4th Gen Tacoma (2024+)
Discussion in '4th Gen. Tacomas (2024+)' started by shakerhood, Aug 26, 2021.
  1. Feb 18, 2023 at 12:18 PM
    #2601
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    How about the cost of labor to install that $750 battery?
  2. Feb 18, 2023 at 12:24 PM
    #2602
    pauldotcom
    pauldotcom Well-Known Member
    Paul
    MA
    2012 Toyota Tacoma 4x4 TRD Sport Quad Cab
    OEM Roof Rack, Bilstein 5100's @ 1.75", Rear 1" block, TRD 17' Wheels
    How about the cost and labor of an automatic transmission replacement? Hybrid models no longer use pressurized transmission systems. The "transmission" of a RAV4 hybrid only contains 1 planetary gear set and a few other gears. Nothing else. No bands, no valve body, etc. The simplicity of the transmission is remarkable. Should last the lifetime of the vehicle. But keep your rant going, it's pretty hilarious.
    burnttaco7, willie2 and pushgears like this.
  3. Feb 18, 2023 at 12:54 PM
    #2603
    Turd Ferguson
    Taxachusetts
    You’re deflecting. What’s the cost of a Prius battery replacement including labor? It’s not exactly a DIY project.
    Also are there many transmission replacements required with Tacomas? If there are I’m not hearing about it.
  4. Feb 18, 2023 at 12:56 PM
    #2604
    pauldotcom
    Paul
    MA
    Toyota require transmission replacements time to time, yes. You've never worked in a Toyota Dealership so once again, how can you even talk about this stuff? Hybrid batteries require replacement time to time also, but cost less than a transmission replacement.
  5. Feb 18, 2023 at 1:08 PM
    #2605
    Turd Ferguson
    Taxachusetts
    What’s the cost then?
    Google says this:
    The average cost of replacing a Prius hybrid battery ranges from $2,000 and $4,500. Even if you opt for a used battery, you might still spend about $1,500. Add this to installation costs, additional fees from the mechanic, and repair expenses, and you will be looking at a much higher bill.
    Also, batteries are always going to wear/age out, Transmissions aren’t.
  6. Feb 18, 2023 at 1:42 PM
    #2606
    It's a TRD Thang
    It's a TRD Thang Well-Known Member
    Canada
    2021 Army Green Off Road
    3 inch Leveling kit with 265 75 r16 Ko2's
    You need to look at maintenance cost over the life time vs An ICE vehicle. And no I don't know the cost but I'm sure someone does .
    shakerhood[OP] likes this.
  7. Feb 18, 2023 at 1:55 PM
    #2607
    pauldotcom
    Paul
    MA
    Well if Google says it, it must be true!
    burnttaco7 and doublethebass like this.
  8. Feb 18, 2023 at 2:00 PM
    #2608
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I think the batteries last a long ass time. All the taxis around here are Prius’ with half a million KM. The taxi companies pick the lowest cost to operate machine (fuel, maintenance and repairs) for obvious reason and every taxi sedan I’ve seen is a Prius.
    pauldotcom and Canadian Caber like this.
  9. Feb 18, 2023 at 2:02 PM
    #2609
    shakerhood
    shakerhood [OP] Well-Known Member
    Southern Ohio
    My guess would be maintenance cost between a Hybrid and regular ICE would be pretty similar outside of the battery pack.
  10. Feb 18, 2023 at 2:04 PM
    #2610
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Kind of … except the brakes last a lifetime of the car in the hybrid
  11. Feb 18, 2023 at 2:19 PM
    #2611
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    When a truck has a two battery system. The cost to replace the batteries is double.
    I used to see some Prius cabs, I still see them but they have been retired from cab duty.
    No idea if the Camry cabs I see are Hydrid or not. The most common cab vehicle I see are pre owned ICE sedans Camry, Impala, Malibu, Versa, Caravan. ICE vehicles coming off auction are still way less expensive to purchase and maintain than any other vehicle.
    I like seeing the Cab company dragging their brokedown cabs back to the shop with a tow strap and another cab.
  12. Feb 18, 2023 at 2:26 PM
    #2612
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Yeah I'm very surprised by this is as well. The low end of the model scale guys will be tuning theirs no doubt. Who will be the first to crack GMs tune ? They'll make a killing
  13. Feb 18, 2023 at 2:31 PM
    #2613
    Turd Ferguson
    Taxachusetts
    But a hybrid is still an ICE vehicle and requires all the ice vehicle maintenance. We aren’t talking full EV here.
    Jeff Lange likes this.
  14. Feb 18, 2023 at 2:31 PM
    #2614
    batacoma
    batacoma Truck Wars
    With the exception of Nissan for now, all midsize trucks will have turbos. Things will get interesting.
    Are all the fullsize GM 2.7 trucks rated for the same horse power and torque?
  15. Feb 18, 2023 at 2:32 PM
    #2615
    Turd Ferguson
    Taxachusetts
    If you know so much then why don’t you just tell us how much a Prius battery replacement is at your dealership. Stop stalling.
  16. Feb 18, 2023 at 2:41 PM
    #2616
    Turd Ferguson
    Taxachusetts
    Google is pretty effing amazing. You guys should try it sometime. :D
    “Toyota says a Prius battery will last between 100,000-150,000 miles or between 8-10 years. However, there are owners that have eked out far more mileage, as well as others who’ve reported fewer.”
  17. Feb 18, 2023 at 2:41 PM
    #2617
    It's a TRD Thang
    Canada
    I'm more worried how long it takes before you need to replace it the how much. If it takes 10 years all the Gas you save can pay for it
  18. Feb 18, 2023 at 2:43 PM
    #2618
    Turd Ferguson
    Taxachusetts
    See post above.
    It depends on how much more the hybrid costs up front and how many mpgs you actually gain. It doesn’t would like it will be much gain except for maybe around town.
  19. Feb 18, 2023 at 2:52 PM
    #2619
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    Hey Turd, do you ever get tired of polluting threads with your trolling?
  20. Feb 18, 2023 at 2:54 PM
    #2620
    Turd Ferguson
    Taxachusetts
    Not really.
    Lt. Dangle, SwollenGoat and Malvolio like this.
