4th Gen Tacoma (2024+)
Discussion in '4th Gen. Tacomas (2024+)' started by shakerhood, Aug 26, 2021.
  1. Dec 17, 2024 at 3:49 PM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Prices very slightly
    shakerhood[OP] likes this.
  2. Dec 17, 2024 at 5:07 PM
    Plasmech
    Plasmech Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    I wonder why? Perhaps the the dealers asked for more pollen collectors?
    smugly likes this.
  3. Dec 17, 2024 at 5:57 PM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    You can change the brightness and position settings. I can see it with my polarized sunglasses.
    smugly likes this.
  4. Dec 17, 2024 at 6:25 PM
    balong48
    balong48 Well-Known Member
    2011 Silver 4Runner Limited
    Doubtful. 2026 MY we will probably see more options added. Not much usually changes for the 2nd MY of a redesigned vehicle.
  5. Dec 17, 2024 at 6:36 PM
    Plasmech
    Especially when you consider that the 2nd year is really the 2nd half of the 1st year.
    balong48[QUOTED] and TacoBuffet like this.
  6. Dec 17, 2024 at 6:49 PM
    1stDueL22
    1stDueL22 Well-Known Member
    Va. Beach, Virginia.
    2025 Bronze Oxide Off Road LB Premium
    I wonder if the HUD might be able to be retro fitted into the lower models much like heated side mirrors on 4runners. The wires were already in place on models that did not come with the heated mirrors. It was pretty much just plug and play.
    Now I do believe that a special windshield might also be required.
  7. Dec 17, 2024 at 7:26 PM
    Snakepilot
    Snakepilot Well-Known Member
    Tucson, AZ
    2025 Tacoma TRD Pro
    The wires might be there but you probably have to replace the dash pad. Likely not easy or inexpensive.
  8. Dec 18, 2024 at 3:58 AM
    1stDueL22
    Your right, I forgot to mention the dash also.
  9. Dec 18, 2024 at 4:14 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I'd like to see Toyota build more Xtra Cabs for 2025. 4x4 XC are scarce in the northeast region. I'd see two new Orkins on the back of a truck yesterday.
    smugly likes this.
  10. Dec 18, 2024 at 8:19 AM
    foeix
    foeix 24 TRD OR 6MT
    Solar Octane is gone for good - Terra is now available on most trims - and Mudbath is now the TRD Pro color.
  11. Dec 18, 2024 at 8:45 AM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Orange will be back in 2026.
  12. Dec 18, 2024 at 8:59 AM
    Lock24
    Lock24 Well-Known Member
    Western Washington
    Now: 2022 SR5 DCLB V6 4x4 (Was: '24 SR5 DCBL)
    Still thinking I might be up for a trade if / when Toyota offers a Long Bed option paired with the hybrid powertrain in the future (aside from the TH model). Would prefer to keep my SR5 trim level, as it has what I need without paying for a lot of upgrades I won't use, but I could likely convince myself that an OR trim would be okay also. Doesn't look like 2025 is going to do that from what has been shared so far.
  13. Dec 18, 2024 at 9:48 AM
    batacoma
    batacoma Truck Wars
    Solar Octane or something different?
    I saw 3 maybe 4, 24' Solar Octane Prerunners listed all have since sold. Nothing close to me, it was like Okland CA, Texas, and Larry H Miller in CO. There may have been a few others built. I'd have liked to have one, one local dealer had a silver Prerunner, that disappeared from the site in about 2 weeks.
  14. Dec 22, 2024 at 7:51 AM
    Plasmech
    Has it been determined if the IsoDynamic seats can be "self-deleted" by either removing all the shit on the back of them or replacing them with regular seats?
    I'm actually thinking about a Pro now, but I have two kids.
  15. Dec 22, 2024 at 8:21 AM
    CrispyTacoLover
    I bet replacing them with regular seats would not be too hard. They are already wired for power, heating, ventilation, etc. Buy some premium Off-road seats from a wreck where the seat airbags didn’t deploy.
    Plasmech[QUOTED] likes this.
  16. Dec 22, 2024 at 8:36 AM
    Snakepilot
    Tucson, AZ
    2025 Tacoma TRD Pro
    "The IsoDynamic seat as a seat within a seat. The cushions rest on an inner frame that attaches at two points to an outer frame (which itself mounts to the vehicle body). One attachment point is high on the seatback, and the other is a ball joint hidden below the front edge of the thigh cushion. Between these, the seat swings side to side like a hammock, up to an inch in each direction.
    To regulate the IsoDynamic seat's movement, the prominent vertical reservoirs contain pistons that compress chambers of air. The right strut works against lateral swing, and the left one restrains up-and-down motion. Below each piston, oil flows through hoses to pairs of remote cylinders affixed to the seat."
    If you remove the reservoirs and replace the up-down and lateral struts with fixed (smaller diameter) tie rods, you might free up space for a lower profile back cover. Probably not a kit from Toyota/TRD. Big enough market for an aftermarket kit? If you went with an adjustable tie rod/heim joint you could probably find something off the shelf. A custom auto upholster could wrap a wood/plastic/foam panel in red or black softex.
    Plasmech likes this.
  17. Dec 22, 2024 at 9:19 AM
    Plasmech
    What about just removing the covers? How much room does that effectively free up, I wonder.
  18. Dec 22, 2024 at 12:53 PM
    Snakepilot
    Tucson, AZ
    2025 Tacoma TRD Pro
    Bon3h3a6 likes this.
  19. Dec 22, 2024 at 6:33 PM
    Kohan21n
    Kohan21n A caffeine dependent life form - IG @dizzy.trd
    Nazareth, PA
    2016 DCSB MGM 6MT
    Why do you say that? Toyota, for a long time now, will introduce a new color onto the Pro models only for one year. The following year, make it available on the TRD options and then remove it for good after that.
  20. Dec 22, 2024 at 7:17 PM
    CrispyTacoLover
    Wishful thinking on my part. I’m hoping they’ll bring back Inferno. All new colors do not have to be a Pro first. Blue Crush and Supersonic Red are recent examples.
    Kohan21n[QUOTED] likes this.
