4th Gen Tacoma (2024+)
Discussion in '4th Gen. Tacomas (2024+)' started by shakerhood, Aug 26, 2021.
  1. May 30, 2023 at 7:52 AM
    #9041
    jaxyaks
    jaxyaks Well-Known Member
    2020 Silver Tacoma TRD Off Road
    You can always just get the non hybrid
    Lt. Dangle, stevesnj and JTacoma4life like this.
  2. May 30, 2023 at 7:58 AM
    #9042
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    I believe that is the turbo version, correct?
  3. May 30, 2023 at 8:01 AM
    #9043
    It's a TRD Thang
    It's a TRD Thang Well-Known Member
    Canada
    2021 Army Green Off Road
    3 inch Leveling kit with 265 75 r16 Ko2's
    They are all turbo....
    burnttaco7, Lt. Dangle and DRAWN like this.
  4. May 30, 2023 at 8:02 AM
    #9044
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    All the 2024 Tacoma's have a 2.4l turbo 4 cyl engine.
    The hybrid version just has an electric motor between the 2.4l turbo engine and its transmission.
    BC Hunter and Lt. Dangle like this.
  5. May 30, 2023 at 8:15 AM
    #9045
    crepr12
    crepr12 Well-Known Member
    25 Limited Hybrid
    a troll with 5K+ post?...So not a troll...but what gives Smugly with a little s...i dont get it..Just keep your 3rd gen...
    Rocko likes this.
  6. May 30, 2023 at 8:27 AM
    #9046
    jaxyaks
    They both have the turbo...
  7. May 30, 2023 at 8:41 AM
    #9047
    smugly
    Doug
    I get what they’re saying in that video, but that still doesn’t verify that it’s the same exact system in the new Tacoma. And if in fact, it is the same system, then I go right back to my original statement on here that the four-cylinder motor will be aggressively inadequate when towing when you have run out of battery power because it is not a V6 TwinTurbo that is in the Tundra, which is twice the motor as the one they’re offering in the Tacoma. In other words, you don’t get the pretty torque numbers that they’re trying to post up as soon as you’re out of battery power. You’re right back to a car engine in a truck.
  8. May 30, 2023 at 8:45 AM
    #9048
    Plasmech
    Plasmech Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    If this were the case (and maybe it is), the Tundra boys would be talking about it.
    stevesnj likes this.
  9. May 30, 2023 at 8:46 AM
    #9049
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    The engine is directly connected to the wheels, it is not just an electric motor, in fact the electric motor is relatively weak compared to the combustion engine.
    Also, the towing capacity of the non-hybrid will likely be the same, so if the battery is depleted, you’ll probably still have better towing torque than the current V6.
    Jeff
  10. May 30, 2023 at 8:47 AM
    #9050
    smugly
    Doug
    Not trolling, just trying to weed though all the bullshit to get to the fax about the new Tacoma on here, all the facts are lost within all the other gibberish going on on this thread that is supposed to be ONLY for the new Tacoma. It’s hard to read through the 6 to 10 pages of non- 4th generation Tacoma gibberish going on every single day.
    And the 3rd gens are not gonna last forever.
    enforcertaco91 likes this.
  11. May 30, 2023 at 8:47 AM
    #9051
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    The engine alone will have enough to tow if the battery depletes. Just don't tow more than they say or don't buy the truck at all. The battery is always being recharged.
    brtnstrns likes this.
  12. May 30, 2023 at 8:48 AM
    #9052
    smugly
    Doug
    Why would they be talking about it, they gave them a sufficient engine without electrical?
  13. May 30, 2023 at 8:48 AM
    #9053
    stevesnj
    Yes, even in the video I showed you he says that.
    smugly[QUOTED] likes this.
  14. May 30, 2023 at 8:49 AM
    #9054
    smugly
    Doug
    Let’s see you go through the hills of West Virginia with 6000 pounds and a four-cylinder engine
  15. May 30, 2023 at 8:50 AM
    #9055
    stevesnj
    It will be fine.
  16. May 30, 2023 at 8:51 AM
    #9056
    smugly
    Doug
    And next time don’t be afraid to tag somebody so that they can see what non-useful gibberish you have wrote about them that doesn't pertain to the topic.
  17. May 30, 2023 at 8:53 AM
    #9057
    It's a TRD Thang
    Canada
    Buy a full size , the max tow is 6000lbs on this truck . I think 6500 on the non hybrid. Have you even watched any of the videos where this info is available. There is a really good video the tfl guys did with Sheldon the engineer you should watch. It will answer some of these questions until we get some real life driving experience videos in 4 months
  18. May 30, 2023 at 8:54 AM
    #9058
    jaxyaks
    They have already said the towing on the non hybrid is 6500 lbs and the hybrid is 6000
    BC Hunter, DRAWN and stevesnj like this.
  19. May 30, 2023 at 8:55 AM
    #9059
    smugly
    Doug
    Do any of these videos actually specifically talk about the brand new fourth generation motor in the Tacoma
  20. May 30, 2023 at 8:56 AM
    #9060
    It's a TRD Thang
    Canada
    Not in super detail because no one has one to do that yet . If you are looking for one like the one posted on the Tundra you will have to wait . I know this engine is already in a different vehicle though but I can't remember which one , maybe on of the other guys have that info on here
