4th Gen Tacoma (2024+)
Discussion in '4th Gen. Tacomas (2024+)' started by shakerhood, Aug 26, 2021.
  1. Jun 11, 2023 at 5:35 AM
    #9461
    Plasmech
    Plasmech Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    Where is the 17 MPG figure coming from?
  2. Jun 11, 2023 at 5:38 AM
    #9462
    Plasmech
    Ah, I could have sworn the displacement of the G3 Tundra engine was reported as 3.5 liters.
  3. Jun 11, 2023 at 6:43 AM
    #9463
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    True.
  4. Jun 11, 2023 at 6:54 AM
    #9464
    AngryChair1983
    AngryChair1983 Errrr Rahhhh
    OR / WA / ID / WY / MT / NV / UT / CA
    08 TRD Off Road
    ARB bumper with warn winch, bilstein 5100 all around w/OME 886, Dakar leafs, 4.56 gears, 255/85r16 and 2 meter yeasu.
    Never said you can't rock crawl with the current location. Just trying to point out they could have made some simple changes to the truck and had more travel and better specs in some areas. I know that they know they can sorta do whatever they want so long as they slap a toyota or tacoma badge on it and everyone will buy it.
    I was just hoping they were going to make one model that reached for the stars so to speak.
  5. Jun 11, 2023 at 8:01 AM
    #9465
    jaxyaks
    jaxyaks Well-Known Member
    2020 Silver Tacoma TRD Off Road
    They are using the MPG rating for the new GX...
    Lord Helmet likes this.
  6. Jun 11, 2023 at 8:04 AM
    #9466
    jaxyaks
    I highly doubt the 4th Gen Tacoma is going to get worse fuel mileage than the 3rd gen. (I get 19-23 all day long everyday with mine)
    DragonDawg75 likes this.
  7. Jun 11, 2023 at 8:19 AM
    #9467
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    It's going to be a 2.4t mated to an 8spd auto in a heavy truck with a Rwd layout. 2.3t Ranger gets like 20 mpg with a 10spd, don't have a good average on the new GMs yet, and I think the 2.4t Highlander is probably getting 20mpg real world.
    Toyota is going to have to pull some magic to get acceptable EPA numbers.
    I don't care about fuel numbers, but regulators do.
    shakerhood[OP] likes this.
  8. Jun 11, 2023 at 8:29 AM
    #9468
    jaxyaks
    So at worst it stays pretty much the same...RWD configuration now with v6 is 19/24 21 combined. With 4 cyl its 20/23 21 combined. I don't think your going to see 15/18....Unless Toyota wants the Tacoma to be the only newly release truck in their lineup that does not improve fuel mileage....
  9. Jun 11, 2023 at 8:38 AM
    #9469
    Snakepilot
    Snakepilot Well-Known Member
    Tucson, AZ
    2025 Tacoma TRD Pro
    Tundra with 3.4TT gets 19 combined and the new GX gets 17 combined with a detuned 3.4TT. There about the same weight and aero. Could the full time 4wd make that much of a difference?
  10. Jun 11, 2023 at 8:44 AM
    #9470
    batacoma
    batacoma Truck Wars
    Toyota could claim any number they want and pay the fine latter. We will definitely get to see some mpg threads once people start driving 4th gens. If a Fwd Highlander is getting getting 22/29, yeah it's heavy. I can't see the new Tacoma getting an average of much more than 18/22 4wd non hybrid, and the heavier trucks with a hybrid will probably fair worse.
    Let's say the 6g 4R gets the same iForceMax 2.4t those numbers will be much lower as the 4R will pick up weight.
  11. Jun 11, 2023 at 9:01 AM
    #9471
    jaxyaks
    The 4 runner doesn't have to pick up much, its already at 16/19 17 combined.
  12. Jun 11, 2023 at 9:20 AM
    #9472
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    People keep saying lower emissions.
