4th Gen Tacoma (2024+)
Discussion in '4th Gen. Tacomas (2024+)' started by shakerhood, Aug 26, 2021.
  1. May 20, 2023 at 4:51 PM
    #8101
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    At 5:08 they show the auto start/stop disable button on the prerunner :thumbsup:
    https://youtu.be/POZkV2CWDwQ
  2. May 20, 2023 at 4:52 PM
    #8102
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    Ford has the same exact bumper steps as Chevy now.
    burnttaco7 likes this.
  3. May 20, 2023 at 5:05 PM
    #8103
    ManInTheMaze
    ManInTheMaze Well-Known Member
    Mendo
    2003 and 2017
    I am kinda interested to see what a shell looks like on a 4th gen. The cab spoiler doesn't look removable, which might make for a funky-looking shell situation.
  4. May 20, 2023 at 5:08 PM
    #8104
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Definitely would be a challenge with the trailhumper :)
    Lawfarin likes this.
  5. May 20, 2023 at 5:20 PM
    #8105
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    No they don't. Ford's are on the side while GM's are in the corner.
    Lt. Dangle likes this.
  6. May 20, 2023 at 5:22 PM
    #8106
    RedWings44
    Michigan
    TFL was estimating $57k for TRD Pro and Trailhunter based on GM and Ford.
  7. May 20, 2023 at 5:23 PM
    #8107
    RedWings44
    Michigan
    The explanation I heard is that Trailhunter is geared toward rock crawling while TRD Pro was geared more toward desert running.
    BC Hunter likes this.
  8. May 20, 2023 at 5:31 PM
    #8108
    mikekoot
    mikekoot Well-Known Member
    MIKE
    Castlegar BC
    14 ssm dclb sr5/18 tundra
    So 80k canadian :(
  9. May 20, 2023 at 5:31 PM
    #8109
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
  10. May 20, 2023 at 5:33 PM
    #8110
    RyanDCLB
    4/19 DCLBOR
    i-Force Max Hybrid powertrain models have a 9.5" rear axle to handle the power. All other models will come with the 8.5" rear axle. :notsure:
    BSM sensor is still located above the bumper and below the taillights. :frusty:
  11. May 20, 2023 at 5:35 PM
    #8111
    trazerr
    Oregon
    both have them in the bumper is what i meant. Pretty dang similar to the point that I bet any manufacturer could use them now.
    Edit: and both Chevy and ford have the side steps now. I’m not sure if those would be as useful as the bumper ones though.
  12. May 20, 2023 at 5:35 PM
    #8112
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    3rd Gen Tundra WCP TRD OR I-Force Max
    Saw the 4th gen Taco in person today. Makes you wonder if Toyota did this so you can easily remove that pad off and stuff 35s in hmmm... :fingerscrossed: This is the front right wheelwell:
    supralee and Gmak621 like this.
  13. May 20, 2023 at 5:36 PM
    #8113
    RyanDCLB
    4/19 DCLBOR
    Limited is the first mid-size with power folding steps. :cool:
    The Chief Engineer said the chin spoiler is meant to be removable for trail use. :rolleyes:
  14. May 20, 2023 at 5:39 PM
    #8114
    Lord Helmet
    Nick
    They also beefed up the front bumper part. Same wheelwell but behind front bumper. That part looks like it's gusseted.
  15. May 20, 2023 at 5:42 PM
    #8115
    Lord Helmet
    Nick
    Spring under axle aka SUA on the trd prerunner :thumbsup:
    supralee and shakerhood[OP] like this.
  16. May 20, 2023 at 5:44 PM
    #8116
    RyanDCLB
    4/19 DCLBOR
    Trailhunter and Pro come with high-lift jack points in the rear next to the tow points.
    Chief Engineer said no plastic cover over the engine. :pout:
  17. May 20, 2023 at 5:44 PM
    #8117
    Lord Helmet
    Nick
    I dig the TH in person :thumbsup:
    Also just to make sure everyone knows you have a Toyota: :rofl:
  18. May 20, 2023 at 5:44 PM
    #8118
    RedWings44
    Michigan
    I'll admit I didn't see those ones. I saw the ones on the new Ranger.
  19. May 20, 2023 at 5:53 PM
    #8119
    RyanDCLB
    4/19 DCLBOR
    The i-Force Max Hybrid models (1.8 kw Nimh battery) have an additional 2400 watt plug located on the inside behind the center console. :thumbsup:
    Trailhunter mid-skids are composite material. It also features a metal rear diff skid.
  20. May 20, 2023 at 5:59 PM
    #8120
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    What does that color look like in person? Green, gray, brown?
