4th Gen Tacoma (2024+)
Discussion in '4th Gen. Tacomas (2024+)' started by shakerhood, Aug 26, 2021.
  1. May 31, 2024 at 7:45 AM
    Snakepilot
    Snakepilot Well-Known Member
    Tucson, AZ
    2025 Tacoma TRD Pro
    But the recall affects the first two years (and possibly the third).
  2. May 31, 2024 at 7:46 AM
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    100% agree with this
    shakerhood[OP] likes this.
  3. May 31, 2024 at 7:58 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    People aren’t using models that were designed, engineered, and built within the last decade as a bastion of Toyotas reliability.
    Why are people buying new Toyotas today based on how reliable they were in the 90s and early 00s?
    Lt. Dangle likes this.
  4. May 31, 2024 at 8:03 AM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    90's? Early 2000s? I'll buy a 4th gen because of how reliable my 2016 3rd gen is.
    DRAWN and TacoBuffet like this.
  5. May 31, 2024 at 8:13 AM
    Snakepilot
    Tucson, AZ
    2025 Tacoma TRD Pro
    Data from the last 10 years still supports Toyota/Lexus being the most reliable. In addition to reliability, in my opinion, Toyota interiors tend to age better than the competition (wear better and appear less dated).
    TacoBuffet likes this.
  6. May 31, 2024 at 9:36 AM
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    Instead of buying my new ‘16, I had also considered buying a new outgoing 2015, and in hindsight I probably should have. That ‘16 was a nice truck, just not finished. A couple years later, my 2018 OR was excellent, so maybe that’s how Gen4 goes.
  7. May 31, 2024 at 10:36 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    toyota had some dud engines in the 80s and 90s too. the 7m and 3vz both had head gasket issues. the 3vz so bad they were replacing engines well outside of warranty
  8. May 31, 2024 at 11:19 AM
    LawTaco
    LawTaco Well-Known Member
    Lawrence
    Bay Park,San Diego,Ca
    TRD SPORT 24
    I traded my 4.0 2014 2nd gen for a 2016 trd sport 3rd gen in October 2015 and never had any mechanical problems for 92k miles and just traded it for 2024 trd sport and this new engine and trans drives so nice the extra torque this engine produces comes in at very low rpms it's a pleasure to drive no laggy gas pedal. It has a warranty so you are covered. There is alot of room under the hood to access the turbo and other components. It has a real oil filter back on it. Wife has a lexus tx350 with the same engine and it drives awesome too. I tried to talk myself out of wanting a 4th gen because my 3rd gen was great but this 2024 is way better in all departments. Go test drive one you don't have to get the fully loaded trd the sr5 has the same engine well equipped and starts at 36k.
    Gmak621, Newwt and batacoma like this.
  9. May 31, 2024 at 11:38 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I wouldn't mind seeing a Xtracab Trail Boss trim. Start with a SR XC, give it the higher output T4, 4x4 with the rear locker front fogs and the TRD overfenders. Leave the steel wheels and put a +size set of AT tires on it.
  10. May 31, 2024 at 12:29 PM
    Johnny919
    Johnny919 Well-Known Member
    Long Island, NY
    2006 Honda Pilot EXL 4WD
    Yep, I'm aware. I probably wouldn't buy the first few years of new gen, just especially the first. I think around mid cycle refresh/end is the best.
  11. May 31, 2024 at 12:42 PM
    Snakepilot
    Tucson, AZ
    2025 Tacoma TRD Pro
    Tundra engines made in Alabama and Lexus engines made in Japan. Rumor was that there was "one guy" in Alabama that was screwing up the engine assembly.
    Does this mean a design flaw? Could be an assembly instruction manual flaw. New guy does it by the book while old timers know to properly flush block before assembly even though it's not in writing.
  12. May 31, 2024 at 1:13 PM
    TacoBuffet
    AL
    Sounds about right as an Alabama resident myself. Don’t get me started, work with nurses that definitely killed people due to incompetence.
  13. May 31, 2024 at 1:36 PM
    Snakepilot
    Tucson, AZ
    2025 Tacoma TRD Pro
    Not slamming Alabama. If the LX is included they're making mistakes too. Maybe the Lexus workers are generally more meticulous and that's why the Lexus failures are less common. I wonder if all of the short blocks are cast in the same factory.
  14. May 31, 2024 at 1:46 PM
    holland1
    holland1 Well-Known Member
    tacoma
    They probably only sell a 5-10k lexus versions a year. I thought this 3.5 twin turbo was used in older models Lexus cars? No recalls for those, something must have changed.
  15. May 31, 2024 at 2:04 PM
    JWestie
    JWestie Well-Known Member
    2019 Tacoma DCLB-OR Mag gray
    Not sure what it says about the manufacturing process at that particular plant if one guy could F-up an entire batch of engines. Regardless, its a major black eye for Toyota. Tundra is a mess.
    Extra Hard Taco likes this.
  16. May 31, 2024 at 2:45 PM
    TacoBuffet
    AL
    I think its a design issue and they are just using that as a scape goat, I mean there are 2024's having the same issue.
  17. May 31, 2024 at 2:49 PM
    Acey
    Acey Well-Known Member
    Denver ish
    ‘24 Cybertruck
    The issue is not fixed?!
  18. May 31, 2024 at 2:51 PM
    TacoBuffet
    AL
    Nope, watch the video I posted, guy shows on the forum/facebook groups a few guys with 2024s having same issue. One with 7500 miles.
    Acey[QUOTED] likes this.
  19. May 31, 2024 at 3:05 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    The videos I watched seem to indicate a design flaw. They attempted to fix it, but it appears the new design did not fix the bearing and seal issue.
  20. May 31, 2024 at 3:07 PM
    TacoBuffet
    AL
    From what I've gathered as well.
