4th Gen Tacoma (2024+)
Discussion in '4th Gen. Tacomas (2024+)' started by shakerhood, Aug 26, 2021.
  1. Feb 21, 2023 at 10:09 PM
    #2741
    SwollenGoat
    SwollenGoat Onwards and Upwards!
    ‘21 ACLB, ‘99 XCLB, ‘92 RC, ‘85 4R
    Hells to the yeahs! E-Starters are so overrated.
    https://www.youtube.com/watch?v=EnvG2NrAS3c
  2. Feb 21, 2023 at 11:44 PM
    #2742
    jmodz
    jmodz Well-Known Member
    San Diego
    2014 Regular Cab 4x4
  3. Feb 22, 2023 at 4:56 AM
    #2743
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    LOL, don't confuse the prognosticators with logic, they'll continue pull numbers out of thin air as if they were gospel.
    SwollenGoat likes this.
  4. Feb 22, 2023 at 6:26 AM
    #2744
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    Wow! A $228 a year savings. That’s life changing money right there. :D
  5. Feb 22, 2023 at 6:32 AM
    #2745
    Da Voke
    Da Voke Well-Known Member
    Canada
    2020 DCLB Sport (Stolen and recovered)
    There’s 3 waiting lists via Tacomaworld
    1. To buy it
    2. To complain about it
    3. To buy it and complain about it
    o_O
    Soonr1, MadDaddy, Hogleg918 and 12 others like this.
  6. Feb 22, 2023 at 7:07 AM
    #2746
    SwollenGoat
    Lol!
    Recently read a book on how statistics and numbers are used to persuade people. If one really wanted to save money on a new vehicle purchase, buy the cheapest gasser you can find.
    willie2, Newwt, Foushee and 1 other person like this.
  7. Feb 22, 2023 at 7:39 AM
    #2747
    OldSaltyDog
    OldSaltyDog Well-Known Member
    Hampton Roads VA.
    2022 DCSB Limited Nightshade Edition in Magnetic Grey
    None to speak of, just enjoying it for the moment.
    MFR's employed start/stop tech to get to mandated CAFE regulations. It is not, nor has it ever been good for the consumer WRT reliability and longevity. In fact, current start/stop tech has a clear adverse effect on engine longevity. MFR's continue research to create bearings that won't be damaged during the start/stop process but while making small gains have not resolved this major drawback. Remember, start/stop tech is NOT for the consumer but to allow MFR's to meet their average CAFE MPG requirements. It is used as an easy way to improve the numbers at the known compromise of reliability and longevity. It is, at this point, industry common knowledge that SST is not consumer friendly, good for engines or popular. Your dad's old saying that 90% of engine wear occurs during startup and shutdown was absolutely true.
    SwollenGoat and Foushee like this.
  8. Feb 22, 2023 at 9:47 AM
    #2748
    DRAWN
    DRAWN Well-Known Member
    2016 QUICKSAND AC SR5 4X4
    Sliders, 6112's, full skids.
    It's really a nonissue these days, this isn't the 1990's. Engine wear occurs on startup when the engine is cold that's what "your dads old saying" applies to. Modern start stop won't activate until your engine has reached operating temp. The starter will get cycled more but modern starters are designed to last up 500,000 cycles as opposed to old school starters which would crap out at 50,000 cycles. Modern synthetics have advanced and new engine bearings are designed to last 250,000-300,000 start cycles for this reason. If you don't like it, like I don't, simply turn it off. Now you don't have to use start stop but your starter and bearings are now much stronger because of it. It won't save you fuel but reducing air pollution does affect other people.
    Malvolio and BC Hunter like this.
  9. Feb 22, 2023 at 11:41 AM
    #2749
    DougNuts
    DougNuts Well-Known Member
    Georgetown, KY
    N/A
    The only start/stop I'm interested in, is if a hybrid motor is doing the work. It's hard to explain how they function differently - I can't stand start/stop on my F150 (so I disabled it), but I love how it works on our hybrid RAV4. Not only that, the RAV4 coasts to a stop, and pulls away ,under electric only power, most of the time.
    BC Hunter, pauldotcom and vanderww like this.
  10. Feb 22, 2023 at 11:45 AM
    #2750
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I'd get the all gas version just to be that guy.
    CrispyTacoLover and Newwt like this.
  11. Feb 22, 2023 at 12:32 PM
    #2751
    TacoTanium
    TacoTanium Well-Known Member
    It could be possible. Some article mentioned the same hybrid in the Lexus RX will be in the next tacoma hybrid. Comparing the weight and transmission, could be close to 30....hoping.
  12. Feb 22, 2023 at 12:41 PM
    #2752
    TacoTanium
    lol...they have had many chances to fix that, especially with 4-8 years of generation gaps. At least have one 'performance' engine and one none, even that would help.
    shakerhood[OP] likes this.
  13. Feb 22, 2023 at 12:44 PM
    #2753
    TacoTanium
    Was there an option to disable it or did you had to do it manually?
  14. Feb 22, 2023 at 1:08 PM
    #2754
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    It's more efficient than an equivalent combustion-only powertrain. They've just decided to stop offering the less efficient equivalent powertrain as an option.
    It's the same strategy, implemented differently.
    Jeff
  15. Feb 22, 2023 at 6:41 PM
    #2755
    Plasmech
    Plasmech Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    Not to hijack this thread (but figured why not since we're probably in a 6-month holding pattern), but how is Tacoma's crashworthiness?
  16. Feb 22, 2023 at 6:43 PM
    #2756
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
  17. Feb 22, 2023 at 6:59 PM
    #2757
    Plasmech
  18. Feb 22, 2023 at 7:08 PM
    #2758
    DougNuts
    Georgetown, KY
    N/A
    There’s a switch on the dash to turn it off, but it resets every time you start the truck. I bought a module that plugs into the switch and leaves it in whatever setting you last had it in. There are also ways to turn it off in the computer, using Forscan.
  19. Feb 22, 2023 at 7:45 PM
    #2759
    pauldotcom
    pauldotcom Well-Known Member
    Paul
    MA
    2012 Toyota Tacoma 4x4 TRD Sport Quad Cab
    OEM Roof Rack, Bilstein 5100's @ 1.75", Rear 1" block, TRD 17' Wheels
    Person experience- My son was hit in the highway, flipped twice ended on the roof (gen 2). Walked away without a scratch
    burnttaco7 and shakerhood[OP] like this.
  20. Feb 22, 2023 at 7:47 PM
    #2760
    shakerhood
    shakerhood [OP] Well-Known Member
    Southern Ohio
    Glad to hear he was ok.
    BC Hunter and CrispyTacoLover like this.
