4th Gen Tacoma (2024+)
Discussion in '4th Gen. Tacomas (2024+)' started by shakerhood, Aug 26, 2021.
  1. Dec 5, 2024 at 7:37 AM
    Tacowrench
    Tacowrench Well-Known Member
    Northern California
    2024 Bronze Tacoma TRD Off-Road
    No issues with my glove box. However, this product appears to work on friction and will scratch the glove box side plastic, imho...
  2. Dec 5, 2024 at 8:35 AM
    dleithaus
    dleithaus Well-Known Member
    Washington State
    2024 TRD OR iForce Max
    The glove box door is spring loaded to push it outward and from the compartment to minimize contact and potential rattling.
    At least that is the way mine is. Feature, not fault.
    Newwt and PDKTaco like this.
  3. Dec 5, 2024 at 8:58 AM
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
    They are all like that but for some reason people can't get over the look of it.
    PDKTaco likes this.
  4. Dec 5, 2024 at 9:07 AM
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    It does not work on friction and will not scratch the side of the glove box. It moves the latching point forward about 3/16 of an inch taking up that sloppy gap that the glove box falls back once you’ve taken your hand off of it, closing it. I’m not sure where you came up with this thought but you are incorrect
  5. Dec 5, 2024 at 9:10 AM
    smugly
    Doug
    From 2005 to 2011, all of the leaf spring suspensions in every Tacoma ever made was improperly designed, which is why they changed it in 2012.
    But by your philosophy, all of those suspensions were good because they all were the same. Incorrect, they all were failures, which is why they constantly failed forcing them to redesign the leaf spring system, and add a leaf in 2012 even though it was the same exact platform since 2005
  6. Dec 5, 2024 at 10:57 AM
    Plasmech
    Plasmech Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    What was wrong with them?
    I'm still driving my 2009 leaf springs with 150k on them every day. That's not to say that I don't think there was a design flaw. I'm just curious as to what it was. Thanks.
  7. Dec 5, 2024 at 11:10 AM
    smugly
    Doug
    Look underneath, you see how yours are reverse sprung. Then go look at every other truck with leaf springs.
    They were under engineered to give you a car like soft ride.
    and there are thousands of cases filed for the second leaf snapping right behind the shackle on the rear side of the leaf spring. This was an incredibly common issue. There was a TSB released for them, but that’s as far as it ever went until they quietly added a fourth leaf in 2012
    (I believe it was in 2012), and in my opinion, they were still under engineered even with the four leaf.
    I ended up like many others putting sumo springs in between the axle and the frame to help take some of the pressure off of the leaf springs.
  8. Dec 5, 2024 at 12:40 PM
    Plasmech
    Does this apply to the TRD Off Road option?
  9. Dec 5, 2024 at 2:18 PM
    Plasmech
    Having my ‘09 inspected tomorrow. Rented a 2024 TRD Sport iForce MAX.
    How do I turn on the display of the hybrid boost gauge?
  10. Dec 5, 2024 at 4:12 PM
    smugly
    Doug
    As far as I know, it was all of them across the board. I do believe the shocks themselves were different between the off-road and the sport and other models but the leaf springs remained the same and we’re doing the same job.
  11. Dec 5, 2024 at 4:14 PM
    smugly
    Doug
    It will be in your dashboard display,
    either on the left side or the right side. Your choice.
    one will display boost, and one ( the blue one) will display the hybrid battery usage.
  12. Dec 5, 2024 at 6:25 PM
    Plasmech
    I had to go into setup and enable it, then add it to one of the displays. I put the turbo boost on the left, and the electric boost on the right.
  13. Dec 5, 2024 at 6:26 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
  14. Dec 6, 2024 at 5:15 AM
    smugly
    Doug
    Bon3h3a6 likes this.
  15. Dec 8, 2024 at 6:00 PM
    Plasmech
    When I was driving the TRD Sport iForce MAX last week, I played around with the 3 different drive modes. To be honest, I did not notice a difference between Eco, Normal, and Sport. What are the different modes supposed to be, exactly?
    Also, what exactly does the green "READY" indicator mean in the lower left corner of the dash?
    Are the two red bars on the dash simply brake light indicators, or do they have additional significance?
    Thanks.
  16. Dec 8, 2024 at 6:16 PM
    PDKTaco
    PDKTaco Well-Known Member
    Montana
    2024 TRD Off-road
    Next time put it tow/haul mode, and press this button for 3-4 seconds until the dash lights up. It’ll make a difference!
  17. Dec 8, 2024 at 6:21 PM
    Plasmech
    What will that do?
    Thanks.
  18. Dec 8, 2024 at 6:25 PM
    BigDaddyJuan
    BigDaddyJuan Well-Known Member
    2024 Black Tacoma SR5
    Lift, tires, fender flares, fangs, engine cover, window tint, window channel deflector, skid plate.
    I don't have the 3 drive modes, just tow haul and ECT on the 4×4 switch.
  19. Dec 8, 2024 at 7:55 PM
    PDKTaco
    Montana
    2024 TRD Off-road
    AKA..TowHaulAss mode, Shuts the Nannie’s off that often limit torque/power, trans holds gears longer, and better throttle response.
    Gmak621 likes this.
  20. Dec 9, 2024 at 3:42 AM
    smugly
    Doug
    The biggest thing I noticed between regular mode and Eco is it uses less of the turbo. The green ready light tells you that the hybrid part of the vehicle is in good functioning order and ready to go much the same way the green and red light is on a Formula One car. And the two red bars at the bottom are just simply brake light indicators
