4th Gen Tacoma (2024+)
Discussion in '4th Gen. Tacomas (2024+)' started by shakerhood, Aug 26, 2021.
  1. Aug 18, 2023 at 11:03 AM
    SwollenGoat
    SwollenGoat Onwards and Upwards!
    ‘21 ACLB, ‘99 XCLB, ‘92 RC, ‘85 4R
    Toyotas fail safe response for warranty work is “that’s normal”.
    If it is only loose and the nut didn’t fall off (or is it a captured nut?) anyways….if the bolt didn’t fall out, means the washer was never there from the factory.
    Think no matter the manufacturer, there will always be some sort of warranty battle.
  2. Aug 18, 2023 at 11:15 AM
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    Mine is the base engine :thumbsup:
  3. Aug 18, 2023 at 11:16 AM
    Falconemalcone
    Falconemalcone Member
    Malcolm
    British Columbia, Canada
    2019 OR AC 6M
    So how long until we get anymore content on the new Tacoma? They revealed it, only showed a few trims and there’s been fuck all for information since. Been like 3 months.
    burnttaco7 and taco terror like this.
  4. Aug 18, 2023 at 11:23 AM
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    That fire in the tree is pretty crazy.
  5. Aug 18, 2023 at 11:25 AM
    It's a TRD Thang
    It's a TRD Thang Well-Known Member
    Canada
    2021 Army Green Off Road
    3 inch Leveling kit with 265 75 r16 Ko2's
    That's what I said , one bolt means they screwed up but they are trying to say I'm on the hook. Also I am definitely not paying for the whole box the be replaced as per the body shops feed back. That is fucking ridiculous and will be thousands of dollars
  6. Aug 18, 2023 at 11:27 AM
    Turd Ferguson
    Taxachusetts
    Why can’t you just take the bolt out, put a big fender washer in there and tighten it back up. Then forget the whole thing even happened?
    burnttaco7 and Lt. Dangle like this.
  7. Aug 18, 2023 at 11:39 AM
    It's a TRD Thang
    Canada
    Read my post the body shop said it's warn out
    I have no clue why
  8. Aug 18, 2023 at 12:12 PM
    SwollenGoat
    It is however not in the base trim, yeah?
    Tried to build one in the WT trim, won’t let me do it. Before Ram cancelled theirs you could. If you looked hard enough, could find one in the low $30s or below if you were lucky. Now that makes financial sense to me. $30K truck and high 20s low 30s mpgs. Couldn’t bring myself to buy a Ram product though. Price is right, wrong manufacturer.
    On the Chevy when I do a build, it is $60K+, that doesn’t make $en$e to me.
  9. Aug 18, 2023 at 12:14 PM
    shakerhood
    shakerhood [OP] Well-Known Member
    Southern Ohio
    Sounds like full production of lower trims starts in December and Hybrid Models in 2024. Pricing still hasn't been released yet, but I would guess that probably won't be till around late October or early November.
    ReubenSandwich and Lt. Dangle like this.
  10. Aug 18, 2023 at 12:15 PM
    SwollenGoat
    Yeah it is, have video of it, but can’t figure how to save it, to upload it here. His son is carrying a 42” saw! The shape you have to be in to do that kind of work. Maybe in my 20s I could have, that stuff would kill me now.
    Toyota, king of the blue balls.
  11. Aug 18, 2023 at 12:16 PM
    MaxTaco6
    MaxTaco6 Well-Known Member
    Vancouver, BC
    2022 TRD OR Lunar rock
    Same here in West coast, Canada. That's a pretty sick Arson trick, burn from inside, even the rain can't stop it.
  12. Aug 18, 2023 at 12:20 PM
    shakerhood
    Southern Ohio
    Does GM do the same is what Toyota is planning with cutting the HP on the WT as with the SR AT?
  13. Aug 18, 2023 at 12:20 PM
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    They offer the 2.7T or 5.3L in lower models.
  14. Aug 18, 2023 at 12:23 PM
    SwollenGoat
    Didn’t even think of arson, was guessing it worked its way through the root system. Though majority of fires are started by arson and/or negligence.
    You would think with all the heavy snowpack the west got this year, fire season wouldn’t be too bad.
    The fire map says otherwise.
  15. Aug 18, 2023 at 12:24 PM
    SwollenGoat
    They do on the Colorado, iirc the WT has different mechanicals so it can’t be tuned. Don’t quote me on that, though do remember reading something somewhere…
    Edit: found it, it gets the lighter duty trans, can’t be tuned for high output.
    https://tfltruck.com/2023/02/2023-chevy-colorado-engine-tune-news/
    sorry it is TFL, but I was in a hurry.
  16. Aug 18, 2023 at 12:31 PM
    Turd Ferguson
    Taxachusetts
    And you believe that? That doesn’t even make any sense. What’s worn out? It’s a 2” thick piece of plastic bolted to a steel frame.
    Lt. Dangle likes this.
  17. Aug 18, 2023 at 12:37 PM
    It's a TRD Thang
    Canada
    Don't worry I think I need a second opinion lol
  18. Aug 18, 2023 at 12:42 PM
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    Every Canyon model gets the high output tune, btw.
    SwollenGoat[QUOTED] likes this.
  19. Aug 18, 2023 at 12:56 PM
    benzy
    benzy Well-Known Member
    Bay Area, CA
    2006 DCSB TRD OR
    Simple OME/884/AAL lift. 32” WP’s
    An EV Tacoma is going to 60k minimum in todays dollars. You’ll be lucky to get a unibody Scout EV (or whatever they end up calling it) for less than 45k.
    This gen 4 is the last opportunity to buy a Toyota truck for less than luxury pricing. Or keep your 2G/3G. But this idea that capable EV trucks are going to sell anywhere close to what most consider consumer prices is a pipe dream.
  20. Aug 18, 2023 at 1:05 PM
    Johnny919
    Johnny919 Well-Known Member
    Long Island, NY
    2006 Honda Pilot EXL 4WD
