4th Gen Tacoma (2024+)
Discussion in '4th Gen. Tacomas (2024+)' started by shakerhood, Aug 26, 2021.
  1. Apr 19, 2023 at 12:43 PM
    #5641
    SwollenGoat
    SwollenGoat Onwards and Upwards!
    ‘21 ACLB, ‘99 XCLB, ‘92 RC, ‘85 4R
    Lol!
  2. Apr 19, 2023 at 12:43 PM
    #5642
    PendulumRC
    PendulumRC Well-Known Member
    NC
    How long does the battery last in a Toyota hybrid? Seems like something else to have to worry about long term. And wondering if better mpg's in a turbo Tacoma would be enough to make up for the cost of replacing that eventually.
  3. Apr 19, 2023 at 1:26 PM
    #5643
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    Look up “Toyota Prius.”
    Toyota isn’t new to it. I (me) would expect 8-10 years or north of 100k miles. Similar to said Prius.
    BC Hunter and Crash415 like this.
  4. Apr 19, 2023 at 1:33 PM
    #5644
    pauldotcom
    pauldotcom Well-Known Member
    Paul
    MA
    2012 Toyota Tacoma 4x4 TRD Sport Quad Cab
    OEM Roof Rack, Bilstein 5100's @ 1.75", Rear 1" block, TRD 17' Wheels
    I've worked on several Prius with over 300k on the original battery.
    RAV4 is similar to prius hybrid design; I can get 50mpg if I drive like there is an egg under the pedal.
    Bonus with the Rav4 hybrid is- they don't have a traditional transmission. Meaning it's not a pressurized hydraulic unit and it's super simple. 1 planet gear and a couple heavy duty gears. Non-pressurized and not much in it that will break.
  5. Apr 19, 2023 at 1:40 PM
    #5645
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    That’s a good explanation. This use of a hybrid just as a power boost seems pointless to me. A more complicated and expensive system plus losing the under seat storage seems like a lot of negatives. If they made a plug-in hybrid truck where you could actually drive locally without needing gas that would be great. Especially if you have solar panels at your home.
  6. Apr 19, 2023 at 2:05 PM
    #5646
    pauldotcom
    Paul
    MA
    As I said, it isn't simply just for power. The driving experience is better- especially acceleration.
  7. Apr 19, 2023 at 2:31 PM
    #5647
    It's a TRD Thang
    It's a TRD Thang Well-Known Member
    Canada
    2021 Army Green Off Road
    3 inch Leveling kit with 265 75 r16 Ko2's
    Last time I checked you're not an engineer. Probably why it seems pointless to you. And furthermore I feel this is the 10th time you have complained about it
    Lt. Dangle likes this.
  8. Apr 19, 2023 at 3:09 PM
    #5648
    Turd Ferguson
    Taxachusetts
    Where did you check? My degree and license say otherwise. :eek:
    Are you in charge of what we are allowed to discuss here?
    pauldotcom and Dirty Harry like this.
  9. Apr 19, 2023 at 3:41 PM
    #5649
    holvey
    holvey Well-Known Member
    Brian
    Portland, OR
    2020 DCSB TRD OR
    I wouldn't call it pointless, but I would call it a missed opportunity. Toyota has been the leader in Hybrid tech to increase fuel efficiency for over 25 years and the first time they use it in an actual pickup truck lands the fuel economy in the middle of the pack seems like it misses the mark. Sure the power numbers are impressive, but I think having a Tundra hybrid system on an SR5 trim that produced a modest 300 hp / 350 ftlb torque and got 25-30 mpg would have been huge for Toyota.
    Nothing in the teasers for the Tacoma indicate improved fuel economy which is kind of a bummer.
  10. Apr 19, 2023 at 4:18 PM
    #5650
    mosccat
    mosccat Well-Known Member
    Mark
    Currently in Bend, OR
    2020 OR
    That’s a negative for me, love my wife’s RAV4 but can’t stand the transmission.
    shakerhood[OP] likes this.
  11. Apr 19, 2023 at 4:28 PM
    #5651
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    Hybrid powertrains in Tundra/Sequoia & upcoming Tacoma emphasize greater torque and lower emissions. If it also picks up a couple mpg’s that’s a bonus but don’t expect your ‘24 Taco to compete w your neighbor’s Prius.
    Toyota needs to roll this baby out already b/c the anticipation level right now has people speculating the Gen4 writing checks that the actual finished truck will never cash. It’s like if you dream it up, just post it & Toyota will magically weld it onto the new truck for you….
    For now I much prefer my current reality complete w V6, drums, leafs, and missing grab handle…
  12. Apr 19, 2023 at 4:43 PM
    #5652
    SwollenGoat
    The reasoning behind it is, Mike Sweers wanted a diesel for the Tundra (and assuming the Tacoma), Toyota said no. Hybrid boost was the compromise. While no real gains for mpg, it does give low end diesel like torque.
    https://carbuzz.com/news/toyota-wont-rule-out-plug-in-hybrid-tundra
    Toyota is probably right no matter how much some of us complain about never getting a diesel (other than that lack luster attempt in the 80s). Small diesels came too late, and are insanely overly complicated plus crazy expensive now. Ram and GM both tried small diesels and they mostly failed with poor sales. GM cancelled it the Colorado, think Ram is phasing them out too.
    Diesels made sense when there was very little emissions and when fuel was cheap. Toyota missed that window long ago. Gotta say, living in Idaho, tons of de-smogged diesels here, following behind them sucks. Roll up the windows and close off the “fresh air” vent, otherwise you get fumed out.
  13. Apr 19, 2023 at 5:01 PM
    #5653
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I see no drawback to using hybrid power to fill in the gaps of an ICE. Other than cost and complexity of course. But from a sheer driving experience? Bring it on.
  14. Apr 19, 2023 at 5:18 PM
    #5654
    shakerhood
    shakerhood [OP] Well-Known Member
    Southern Ohio
    I am expecting Toyota to introduce a unibody pickup at some point like the Maverick. If they use the Rav4 platform it already has hybrid set up for MPG.
    BC Hunter, Dirty Harry and Lt. Dangle like this.
  15. Apr 19, 2023 at 5:22 PM
    #5655
    Lt. Dangle
    Ohio
    Aren't they working on the Stout? Or is that a rumor I have seen too many times?
  16. Apr 19, 2023 at 5:24 PM
    #5656
    shakerhood
    Southern Ohio
    I "think" they are, but every time I delve into the subject its hard to tell fact from fiction.
    Lt. Dangle[QUOTED] likes this.
  17. Apr 19, 2023 at 5:24 PM
    #5657
    Lt. Dangle
    Ohio
  18. Apr 19, 2023 at 5:25 PM
    #5658
    Lt. Dangle
    Ohio
    I just tried looking for some info and it's all renders and inuendo lol.
  19. Apr 19, 2023 at 5:47 PM
    #5659
    SwollenGoat
    There was the A-Bat Concept way back in 2007 or so. Seemed odd back then, but now with the Hyundai, Ridgeline and Maverick, maybe not so weird anymore. Toyotas styling as of late has been a bit off the rails. Definitely didn’t buy my Tacoma because of how it looks, the front clip/grill is awful.
    https://www.motortrend.com/vehicle-genres/toyota-a-bat-concept-truck/
  20. Apr 19, 2023 at 5:54 PM
    #5660
    Lt. Dangle
    Ohio
    That's still weird lol. The concept is strong now though.
    More like this ideally. Although some flunky background car from a failed 90's sci fi show would certainly be unique.
