4th Gen Tacoma (2024+)
Discussion in '4th Gen. Tacomas (2024+)' started by shakerhood, Aug 26, 2021.
  1. Apr 22, 2024 at 8:19 PM
    It's a TRD Thang
    It's a TRD Thang Well-Known Member
    Canada
    2021 Army Green Off Road
    3 inch Leveling kit with 265 75 r16 Ko2's
    And better problems. That ford hybrid is full of issues from what I have heard , even talked about on here
  2. Apr 22, 2024 at 8:23 PM
    1stIn3rd
    1stIn3rd Active Member
    2020 Tacoma Trd Pro
    Hopefully its not like my 2023 Trd Pro Sequoia. It doesn’t get near estimated MPG #’s. I’ve never gotten above 16.5 MPG and I drive like an old lady
  3. Apr 22, 2024 at 8:25 PM
    Gasmonkey
    Gasmonkey Well-Known Member
    20 dbcb offroad
    But it has a front locker.
  4. Apr 22, 2024 at 8:29 PM
    Gasmonkey
    20 dbcb offroad
    The watts link is superior to handling over the Tacoma. Ford designed the Bronco Raptor for rock crawling.
  5. Apr 22, 2024 at 8:29 PM
    Snakepilot
    Snakepilot Well-Known Member
    Tucson, AZ
    2025 Tacoma TRD Pro
    Didn't spend a lot of time researching but an F150 Lariat 4x4 hybrid (mid grade trim) with only the FX4 and tow package is 68K.
  6. Apr 22, 2024 at 8:43 PM
    DRAWN
    DRAWN Well-Known Member
    2016 QUICKSAND AC SR5 4X4
    Sliders, 6112's, full skids.
    I’m sure it helps offset the lack of articulation. I’ll take a front sway bar disconnect over a front locker any day though. I hardly touch my front arb locker. A trac + rear locker is sufficient for most scenarios. Much harder to add an electronic sway bar disconnect aftermarket than it is a front locker.
  7. Apr 22, 2024 at 8:47 PM
    DRAWN
    Yea that’s what I meant by better performance. Again it comes at the cost of complexity and cost, probably won’t be an issue for most owners. I have to give ford props for giving that level of attention to suspension performance.
    Gasmonkey[QUOTED] likes this.
  8. Apr 22, 2024 at 8:52 PM
    DRAWN
    I live in CO and drive that route regularly. Even loaded down I’ve never been WOT the whole time. 278hp and 265 tq is more than enough. 326 and 465 will be child’s play.
  9. Apr 22, 2024 at 8:54 PM
    Plasmech
    Plasmech Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    The asshole embargo is about to lift.
    taco terror likes this.
  10. Apr 22, 2024 at 9:38 PM
    Snakepilot
    Tucson, AZ
    2025 Tacoma TRD Pro
    I'm not following you. "Bronco Raptor" has panhard rod like the Tacoma, so more articulation for better handling when rock crawling? Or "Ranger Raptor" has watts link which gives more stability for high speed handling? Or Tacoma Pro Fox rear hydraulic bump stops so the rear end doesn't lose composure (handling) when you bottom out during your high speed running?
  11. Apr 22, 2024 at 9:53 PM
    DRAWN
    I was originally just referring to the articulation numbers someone posted, it was either here in on the ranger thread. By performance I was referring to the fact that the watts link is a more complex setup with the added benefit of better handling and axle centering at high speed and in general. I’m not sure if it gives it worse articulation or it’s just an inherent design aspect of the new ranger , someone with more knowledge could tell you. I’m sure the regular ranger numbers are floating around somewhere. The taco just has better numbers than the raptor regardless of linkage design or trim level, probably due to the sway bar disconnect. I wasn’t comparing ride quality when initially taking about articulation though. Wouldn’t be surprised if the raptor is better.
    The new hydraulic bumps are a sweet upgrade on the taco though, it sounds like you can add them to any trim, plug and play. If I get a TH I will probably add some for better bottom out resistance at higher speed.
  12. Apr 23, 2024 at 3:38 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    I missed some of the mpg talk and it could have been brought up a looong time ago, but up to 26mpg?
  13. Apr 23, 2024 at 3:41 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    I drive a shitbox in Appalachia.
    I bet you’re wrong.
  14. Apr 23, 2024 at 3:45 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Hah, some people don't know the feeling of yelling at the car at high RPM's up the mountain "Come on little buddy you can do it!" :rofl:
    Also turning off the AC so it doesn't lug it down too much :laugh:
  15. Apr 23, 2024 at 4:10 AM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    Interesting. I would have guessed the Tailhunter was to top the Pro in price. Whattabargain! Actually, that would make those Iso seats 500 a piece. Depending on your POV, the Pro would be a bargain :D
  16. Apr 23, 2024 at 4:21 AM
    snickers
    Fun times ahead. Finding an Off Road trim with hybrid and the upcoming increased supply. End prices in another year might be more realistic. Toyota can control competitor jumping with discounts.
  17. Apr 23, 2024 at 4:27 AM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Does it sound like only the limited has the heads up display?
  18. Apr 23, 2024 at 4:30 AM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    I would think that too. I guess I’ll have to wait longer.
    My wife’s Grand Highlander has it and I’ve gotten used to it lol.
    not that it will be the only thing that puts me in a TH but it wouldn’t hurt.
    Maybe I need to look into the limited and get a suspension and other upgrades myself…
    lastly, need to start putting my truck to stock and selling parts, invest in dogecoin, shibacoin and hope for the best :rofl::bananadead:
    Delta09 likes this.
  19. Apr 23, 2024 at 4:31 AM
    Plasmech
    Is iso seat delete an option in the Pro?
    Minny Taco likes this.
  20. Apr 23, 2024 at 4:33 AM
    Ryan's Taco
    Ryan's Taco Well-Known Member
    Prince Edward Island
    24 TRD Offroad manual
    I am watching a few videos this am at work but $63900 for the Pro is what the Canadian price was for 23 now that's the USD price that works out to $81k Cdn. Our province is 15% tax so that would be $94 plus dealer stuff and extra warranty you would be at $100k
    shakerhood[OP] and CrashZone like this.
