4th Gen Tacoma (2024+)
Discussion in '4th Gen. Tacomas (2024+)' started by shakerhood, Aug 26, 2021.
  1. May 12, 2023 at 10:23 AM
    #6961
    mosccat
    mosccat Well-Known Member
    Mark
    Currently in Bend, OR
    2020 OR
    I towed this 8k miles last year, 5,000lb loaded. Hopefully newer gen transmission will have torque converter lock up in 3rd gear.
  2. May 12, 2023 at 10:56 AM
    #6962
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    That's not what Toyota does. They have explained time and time again there not looking at trying to beat everyone on the spec sheet. They put the tundra engine in the Tacoma then someone just one ups them the next year. Toyota doesn't play those games. The competition always finds a way to tweak something here and there and then there class leading in whatever the next year.
  3. May 12, 2023 at 11:01 AM
    #6963
    gray223
    SE Missouri
    2014 Tundra Limited
    That is the estimated city/hwy numbers for the Lexus 500h. Which has a hybridized 2.4l turbo 4cly
    And it weighs more then a 3rd gen
  4. May 12, 2023 at 11:03 AM
    #6964
    Plasmech
    Plasmech Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    Will Mike Sweers likely speak next Friday?
    I can't decide if I like that guy or not.
  5. May 12, 2023 at 11:25 AM
    #6965
    SwollenGoat
    SwollenGoat Onwards and Upwards!
    ‘21 ACLB, ‘99 XCLB, ‘92 RC, ‘85 4R
    Given how erratic my trans is just towing my small moto trailer, and having the bed full of crap. No way I would attempt towing that TT. Weird, the same load in my less power 1st Gen manual trans didn’t bother me. Should have ponied up the extra $5K and got a Sport with the manual.
    Have towed earth moving equipment in a past life, so used to towing heavy. All of those dump trucks were manuals. If I am pulling a grade, like to stick it a gear and stay there, even if I have to drive slow. The Taco’s trans doesn’t know what to do, even in S mode. Doing something that could be done in 4th, and wants to bounce to and fro between 3rd. Ok guess we are going it 3rd…
    GladiatorNOT likes this.
  6. May 12, 2023 at 11:35 AM
    #6966
    mosccat
    Mark
    2020 OR
    Before our trip I reset the ECU’s and the trans learnt how i tow. Can pull along quite nicely in 5th at 63mph/1,700rpm (without ECT). Just did the pull from Phoenix to Flagstaff with the 5,000lb TT, a 6kft+ elevation gain averaged 11.5mpg up there on the 150mile leg. The only thing I wish for is the torque converter locked in 3rd.
    SwollenGoat[QUOTED] likes this.
  7. May 12, 2023 at 12:15 PM
    #6967
    SwollenGoat
    Good to hear. Lived in AZ for 20 years, know that route quite well. Was going to get a tune, fear it would void my warranty.
    Maybe I need to reset mine. Around town it is great. Even doing little day trips with the trailer, with virtually no load, it is very sensitive to the slightest change, couple degrees of a grade or slight headwind it is constantly shifting.
  8. May 12, 2023 at 12:26 PM
    #6968
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    You’re probably right. After all, Toyota did tell us repeatedly that Tundra Pro owners didn’t even want a rear locker, until they installed one in ‘22.
    Then again, there’s also the Toyota that turbo’d a 3cyl an inch from exploding, stuffed it under the hood of a Corolla hatchback complete w AWD & manual. After that, who’d be offended by a simple 3.4T dropped into a 55k TRD Pro?
    Halo trucks are not my thing personally, but Ford/GM/Stellantis like to keep score and I guarantee that Toyota’s engineers do too. They want to beat ZR2/Raptor. And that’s good for us.
  9. May 12, 2023 at 12:34 PM
    #6969
    mosccat
    Mark
    2020 OR
    I was thinking about a tune, likely would have gone with kdmax, but at $500 I didn’t see the value.
    The taco is very capable if you set your expectations and drive the transmission/torque converter correctly.
    Towed over 8,000 miles, over 65,000ft of elevation gain with no problems. The only time the taco struggles is up a grade into a 15mph headwind at 55mph, need that 3rd gear to lockup. Averaged 12mpg in total.
  10. May 12, 2023 at 12:45 PM
    #6970
    jaxyaks
    jaxyaks Well-Known Member
    2020 Silver Tacoma TRD Off Road
    If they put the Turbo V6 (non hybrid) that is in the Tundra in the Tacoma, nobody is going to need to one up them, it still doesn't beat the Ranger.
    gray223[QUOTED] likes this.
  11. May 12, 2023 at 12:49 PM
    #6971
    SwollenGoat
    Have been driving manuals for 40 years, guess not used to slush boxes. It doesn’t know what to do, I don’t know what to do…it is hot mess! Lol!
    GladiatorNOT and tcaustin like this.
  12. May 12, 2023 at 1:17 PM
    #6972
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I took a pair of 2x8’s and shaved them down in the mount area so they fit like a pair of 2x4’s. Easier to manage since it’s only 2 boards.
    Also, I intend to do the tailgate leash mod where you add another clip point for the tailgate tethers that leaves the tailgate elevated, and at the same height of the 2x4 crossbeams. Three points of contact.
  13. May 12, 2023 at 1:29 PM
    #6973
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    Exactly ford did it right. I sure hope they do. I forgot toyota has 3 version of the v6 with 358hp with 406tq on the base sr tundra. Hope the tacoma get that version.
  14. May 12, 2023 at 1:49 PM
    #6974
    shakerhood
    shakerhood [OP] Well-Known Member
    Southern Ohio
    I'd say there is a zero chance that an engine from the Tundra ends up under the Tacoma's hood.
    Bedawson, TacoJoe412, DRAWN and 5 others like this.
  15. May 12, 2023 at 2:06 PM
    #6975
    It's a TRD Thang
    It's a TRD Thang Well-Known Member
    Canada
    2021 Army Green Off Road
    3 inch Leveling kit with 265 75 r16 Ko2's
    The new automatics are not slush boxes :rofl:
  16. May 12, 2023 at 2:47 PM
    #6976
    SwollenGoat
    All automatics are slush boxes! :p
    Have been driving my 1G before it went into the shop for a new engine. Kinda miss driving a manual. Was considering trading in for a manual ACLB Sport, but now with the 4G on the horizon, going to wait and see.
    StandardTaco likes this.
  17. May 12, 2023 at 3:10 PM
    #6977
    It's a TRD Thang
    Canada
    The reason I don't want a daily driver as a manual...too much stop and go here . Plus I hate shifting when I'm holding a "pop" on a forest service rd lol
    DRAWN likes this.
  18. May 12, 2023 at 4:05 PM
    #6978
    SwollenGoat
    We do get traffic here, schedule my days to mostly avoid it. 75% of my commute are ranch roads, almost hit some ditch chickens on the way in this morning.
    Baaaaah, have driven with my right clavicle broken before (twice) holding a beverage taint no problem!
    “Pop” ha! Haven’t heard it call that since I lived in PA.
    shakerhood[OP] likes this.
  19. May 12, 2023 at 4:43 PM
    #6979
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    Thats awful. Not a fan of the tablet stuck to the dash look. Much prefer the screen integrated into the lines and flow of the dash.
    ExplorHer likes this.
  20. May 12, 2023 at 4:46 PM
    #6980
    RushT
    North Texas
    Tell that to the modern dual clutch autos….
    My Macan was stellar. I get what you’re talking about though…. Torque converter automatics.
