4th Gen Tacoma (2024+)
Discussion in '4th Gen. Tacomas (2024+)' started by shakerhood, Aug 26, 2021.
  1. Jun 3, 2023 at 11:42 AM
    #9221
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    TFL has a video test driving one of them and mentioned the mpgs of each. It seemed odd that the max gets so much worse mpg so I confirmed on Toyota’s website.
  2. Jun 3, 2023 at 11:48 AM
    #9222
    Turd Ferguson
    Taxachusetts
    That would make a lot if sense. It seems crazy to lose 10 mpg just to gain more horsepower that’s not even needed for the majority of time driving.
  3. Jun 3, 2023 at 1:04 PM
    #9223
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Yeah, but the regular non-max hybrid has all those components too.
  4. Jun 3, 2023 at 1:25 PM
    #9224
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    That 2.5l isn't even turbo charged and doesn't make much power, hence why the mpg is so much better. Looks like a Grand Highlander max is almost 5000 pounds. I guessing the Tacoma be lighter? Surely we could get 25mpg on the highway...
    wrmathis likes this.
  5. Jun 3, 2023 at 2:21 PM
    #9225
    Turd Ferguson
    Taxachusetts
    So if you added a turbo to that 2.5 engine you would lose 10 mpg? That doesn’t make much sense?
  6. Jun 3, 2023 at 2:56 PM
    #9226
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
    It does when you look at the numbers:
    Hybrid Max powertrain — 2.4-liter 4-cylinder turbo Hybrid MAX 16-valve D-4S injection engine with Dual Variable Valve Timing with intelligence (VVT-i); 362 net combined hp @ 6000 rpm, 400 lb.-ft. @ 2000-3000 rpm
    Gasoline engine — 2.4-liter 4-cylinder turbocharged 16-valve D-4S injection engine with Dual Variable Valve Timing with intelligence (VVT-i) and Stop and Start Engine System; 265 hp @ 6000 rpm, 310 lb.-ft. @ 1700-3600 rpm
    Hybrid powertrain — 2.5-liter L4HV Double Overhead Cam (DOHC) 16-valve D-4S injection engine; 245 combined net hp, 175 lb.-ft. @ 4400 rpm
    Only one of those hybrids are meant for fuel savings.
    gray223 likes this.
  7. Jun 3, 2023 at 3:15 PM
    #9227
    taco_rhyno
    taco_rhyno Well-Known Member
    06 DC 4x4 Sport
    Toyota’s hybrid max configuration is designed to maximize performance while getting decent-ish mpg.
    While it is not the Hybrid Max drive train (it is the Direct 4 architecture) the 400 foot pounds of torque and 28MPG is great in my wife’s RX500h. The normal RX350h has 120 less HP and gets 36MPG. I like the zoom.
    In the Tacoma the Hybrid Max is about performance and competing with the turbo’d Ford/Chevy/GMC trucks.
    ReubenSandwich and Lt. Dangle like this.
  8. Jun 3, 2023 at 3:24 PM
    #9228
    JWestie
    JWestie Well-Known Member
    2019 Tacoma DCLB-OR Mag gray
    I will never purchase another ICE-only vehicle and the iForce-Max is going to provide negligible efficiency gains over the ICE-only engine, so why would I bother getting a 4th gen Tacoma if I don't need 465 ft-lbs of torque? I think a lot of people will just skip right over Gen4 until better electrified options come along.
  9. Jun 3, 2023 at 3:31 PM
    #9229
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    That's in or before 2026. So your wait won't be long.
  10. Jun 3, 2023 at 3:33 PM
    #9230
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    BEV trucks are a novelty.
    Normal buyers such as myself don’t want an electric compromise of a truck. There will be an electric version eventually for those who do
    burnttaco7 likes this.
  11. Jun 3, 2023 at 4:16 PM
    #9231
    benzy
    benzy Well-Known Member
    Bay Area, CA
    2006 DCSB TRD OR
    Simple OME/884/AAL lift. 32” WP’s
    Except for the early adopters skipping generations should be the standard plan for Tacoma owners. A 3-4 yo Tacoma should take you to 2035 easy. My 2G was 10 years old when the 3G came out and it was an easy decision.
  12. Jun 3, 2023 at 5:16 PM
    #9232
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    What was an easy decision?
  13. Jun 3, 2023 at 5:19 PM
    #9233
    Turd Ferguson
    Taxachusetts
    I agree with second part of that. What’s the point of a complicated hybrid if you aren’t getting any meaningful fuel savings. If it was a plug in hybrid then sure that makes sense but at this point I will stick with a full ice or go with a full electric like a Lightning.
  14. Jun 3, 2023 at 5:20 PM
    #9234
    batt700
    batt700 Well-Known Member
    2017 SR5 Premium 4Runner
    Today I learned 700+HP and 70+MPGe is a novelty.....
    jkcashin, Lt. Dangle and kakwvu like this.
  15. Jun 3, 2023 at 6:04 PM
    #9235
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    Add in the increased cost (Tundra is wild), and it’s a non-starter. I looked for a lightly used Tundra before getting my AT4 and came up empty on something that made sense.
  16. Jun 3, 2023 at 6:40 PM
    #9236
    It's a TRD Thang
    It's a TRD Thang Well-Known Member
    Canada
    2021 Army Green Off Road
    3 inch Leveling kit with 265 75 r16 Ko2's
    The lighting is trash , doesn't even get close to the numbers they advertise especially on towing
    burnttaco7, CCATT-RN and taco terror like this.
  17. Jun 3, 2023 at 7:30 PM
    #9237
    benzy
    Bay Area, CA
    2006 DCSB TRD OR
    EV is half baked but most everything else is prime. Word is the 2024 F150 is styled like the Lightning which to me will prob be the best looking fill size gasser out there.
  18. Jun 3, 2023 at 7:35 PM
    #9238
    DRAWN
    DRAWN Well-Known Member
    2016 QUICKSAND AC SR5 4X4
    Sliders, 6112's, full skids.
    It’s so Toyota can give the truck the torque curve of a larger diesel or larger gas engine while still meeting emissions compliance. If you want good mpg and a bed then a compact truck like the maverick is a better option. Also the hybrid system is not that complex. Literally a clutch, electric motor and beefed up cooling system, a modern AT transmission has more moving parts. I think the standard iforce will be enough for most buyers. I wouldn’t mind getting 465 pound ft of torque at 1700 rpm. That’s sounds amazing compared to the 3.5, and it will still get slightly better mpg than the current gen. I don’t see an issue. No plug in hybrids exist in the class and BEV’s are still in their infancy.
    GarrettTacoma likes this.
  19. Jun 3, 2023 at 7:58 PM
    #9239
    Turd Ferguson
    Taxachusetts
    If it had a Toyota badge on it you would love it.
    Mad German and JB_TN like this.
  20. Jun 3, 2023 at 8:30 PM
    #9240
    It's a TRD Thang
    Canada
    Because toyota would do it properly
    stevesnj likes this.