  13. Jun 11, 2023 at 10:45 AM
    #9473
    Turd Ferguson
    Taxachusetts
    Are you really getting lower emissions if you are still getting the same gas mileage as a non turbo engine? You’re burning the same amount of fuel to get from point A to point B. It just seems dumb to make all these complex little engines with twin turbos and electric motors if you aren’t getting any better mileage than you would with a simple NA V6 or small V8. It’s a bunch of BS. If we’re really concerned about emissions than just make them fully electric.
    GarrettTacoma and AngryChair1983 like this.
  14. Jun 11, 2023 at 11:07 AM
    #9474
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    No. I'm just looking for some physical evidence it exists. A render and a list of stuff with asterisk's beside it hasn't quite shown much of anything definitive.
    I'm sort of familiar with what the 3rd gen OR has, I want to know what the 4th gen has.
  15. Jun 11, 2023 at 11:11 AM
    #9475
    CrispyTacoLover
    Hell if I know. I’m just regurgitating what I’ve seen stated here.
    There will probably be a 1mpg improvement over the 3rd gen. Nobody even measures emissions around here anymore.
  16. Jun 11, 2023 at 11:14 AM
    #9476
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Can't comment on other manufacturers but for Toyota, yes. Toyota adjusts fuel enrichment based on a calculated catalytic temperature to maintain emissions efficiency. For example, the AFR is more rich on a cold start to get the cats up to temp faster. Then there are maps within the ECU that directly relate to fuel adjustment based on that calculated catalytic temperature. Maintaining a specific catalytic temperature ensures the cats are doing a better job at removing carbon monoxide, hydrocarbons, and nitrous oxides.
  17. Jun 11, 2023 at 11:17 AM
    #9477
    DRAWN
    DRAWN Well-Known Member
    2016 QUICKSAND AC SR5 4X4
    Sliders, 6112's, full skids.
    You’re equating mpg = less emissions which is true but not the only variable in terms of emissions. The dynamic force engines create less emissions because they are more thermally efficient than the previous gen engines and the combustion process is sped up by design decreasing emission levels. Two cars can burn the same amount of fuel but one of them will create more emissions if the combustion process isn’t optimized. The upside of chasing these regulations is all the dynamic force engines create much better torque than their predecessors even before the turbo. This vid explains it very well. They are chasing new regulation standards which are very real metrics they have to meet. I would rather manufacturers chase more stringent emissions requirements than the gov forcing mass EV adoption on the market before the tech and infrastructure is ready.
    https://youtu.be/wwLxxZm_LRQ
  18. Jun 11, 2023 at 11:35 AM
    #9478
    DRAWN
    With the 8 speed transmission, smaller more efficient turbo engine and similar weight as the third gen it would probably have minor gains in mpg. The tundra is rated 20/24. A much lighter Tacoma would get slightly better numbers. Probably 21 city, 26 hwy. even though it would be minor those numbers would make a difference for drivers like me that average close to 25k miles a year.
    DragonDawg75 and CrispyTacoLover like this.
  19. Jun 11, 2023 at 11:35 AM
    #9479
    Turd Ferguson
    Taxachusetts
    Amazing. Sounds like we’re saving the world a minute piece at a time. How much more energy is used to make an engine with a turbo and a hybrid system/battery vs what they are saving on emissions? That’s enough for now. I have to get back to getting the kids 2 stroke dirt bike running and then mow the lawn with my gas mower.
    AngryChair1983 likes this.
  20. Jun 11, 2023 at 11:54 AM
    #9480
    DRAWN
    Probably not that much more energy is used because economies of scale tend to be pretty efficient. So you’re saying no progress should be made at all if it isn’t substantial enough. That all or nothing approach doesn’t work in the real world. Reducing harmful emissions even a small percentage still makes a difference when we talk about the scale of how many vehicles there are on the road. Reducing air pollution is a net benefit for everybody. Look at Southern California’s smog problems before they started creating more strict emissions regulations. I would rather breath less harmful pollutants in but that’s just me. I’ll get back to riding my 4 stroke which has way less problems than my POS 2 stroke. No time wasted mixing gas and hardly have to touch the thing until it’s time to do a top end. I love how technology advances.
