4th Gen Tacoma (2024+)
Discussion in '4th Gen. Tacomas (2024+)' started by shakerhood, Aug 26, 2021.
  1. Nov 16, 2023 at 11:14 AM
    SwollenGoat
    SwollenGoat Onwards and Upwards!
    ‘21 ACLB, ‘99 XCLB, ‘92 RC, ‘85 4R
    What are they? Inquiring minds would like to know :)
  2. Nov 16, 2023 at 11:15 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Yes, and it doesn't drain over the steering rack motor. :laughing:
    Wonder if 4th gen will get an electric radiator fan. The water pump pulley doesn't have the 4-bolt pattern normally used to attach the fan hub.
  3. Nov 16, 2023 at 11:19 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Trailer hitch too low as well as spare, needs larger rear access window, hose out interior option, better tire selection, smaller wheel size availability especially on off road specific models 16" and 17", rear link suspension on all trim levels, higher payload capacity, heavy spring option for front and rear, heat pump for HVAC, standard remote start, long travel suspension option.
    SwollenGoat[QUOTED] likes this.
  4. Nov 16, 2023 at 11:23 AM
    SwollenGoat
    That is a fairly substantial list. Agree with all of those.
    stevesnj[QUOTED] likes this.
  5. Nov 16, 2023 at 11:45 AM
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    It’s so messy dealing with the cartridge. Also have to remove three pieces of skid plates. I just bought a new housing for the last oil change at around 90K miles. Seems like good insurance to replace it before it gets old and cracks.
    My second gen is so nice to change the oil on with the oil filter up on top of the engine. Only takes about 10 minutes.
  6. Nov 16, 2023 at 11:46 AM
    Turd Ferguson
    Taxachusetts
    What a whiner. :D
    SwollenGoat and Lt. Dangle like this.
  7. Nov 16, 2023 at 12:31 PM
    Turd Ferguson
    Taxachusetts
    TreeFortRichard likes this.
  8. Nov 16, 2023 at 12:49 PM
    JWestie
    JWestie Well-Known Member
    2019 Tacoma DCLB-OR Mag gray
    I did mine for the second time this morning and am on the fence as to whether l will do it again. Its a minor PITA to remove air dam and front skid and my oil filter wrench (Toyota brand cap) loves to get stuck on the plastic oil filter housing. And of course I had a spill at the end.
  9. Nov 16, 2023 at 1:25 PM
    It's a TRD Thang
    It's a TRD Thang Well-Known Member
    Canada
    2021 Army Green Off Road
    3 inch Leveling kit with 265 75 r16 Ko2's
    It's better then the v8 though and also if you don't spool the turbo off the line it isn't as bad . It's a full size though so what does anyone expect especially when toyota said the hybrid wasn't designed for gas savings. Curious though if there are tunes out there that can help with that
    DRAWN likes this.
  10. Nov 16, 2023 at 1:36 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Looks are subjective. I’d rather hear about features that are new and different that set the vehicle apart (no matter how small) rather than somebody saying ew glossy fender flares.
    Lorescar likes this.
  11. Nov 16, 2023 at 1:43 PM
    Turd Ferguson
    Taxachusetts
    It was 1 mpg better than one of the V8s but 2 mpg worse than the other v8. All this complication and expense for that?
  12. Nov 16, 2023 at 1:53 PM
    BirdBrain
    BirdBrain Well-Known Member
    2021 4wd Off-Road
    I want to know if the air conditioning blows cold when outside temp is above 100F.
  13. Nov 16, 2023 at 1:56 PM
    shakerhood
    shakerhood [OP] Well-Known Member
    Southern Ohio
    They probably could have paired the 10 speed auto to the V8 and improved the MPG.
    Turd Ferguson[QUOTED] likes this.
  14. Nov 16, 2023 at 2:10 PM
    pittim
    Pennsyltucky
    Boujee Prius
    You can have either improved efficiency with the same power or improved power with the same efficiency.
    Buyers choose the latter.
  15. Nov 16, 2023 at 2:49 PM
    SwollenGoat
    Did they though if there was no other option?
    Ford lets you pick from 4 different powerplants. Plus their hybrid is arguably more useful since you can power your house with it.
  16. Nov 16, 2023 at 3:13 PM
    Turd Ferguson
    Taxachusetts
    Are you sure about that last part?
    The previous Tundras were pretty nice trucks. The only complaints I ever heard were the fuel mileage sucks. It’s the reason I never bought one. Now they completely redesign the truck and it’s not much better???
  17. Nov 16, 2023 at 3:37 PM
    It's a TRD Thang
    Canada
    I have seen posts guys getting 20mpg plus and guys getting 15mpg
    I think it depends where you live , the gas where you live and how heavy their foot is
  18. Nov 16, 2023 at 3:53 PM
    stevesnj
    Well let's say the mileage is the same as the V6 but the power is a noticeable increase across the board in the 4T and 4T Hybrid? Will that be acceptable?
    Lt. Dangle likes this.
  19. Nov 16, 2023 at 3:56 PM
    Turd Ferguson
    Taxachusetts
  20. Nov 16, 2023 at 4:02 PM
    Acey
    Acey Well-Known Member
    Denver ish
    ‘24 Cybertruck
    and the 8 speed transmission!
    V acceptable
