4th Gen Tacoma (2024+)
Discussion in '4th Gen. Tacomas (2024+)' started by shakerhood, Aug 26, 2021.
  1. Jan 14, 2025 at 6:56 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Of course not. It isn’t a Baja racing truck!
    :burnrubber:
    BC Hunter likes this.
  2. Jan 14, 2025 at 6:57 PM
    Plasmech
    Plasmech Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    Hmmm. Then what is it?
  3. Jan 14, 2025 at 7:10 PM
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    Gawd that is beyond infuriating. It should be optional or non existent for us, wonder if I can swap them.
  4. Jan 14, 2025 at 7:55 PM
    Snakepilot
    Snakepilot Well-Known Member
    Tucson, AZ
    2025 Tacoma TRD Pro
    I'm sure you could find somebody that would swap you for the iso seats but in return you would get very plain seats. You wouldn't be able to get the red, it would have to be someone with the premium package or you'd lose your ventilation, and probably a hybrid because I think the rear seat is different too.
    Would probably be easier to unbolt the struts and frame. It be easy for an upholsterer to make a new flat back panel.
  5. Jan 15, 2025 at 4:37 AM
    TacoBuffet
    AL
    If the 4Runner Pro has the same seat pattern but not iso in theory I should be able to swap with them and same interior.
    Snakepilot[QUOTED] likes this.
  6. Jan 15, 2025 at 4:45 AM
    Johnny919
    Johnny919 Well-Known Member
    Long Island, NY
    2006 Honda Pilot EXL 4WD
    I love how they now charge for a spray in bed liner when it's composite. :rofl:
    dneal likes this.
  7. Jan 15, 2025 at 4:54 AM
    Plasmech
    I've been told that the ScudRunner looks a lot better in person than it does in the marketing material.
    The TRD Pro and the Offroad Premium both intrigue me.
  8. Jan 16, 2025 at 5:44 PM
    Plasmech
    Would it be reasonable or would it be foolish to assume that the Gen 6 4Runnner is effectively one year ahead in debugging time due to the Gen 4 Tacoma preceding it? In other words, is the 2025 model year effectively the 2nd year?
  9. Jan 17, 2025 at 4:43 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    No it's a different vehicle that does happen to share drivetrain components. Presumably the 4Runner will have an engine manufactured in Japan, unless Toyota is shipping engines to Japan and sending completed units back. Which could be what they are doing, the LC 250 production process could answer that question.
    I still think 4R and LC 250 production will move to Mexico when the time is right. This will also be the 2nd year of LC 250 production.
    Plasmech[QUOTED] likes this.
  10. Jan 17, 2025 at 12:22 PM
    1stDueL22
    1stDueL22 Well-Known Member
    Va. Beach, Virginia.
    2025 Bronze Oxide Off Road LB Premium
    This is why I REFUSE to pay for that. Get me a truck without it or don't charge me for it.
    Johnny919[QUOTED] likes this.
  11. Jan 17, 2025 at 1:11 PM
    Snakepilot
    Tucson, AZ
    2025 Tacoma TRD Pro
    At first I thought the bed liner on a composite bed was stupid. Right now I have a mat to keep stuff from sliding around and I hear the 4g bed is slicker. When I haul tree trimmings or pick up a load of gravel (you know, truck stuff) leaves, twigs, small rocks, etc end up under the mat. Pulling out the mat so I can blow or hose out the bed isn't a big deal but having a non skid texture and not having to pull the mat out is appealing. Yes, $140 for the mat vs $575 for the spray is a big increase but I'm leaning towards the spray-on liner. Also the PPO dealer cost for the spray-on is $450, so you might be able to to tell them "give it me at cost or find me a truck without it".
  12. Jan 17, 2025 at 2:07 PM
    Johnny919
    Long Island, NY
    I wouldn't be surprised if they made the 4th gen bed slicker on purpose to get you to pay more for mat/spray in.
    shakerhood[OP] likes this.
  13. Jan 17, 2025 at 2:49 PM
    Hogleg918
    Hogleg918 Well-Known Member
    Oklahoma
    Ranger Raptor, sorry TW
    Tacoma beds: Now with more Crisco!
  14. Jan 17, 2025 at 4:31 PM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    Aftermarket bed mats from Lasfit and Triplealiner have an upward lip around the outer rim. Yes some dirt intrusion can stlll get in between, but they don't seem to be the dirt magnet like the crack that exists between the oem mat and our beds. At least you can hose the bed down and not have the slurry channel into that crack the oem mat has.
  15. Jan 18, 2025 at 1:19 PM
    Braunschwaga
    Braunschwaga AyeeeeVita
    A-A-Ron
    Kauai, HI
    Possible, pinouts would need to match though. 4Runner Pro has a power recline, Tacoma Pro has a manual recline lever
    TacoBuffet[QUOTED] likes this.
  16. Jan 18, 2025 at 3:08 PM
    Snakepilot
    Tucson, AZ
    2025 Tacoma TRD Pro
    The vehicle harness/connector is probably the same for all Tacomas. I believe all 3g seat were prewired for heat. Ther's probably an always hot for the fore-aft/recline motors and switched power for the heated seats. The seat connector determines where that power goes. TacoBuffet should buy both Pros and do the swap. 4R has enough rear seat room that the bigger seats won't be an issue. Win-win.
  17. Jan 18, 2025 at 3:18 PM
    Braunschwaga
    A-A-Ron
    Kauai, HI
    I would typically agree with you there as some prior models shared the same harness and could accept parts of other trims. However, we are not seeing the same scenario is this current generation, harnesses looks to be different in some areas of the vehicle and or missing on certain trims (i.e. base level TRD to TRD Premium). But you are right as the seat would in theory only call for power as functions should be contained within the seat itself. Guess he needs to be the guinea pig for all of us lol
  18. Jan 30, 2025 at 7:36 AM
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
  19. Feb 3, 2025 at 12:52 PM
    Frankmig
    Frankmig Well-Known Member
    2019 4x4 DCSB TRD Sport Tacoma White
    Predator step up bars, Tonneau cover OEM
    Today I just started having issues with my JBL Premium Audio. The system has been fine the first 2 weeks of ownership. However, today, it started sounding very muffled. It is only the HD Radio. When I play music via the phone/Apple Music it sounds great. I didn't make any settings changes today. It just started doing that on it's own. I am now at the dealer and they are telling me 2 hours to "diagnose" the issue as the truck and system is so new that Techs are still training, etc. I am a little annoyed.
  20. Feb 3, 2025 at 3:33 PM
    CrispyTacoLover
    Have you looked at the built-in equalizer settings?
