand the importance of a good departure angle, but why is it such a deal breaker for you? If it’s a trail rig then wouldn’t you throw a lift on and bigger tires anyway solving that issue?
  13. Apr 9, 2024 at 3:09 PM
    awdj
    20' Tacoma TRD PRO
    The real issue is the almost zero effort to make this a different vehicle than the Tacoma. The 4Runner was a unique vehicle in its segment. Additionally, the new 4Runner shares the same shitty rear leg room as the new Tacoma, and the Tacoma's before it.
    The Land Cruiser should have been the 6th gen 4Runner.
    Acey likes this.
  14. Apr 9, 2024 at 3:11 PM
    DRAWN
    Yea but if it’s anything like the new Tacoma it will be much easier to fit larger tires on with little modification (removable plates on the cab mount). The TH and PRO Tacoma trims can easily fit 35’s stock, and they will handle the power and stress better with the larger diffs, cv, steering rack, and torque from the hybrid. That should make it a better option than the 5th gen for anybody serous about taking it off-road frequently.
  15. Apr 9, 2024 at 3:17 PM
    CrispyTacoLover
    We don’t know that yet. But the interior picture doesn’t look good.
    Rear leg room was a selling feature for the 5th gen runner. If that is gone, it’s a mistake.
  16. Apr 9, 2024 at 3:26 PM
    DRAWN
    I mean I get it, the 5g is a gem in the current market. And it’s lame how they gave it the exact same interior. It would be more special if it had its own unique interior. It kind of makes me want to pick up a used one in good condition. The cabin space is definitely a fail, that was one reason the 4 runner was a better choice for passengers. I just wish they gave the LC a split tailgate like the old ones. Was considering either a 4Runner or new LC to replace the wife’s crv. This leak has me leaning towards the LC, styling and interior alone. Especially if I’m getting a 4g taco eventually. But man do I love that roll down rear window.
  17. Apr 9, 2024 at 3:31 PM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    Haahaa. Try 90k for the LC
  18. Apr 9, 2024 at 3:38 PM
    CrispyTacoLover
    Sure, if you are an idiot.
  19. Apr 9, 2024 at 3:41 PM
    SACTOWN
    Greg
    Well are your chirpy
    BC Hunter likes this.
  20. Apr 9, 2024 at 3:41 PM
    DRAWN
    That’s the first edition version though. It’s a limited production model run that they are releasing first.
